fuel system maintenance
Discussion in 'New Members' started by tacomatug, Dec 29, 2011.
  1. Dec 29, 2011 at 10:51 AM
    tacomatug
    tacomatug [OP] New Member
    05 Tacoma
    I have a 2005 Tacoma with 82000 miles. I recently went to the dealer to have the accelerator pedal modified from the recall. They informed me the throtttle body needed cleaned (79.95). I recently got a dealer coupon. For 99.99 they clean the fuel injection throttle body, pressure flush the injectors, and check the emission system. Is this worth doing? I get different viewpoints such as run a tank of 93 fuel. I generally use 97. Truck runs fine except the gas milage isn't as good, but I haven't had the plugs changed since 30,000.
  2. Dec 29, 2011 at 2:23 PM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Welcome to TW from SoCal! Dealerships are famous for recommending service that doesnt need to be performed. I would consider getting a second opinion. That said, it is pretty easy to clean a throttle body yourself. Simply spray throttle body cleaner into the air intake (remove air intake hose from filter housing first). Have someone on hand to press accelerator as you spray, as your rpms will drop. My mechanic friend charges something like 59.95 for this 5 minute procedure:eek:
  3. Dec 29, 2011 at 2:27 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Clean the MAF sensor too.
  4. Dec 31, 2011 at 4:25 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
