Fuel System Cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TaylorU, Jul 4, 2013.
Thoughts on fuel system cleaner products?
  1. Yes, it helps
    129 vote(s)
    52.9%
  2. Not worth the price
    13 vote(s)
    5.3%
  3. Completely useless
    30 vote(s)
    12.3%
  4. Not sure
    76 vote(s)
    31.1%
  5. STP brand
    6 vote(s)
    2.5%
  6. Gumout brand
    7 vote(s)
    2.9%
  1. Jul 16, 2013 at 7:34 AM
    #41
    stocksport
    stocksport Well-Known Member
    Orlando, FL
    White 2011 TRD Sport DC 4x4
    Blacked out emblems, Weathertech liners, LED interior, tag, and 3rd brake light, reverse light mod, rear TSB, rear diff. breather, added black factory running boards, OR tow hook, and rhino lined UWS low profile box.
    Ethanol Medic FTW. I use it in every tank in my boat. 1oz. treats 16 gallons of fuel. It may not differentiate itself much in our trucks, but I've tried it all in marine applications. Sta-Bil, Startron, and SeaFoam. I don't have a scientific test, but I do have a real world experience.
    I bought a boat that had sat for about 6 months, which gummed up the entire fuel system. It has a carbureted 351 engine. Started off using my go to, which was SeaFoam. It ran, but not great, and it would occasionally shut off due to the fuel tank pick up getting clogged with a brownish gum like sludge. (27 gallon aluminum tank with no easy way to clean out) I was able to remove the gas, but the gunk remained. Then I tried Startron. I think it's better than SeaFoam, but I was still having to pull the pick up and clean gunk out of it. Ran through a couple tanks with Startron having to clean the pick up every other time I ran it. Then a family friend who works on jet skis gave me a bottle of Ethanol Medic. (He did his own test with all four mentioned) This sounds like a sales pitch, but this stuff made my boat run the best it ever had since I bought it. Never had to clean the fuel tank pick up after using it either. Did I eventually clean all the gunk out of the tank before using Ethanol Medic?? possibly... but I doubt it. Just my experience, but I swear by it.
  2. Jul 16, 2013 at 9:37 AM
    #42
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    Marvel Mystery Oil... I dunk the truck in it one a week. It runs great.
  3. Jul 16, 2013 at 12:45 PM
    #43
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Best stuff you can buy!
  4. Jul 17, 2013 at 10:41 PM
    #44
    Komrade
    Komrade Well-Known Member
    13 DBCB 4x4 MT
    I have seen SeaFoam sold in places that rent equipment like tractors and chainsaws.
    it's definitely good for anything that sat for a few months (including chainsaws and generators). I've seen my generator bought off CL craigslist purr much better after a proper dosage (watch the dosage in small fuel tanks!). I've used it on cars too, but probably a waste, unless car sat somewhere for a while.
  5. Jul 17, 2013 at 11:08 PM
    #45
    Vegas Tacoma
    Vegas Tacoma Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    Where can you get this at other then at the dealership
  6. Jul 18, 2013 at 6:21 AM
    #46
    Mossy
    billy
    san antonio, TX
    Not real sure. I work for a dealership so that's how I get it.
  7. Jul 18, 2013 at 6:48 AM
    #47
    pinktaco808
    pinktaco808 Hot Steppa
    pics thanks of 4 cylinder engine
  8. Jul 18, 2013 at 7:00 AM
    #48
    BamaToy1997
    Bill
    Navarre, FL
    You can buy the BG44k products on Ebay and other online sales places like Amazon. This chemical is added to your fuel tank on fill up and slowly works to clean light deposits in injector tips and on valve stems and backs. If you want to take care of heavy valve deposits and severe carbon build up on the valves, AND the intake runners, then you should use this:
    [​IMG] Which is designed to clean the entire induction system. HOWEVER to do it properly requires a special tool like the one below.
    This tool, and a special adapter for the throttle body, allow the chemical to quickly clean the entire intake from the throttle plates back. THAT is the way to clean it if you really want to take care of the oil and carbon deposits on an engine. MOST dealerships charge around $199.00 to do this service, but make SURE that the tech does the INDUCTION cleaning service, not the INJECTOR cleaning service, which uses the same tool, but only cleans the injectors and valves.
    BG makes some pretty good products, but they are normally for commercial sales. (dealerships, independent shops, etc...) However you can still get them. I swore by them when I was in the dealerships. I have had trucks come in with random misfires, lean codes, rich codes, etc. and simply used an injector service and/or induction service, and they ran like a top afterwards, when other shops would tell the customer they needed new injectors, to the tune of $1000.
    #48
  9. Jul 18, 2013 at 7:01 AM
    #49
    BamaToy1997
    Bill
    Navarre, FL
    Could you be more specific? 1st gen? 2nd gen? And what product are you talking about using. Different products will need to be ingested at different locations.
  10. Jul 18, 2013 at 8:33 PM
    #50
    pinktaco808
    sorry about that second gen 06 base model 4 cylinder.
    and whatever that guy was using.
  11. Jul 30, 2013 at 8:06 PM
    #51
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    As long as you use a quality gasoline with a good additive package. Then you don’t need fuel system cleaner. It’s a waste of money because it’s already in your gasoline.
  12. Jul 31, 2013 at 10:31 AM
    #52
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    It's really a preference. Personally, I feel that using an additive in your gasoline does help, but the fuel system is still prone to buildup. Which, I feel, is a good reason to use products like seafoam through a vacuum line a couple times a year. It's like a deep clean that the fuel additives don't get.
  13. Jul 31, 2013 at 10:56 AM
    #53
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    @BradyT88
    2006 V6 4x4
    @BamaToy1997
    Is this the line you are talking about?
  14. Jul 31, 2013 at 7:27 PM
    #54
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    lucas,buy it at the truck stop by the gallon.4 ounces every 3rd tank or so.hasnt failed me yet.
  15. Aug 1, 2013 at 11:18 AM
    #55
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    Seafoam
  16. Aug 1, 2013 at 1:41 PM
    #56
    Nfurtado77
    Nfurtado77 Well-Known Member
    Sea foam used to clean the throttle body on my car and poured some in my tank.
  17. Aug 1, 2013 at 5:18 PM
    #57
    bigshug1
    bigshug1 Well-Known Member
    Concord, VA
    '16 DC Off-Road 4x4
    Another vote for Seafoam - I use it in my ZX6R and I have used in my BMW's of days past...
    Not sure whether the prices are universal - but our local (in central VA) Northern Tool has SeaFoam for ~$6.50 for the 16oz size...
  18. Aug 1, 2013 at 5:22 PM
    #58
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    I've used Seafoam and the Chevron Techron stuff. I liked the Seafoam better as a induction cleaner than the Chevron stuff as a tank pour.
  19. Aug 1, 2013 at 8:13 PM
    #59
    RPD STARS
    RPD STARS Turn up the good, turn down the suck!
    BC
    2010 Raptor
    Go Faster Retrozzz... Drop in Dry Flow, Blowfaster Delta 50, 315/70/17 BFG Stock Action
    I use lucas with my 94 chevron fill ups.... i dunno if it does anything but it makes me feel better.
  20. Aug 1, 2013 at 8:15 PM
    #60
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    I use Marvel's Mystery Oil, I have been pleased with the results in other vehicles, have yet to use it in the taco though...
