Fuel smell question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bababooian, Jan 11, 2016.
  1. Jan 11, 2016 at 4:52 PM
    Bababooian
    Bababooian [OP] New Member
    Ian
    2004 Tacoma 4wd sr5 supercab
    K&N cold air intake, air spacer, filter (air and oil). Leveling kit
    I just replaced my catalytic converter today with the flow master because the Toyota dealership said they were 99.9% sure that I needed a catalytic converter it was restricting. But I had a fuel smell coming out of my exhaust and my question is what could be causing the fuel smell. It is a 2004 Toyota Tacoma 4 x 4 V6 and it idles perfect runs perfect however the fuel smell out of the exhaust. No other code is coming up in the engine but I am thinking the water efi sensor or mass air sensor. My truck looks like it has 25,000 miles on it but it has 219,000 miles on it... Anybody have suggestions on what could be making the truck burn rich or smell Rich coming out of the exhaust pipe before I spend a ton of money on changing every little thing ? Thank you
  2. Jan 11, 2016 at 5:04 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Google: toyota 3.4 "running rich"
    Lots of hits to research.
    Bababooian[OP] likes this.
  3. Jan 11, 2016 at 7:08 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    welp. smelling rich. if the cat is truly clogged, more exhaust may be shooting out of it than it can handle in the free'er flowing parts of the honey comb. does it still smell like gas? and are you checking for gas smell when the engine is cold, or warmed up after it's been running a while.
    now for a truly rich burning situation. youll need a scanner and also need to watch the fuel trims and air intake levels both measured and calculated. that way you can see if everything is matching or something is out of whack.
    but the only real way you would have a rich situation is if your front o2 sensor is bad and reporting everything being ok when it isnt.
  4. Jan 11, 2016 at 7:13 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    A failing temp sensor can richen [sic] the mixture once it goes into closed loop. Does it start easily from cold and then, once warm and shut off, crank a bit longer then normal?
  5. Jan 14, 2016 at 11:55 AM
    96coma
    96coma Active Member
    Josh
    New Hampshire
    96 5sp tacoma 4x4
    to much to post lol
    if it helps, i have the 2.7 mine was running rich with a fuel smell recently, turns out my maf was dirty (truck sits for awhile during the summer) had black fuzzy stuff built up in it, cleaned that and replaced my air filter and was good to go, hope that helps
  6. Jan 14, 2016 at 6:28 PM
    Bababooian
    Ian
    Thank you
  7. Jan 15, 2016 at 9:18 AM
    96coma
    Josh
    New Hampshire
    96 5sp tacoma 4x4
    to much to post lol
    No Problem man, let me know how it turns out
  8. Jan 15, 2016 at 10:13 AM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    My 2001 2.7l does the same thing, fuel smell but only when it is cold. Once it is warmed up the smell goes away. No cel, truck runs good with 248,000mi.
  9. Jan 18, 2016 at 8:18 AM
    96coma
    Josh
    New Hampshire
    96 5sp tacoma 4x4
    to much to post lol
    mine did the same thing, then i just did what i mentioned above and it fixed my problem but to be safe check the plugs and wires also the cap and rotor too just to be safe, also i think its the egr, theres filters in there you just take the cap off to clean or replace those little filters, that may help also
