Fuel Shutoff? Rolled my truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TurdGenBrah, Dec 2, 2017.
  1. Dec 3, 2017 at 7:54 PM
    #121
    J.M Taco
    J.M Taco Well-Known Member
    Central California
    '17 Tacoma Quicksand DCSB TRD OR 4x4
    :eek:
    Holy smokes...
  2. Dec 3, 2017 at 8:02 PM
    #122
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    FIFY....
  3. Dec 3, 2017 at 8:11 PM
    #123
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
    It might be. I've checked with my insurance in the past and discovered they will cover off-roading damage as long as it wasn't an event or formal competition like a charity or a race.
    But...let's hope it doesn't come to that. Sure do hope to see you post a positive report.
  4. Dec 4, 2017 at 6:30 AM
    #124
    TurdGenBrah
    TurdGenBrah [OP] Well-Known Member
    2016 Black TRD Off-Road ACLB Tacoma
    CB radio, ARB bumper, OME 886 coils w/ Nitrocharger shocks, TRD Pro grill
    Warranty is still good (24,000km's but I purchased extended) I just meant I'm not sure warranty will still be in effect following this situation I put myself/the truck in.
  5. Dec 4, 2017 at 6:31 AM
    #125
    TurdGenBrah
    Ok I'll call my provider and speak with one of their adjusters. Doesn't hurt to inquire right?
  6. Dec 4, 2017 at 6:33 AM
    #126
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    You still haven’t blasted the oil out of the cylinders yet? Your over thinking this it’s like a 1 beer job
    JoeyDel, crisanalex, synaps3 and 2 others like this.
  7. Dec 4, 2017 at 6:34 AM
    #127
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Most insurance covers anything that’s not a timed event like a race. Doesn’t matter where it is.
  8. Dec 4, 2017 at 6:35 AM
    #128
    TurdGenBrah
    Negative, haven't gotten the plenum spacer off in order to get to the driver's side plugs. Busy with work and ran out of daylight yesterday.
  9. Dec 4, 2017 at 6:38 AM
    #129
    TurdGenBrah
    Working outside on the street on a lifted truck with ice all around me, it's below freezing and I don't have a lot of mechanical knowledge.
    I just want to make sure these steps are done right, doesn't look like I'm gonna be able to get a breaker bar on the crank to turn it over manually so I'm kinda worried about that as well.
  10. Dec 4, 2017 at 6:46 AM
    #130
    TurdGenBrah
    Do I bump the starter or try fully cranking it over? Also, will the starter engage with the coil/plugs removed?
    Thanks
  11. Dec 4, 2017 at 6:53 AM
    #131
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    I just read through the thread and i initially thought it was hydrolock. You probably do not want to crank it until you make sure nothing is in the cylinder or combustion chambers. Or until you can manual turn the crank.
    Pull the plug out, check and see if spark plug is wet or if you see liquid inside first. Very easy first step...
    Check for mechanical blockage that could be preventing motor from turning like one of the reply.
    Troubleshoot the starting circuit.
    I hope she'll recover!
    I married my tacoma likes this.
  12. Dec 4, 2017 at 7:10 AM
    #132
    TurdGenBrah
    After recovering the truck, getting it to flat ground for 20 minutes and checking the oil level (which showed between add and full) my friends convinced me that it would be fine to try starting the truck... I expressed concern regarding further damage but they were sure whatever damage that was there was done already. Like a potential fool, I tried starting it up. Starter clicked, we heard a thud. They deduced that the battery was no good due to it being on its side for over almost 2 hours so they boosted it and we tried again. Just clicked. Flatdecked it home and started pulling plugs after 24 hours of sitting, hadn't tried turning it over again. Oil level is showing full now.
    I'll get started on driver's plugs after work with the 1 hour daylight I have in -15 C temps
  13. Dec 4, 2017 at 7:12 AM
    #133
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Yes if it was my truck. I would pull the plugs and turn the motor over with the starter. It’s going to take 20 -30 secs of turning it over to get all the oil out. You can stop when you see no oil shooting out.
    If the rods or bent the damage is already done. And the motor will have to be rebuilt or swapped
    wilcam47 likes this.
  14. Dec 4, 2017 at 7:14 AM
    #134
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Wow -15 your better than me. That truck would sit until spring if it was me. Lol
    tcjacado, boynoyce and pictureaday like this.
  15. Dec 4, 2017 at 7:19 AM
    #135
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Bump the starter by bridging the contacts with a screwdriver, that way you are right there, can see what is going on, won’t have to worry about any other nannies between the ignition switch and starter.
    Of course this is after pulling your plugs.
  16. Dec 4, 2017 at 7:20 AM
    #136
    krzysnwbrdr
    Masaki
    Haha the temp reminds of me being in ND. I used to work on bikes in the garage at those temperature. I hated when i had to sand the whole plastics.
    Anyways, i would not try to start it until i am sure its safe to turn. Hydrolocks can easily break your conrods.
    If you cant see with flashlight you could use a tube or slinge and try to suck it up. if there is nothing, now you have less things to worry about and move on to next possibility.
    Very good mechanics can narrow down the cause quickly but people like me i would eliminate possible cause one by one...
  17. Dec 5, 2017 at 4:53 AM
    #137
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    May want to pull the fuse for your fuel pump before turning the motor to shoot out any potential oil
    TurdGenBrah[OP] likes this.
  18. Dec 5, 2017 at 6:07 AM
    #138
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    No shit. lol
    Temps are supposed to drop below 50 tonight. I'm in fear for my life.:goingcrazy:
  19. Dec 5, 2017 at 6:51 AM
    #139
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Those jeep boys must have been talkin smack the whole time .
    Seriosly though, hope all is well in the end. Last thing you want is a bent rod from being hydro locked.
  20. Dec 5, 2017 at 8:00 AM
    #140
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    :smack:
    My balls don't even start to draw up until it drops below freezing
    BlakeM[QUOTED] and Paul123 like this.
