Fuel System Cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TaylorU, Jul 4, 2013.
Thoughts on fuel system cleaner products?
  1. Yes, it helps
    129 vote(s)
    52.9%
  2. Not worth the price
    13 vote(s)
    5.3%
  3. Completely useless
    30 vote(s)
    12.3%
  4. Not sure
    76 vote(s)
    31.1%
  5. STP brand
    6 vote(s)
    2.5%
  6. Gumout brand
    7 vote(s)
    2.9%
  1. Aug 18, 2013 at 6:44 PM
    #61
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    i use Seafoam once every 4 months, but i put half in gas and half in vacuum line... then i put gas treatment in truck once every 2 months... I actually do see a difference with it.. right now i get about 22-23 MPG mix of highway/mountain/city...
  2. Aug 18, 2013 at 7:03 PM
    #62
    Greenpants
    Greenpants Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
    Chevron Techron ,all my cars & trucks for twenty years. Stuff works !
    greenpants....mike
  3. Aug 18, 2013 at 8:26 PM
    #63
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I have heard nothing but good things about Techron.
    I recently put Seafoam into the gas and a little into the oil of my tractor mower. Ran it for a bit and then sucked some through the carb. Yeah... white smoke. Changed the oil and I'll be damned if the thing doesn't run and sound better now.
  4. Aug 18, 2013 at 10:16 PM
    #64
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Seafoam is awesome. I had an old 1991 Kawasaki ZX6 in the shed stored for 2 years. Carbs were gummed up and the gas was bad. Needless to say she wouldn't start. Half a can of Seafoam in the tank, left it overnight and she started up on the first try the next day!
  5. Aug 18, 2013 at 10:46 PM
    #65
    Nfurtado77
    Nfurtado77 Well-Known Member
    Why in the oil? And one of the side effects of seafoam is white smoke. My favorite part of seafoam is the aggressive driving they suggest after you use it.:D
  6. Aug 19, 2013 at 8:19 AM
    #66
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    wow I have 101k miles and ive never used a fuel cleaner, think it's time to dump a bottle?
  7. Aug 19, 2013 at 3:52 PM
    #67
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  8. Aug 19, 2013 at 9:36 PM
    #68
    Vincent05
    Vincent05 Well-Known Member
    Bucks County, PA
    Tacoma
    why not just use 93 octane instead of 87 and adding these additives.
  9. Aug 19, 2013 at 10:00 PM
    #69
    Vincent05
    Bucks County, PA
    Tacoma
    I drove a couple Astro vans before getting my Tacoma. Tried using 87 and it would not drive the same as 93, wouldn't pick up speed. Ever since then I never used any other octane. Heard 93 burns cleaner and doesn't gunk up the engine as 87 does.
  10. Aug 20, 2013 at 8:06 AM
    #70
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    so seafoam you dump it in the gas tank before you fill up?
  11. Aug 20, 2013 at 9:32 AM
    #71
    Nfurtado77
    yea basically how it works most engines wont run any better with high octanes, they are harder to burn
    Spray seafoam into a throttle body then scrub it will a toothbrush and you won't think its snake oil anymore.
  12. Aug 20, 2013 at 2:33 PM
    #72
    Maticuno
    2011 Suburban 2500
    There is a huge difference between spraying some on a part and cleaning it by hand, and just dumping it in the fuel tank and praying for the best.
  13. Aug 20, 2013 at 9:04 PM
    #73
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
  14. Aug 20, 2013 at 11:53 PM
    #74
    Nfurtado77
    Either way for $6 why not do it.
  15. Aug 21, 2013 at 5:42 AM
    #75
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    I have used seafoam in all of my vehicles/boats/lawn mowers/engines over the years as a general preventative against gunk buildup. I add some to the gas tank maybe once a year. I add some to the crank case maybe 100 miles before I plan to do an oil change; not every oil change but maybe every 3rd or 4th. I spray some into the carbs on my '79 Mercury outboard every year as part of my de-winterizing routine...still runs like a top.
    A few months ago my son call me and told me his Pathfinder wasn't starting, and asked for my help. I started troubleshooting it; no codes, gas in the tank, strong battery; sounded like it wanted to start but just wouldn't. I finally could get it started using starter fluid sprayed into the air intake, but thats the only way. If I turned it off and tried to start it again, it wouldn't start (even hot) without starter fluid. Mind you, even though he is my son, PM is the last thing on his mind. I decided to "SEAFOAM" the vehicle... I added a can of seafoam to the tank, some to the crancase, and ran some trhough the brake-booster vacuum line. Well what do you know, it then started on its own and continued to do so...no issues...problem solved. I honestly don't know if he had bad gas or gunked up fuel system (or both?). Point is, the Seafom worked...that's all I did.
  16. Sep 3, 2013 at 9:21 AM
    #76
    metrick1215
    Habersham GA..
    My 0.02 is why spend an extra 8 bucks on a tank of gas 4x a month when i can put a can of seafoam in every six months for the same price
  17. Sep 3, 2013 at 10:17 AM
    #77
    Biznitch15
    Biznitch15 Well-Known Member
    José
    Los Angeles/San Diego
    13 DCLB TRD Sport
    None Yet
    If you have a 21 gal tank and filling every last drop. The 93 octane over 87 is only an extra $4.20 and that's if you're at empty to begin with. Plus 93 does not clean better. And the price above is assuming premium over regular is 20¢ more
  18. Sep 3, 2013 at 11:11 AM
    #78
    chas44
    chas44 Well-Known Member
    Virginia
    2012 TRD Sport
    I have used Seafoam in my last few vehicles and have had relative success with it. I am by no means a chemist or researcher who can validate Seafoam to be the exact and only cause to the vehicles running better, but anytime I have treated my cars it has also improved the driving experience such as idling and fuel economy. For instance, I recently purchased my 2012 DCSB Sport with 8,000 miles on it. I drove it around a few weeks and was getting between 18-19 mpg with 70/30 highway and city driving. Put in a can of Seafoam into an empty tank, filled it up, and the last two runs I have made between fill-ups have yieleded between 20-21.3 mpg driving under the same circumstances as before. Was Seafoam the cause? I can't definitely say yes, but I would say there is a strong correlation to it being largely attributable to better vehicle performance.
  19. Sep 3, 2013 at 1:50 PM
    #79
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I voted no to this...then I started to do some research on bobstheoilguy lol. Anyways apparently the chevron techron concentrate plus has been getting alot of positive feedback from several different forums. Soooo...I just ordered some from advance auto parts and it was on sale $4.99 a bottle! All the other sites I checked was $12 per bottle. Here's the link to advance if anyone wants to try some. http://shop.advanceautoparts.com/p/chevron-techron-complete-fuel-system-cleaner-12oz-67740/7081073-P
  20. Sep 15, 2013 at 6:39 AM
    #80
    metrick1215
    Habersham GA..
    lol so for me that would be 16.80 extra a month to run Premium in my truck seeing as i fill up about 4 times a month.. so seafoam every 6 month vs $100.80 extra in gas... id rather spend 8.00 in seafoam every 6 lol...
