Fuel system problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Peter6899, Oct 13, 2023.
  1. Oct 13, 2023 at 2:28 PM
    Peter6899
    Peter6899 [OP] New Member
    Peter
    1999 tacoma 4cyl 2wd standard
    None
    Hi Folks!
    While driving a load of compost to my garden, my trusty stead of a 1999 2.4L 4 Cylinder 2wd, otherwise known by my sons as my POS truck (LOL), lost power and died. It would start up, but cut out shortly after.
    I've changed the Fuel filter (long over do) and have just replaced the fuel pump motor. She starts up fine, but then cuts out and I can hear the fuel pump motor hum for a sec before it quiets.
    This truck has helped me remodel 1 house, build another from scratch and hauled fire wood, soil compost etcetera...it's got 165,000 miles on it, so it's not ready for the old trucks home. I don't have alot of $$ so I'm trying to DIY this myself. Ny advice about what could be wrong and how to fix it would be so greatly appreciated! It's the only vehicle I've ever owned and you could say I'm attached to it!
    Peace, Peter
  2. Oct 13, 2023 at 5:34 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Does it cut out after an amount of time passes, or is it after you try to do something?
  3. Oct 13, 2023 at 5:39 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Could it be the MAF? Try unplugging it and starting it to see what it does.
  4. Oct 13, 2023 at 5:55 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Test fuel pressure
    Try cleaning MAF
    Check compression
    Lots of free/cheap tests you can do and things you can try.
  5. Oct 13, 2023 at 9:49 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    FF is a cheap starting point
    PITA to get to on MY96 2.4L
    Under intake manifold
    2 fuel line bolts
    2 bracket bolts
    my R hand was swollen from contorting to get to bolts….
    Patience is a virtue
    GL
    Let us know
  6. Oct 13, 2023 at 9:59 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    What do you have for codes?
    TnShooter likes this.
  7. Oct 15, 2023 at 9:17 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The fuel pump doesn’t run unless it sees a crank signal.
    The fact that you have changed the fuel filter and pump has thinking there may be an issue other than “fuel”.
    I’d check the truck for codes.
    See if you have any codes present and go from there.
