Fuel System Cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TaylorU, Jul 4, 2013.
Thoughts on fuel system cleaner products?
  1. Yes, it helps
    129 vote(s)
    52.9%
  2. Not worth the price
    13 vote(s)
    5.3%
  3. Completely useless
    30 vote(s)
    12.3%
  4. Not sure
    76 vote(s)
    31.1%
  5. STP brand
    6 vote(s)
    2.5%
  6. Gumout brand
    7 vote(s)
    2.9%
  1. Sep 27, 2013 at 9:36 AM
    #81
    Nmwill
    Nmwill Well-Known Member
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Blacked out emblems and grill. 265/75's shortened antenna
    +1 for techron. The concentrate that is I'll run a bottle through a couple tanks before a oil change. Or if I am ordering something from Amazon I'll get some SL-1. Both contain high amounts of PEA "poly ether amine". Go read about the cleaners on bitog. If you want to read till your eyes bleed. Or just stick with gumout regane. Chevron concentrate. SL-1 or the Amsoil cleaner. I also recommend running a good premium gas.
  2. Sep 29, 2013 at 3:08 PM
    #82
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    i have used seafoam in all my gas filled junk for at least 10 years. i have no bad gas issues ever. you can let it sit over winter or summer and itll fire right up after that long here at least. i put a can in my truck about every 6 months
  3. Sep 29, 2013 at 7:19 PM
    #83
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Another vote for Chevron Techron here.
  4. Oct 3, 2013 at 7:27 AM
    #84
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  5. Oct 3, 2013 at 7:48 AM
    #85
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    After reading this thread I went out and tried to find some seafoam or Chevron Techron, but the one place I went to was out of the Seafoam and didn't sell the Techron.
    So I bought a couple bottles of BlueChem Fuel system cleaner. Put one gas tank and put half a bottle through the air intake nipple thingy on my Acadia.
    Anyway, my Acadia only has 100,000 KM's (62,000 miles) and a couple of years ago I had the system cleaned the one time I went to Mr. Lube for an oil change and tranny fluid change.
    No smoke whats so ever, which is what I was expecting and hoping for!
    Next will be the engine cleaner before my next oil change....
  6. Apr 17, 2015 at 3:14 AM
    #86
    Jmcavene
    Jmcavene Wish I Had TRD OffRoad
    New England
    '14 Access Cab SR5 4x4
    Nd4 anytime foglights, WeatherTech digital fit floor mats, WeatherTech Side Window deflectors, WeatherTech Stone & Bug Deflector
    93 Octane, Gumout Regane every 2,500mi. On a good tank of gas if I dont gun it or haul ass a lot. I can get 400+ miles per tank. I usually refill at just over a 1/4 tank. So I'm right around 300+ miles at that point. And that's in the Warm weather months. I get just under those numbers in the winter.
  7. Apr 17, 2015 at 5:45 AM
    #87
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    bg44k or techron is a good call always
    you cannot rely on the statement 'run a good grade of gas you'll be fine' because your engine does not simply consume the gas you put in it
    it also consumes oil vapor or oil droplets which can be wildly different chemical composition depending on the oil you use, and amount of pcv valve and ring blowby. also a lot depends on how much scavenging is done when the engine shutsdown...if any. it is this mung from burnt oil and the carbon it leaves behind that can be reduced with a little extra solvents in the occasional tank
  8. Apr 17, 2015 at 5:53 AM
    #88
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Techron at every oil change for me. Try and buy it at Advanced Auto when it's buy 1 get 1 free.
