Fuel system treatments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco2010trd, Jul 7, 2017.
  1. Jul 7, 2017 at 1:58 PM
    taco2010trd
    taco2010trd [OP] Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Want to hear thoughts on using fuel treatments like techron or seafoam.
    Thanks
    PapaBear likes this.
  2. Jul 7, 2017 at 2:01 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    BIG fan of Seafoam.
    PapaBear and nobescare like this.
  3. Jul 7, 2017 at 2:02 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    Yes to the seafoam !!!!
  4. Jul 7, 2017 at 2:07 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Seafoam all day everyday, actually works. Personally I would purchase 2 cans, half a can in the tank, full can throughout the engine. I believe there is a TW thread of where to place it and flood the engine but I can't find it, hopefully someone has it.
  5. Jul 7, 2017 at 2:26 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So when would one need to use Seafoam?
  6. Jul 7, 2017 at 2:29 PM
    eon_blue
    Azusa, CA
    It's good to run through the fuel tank every so often for good measure, I try to do one with every oil change. If you want to use it to it's full potential, run it through the throttle body to help clear out carbon buildup. This has to be done carefully though. Running it through the fuel tank is easy and good to do to help keep the fuel lines and injectors clean.
    Techron is supposed to be legit as well from what I've read...though overpriced compared to others because it's "Chevron" I think. Lucas is a good brand, too.
    replica9000[QUOTED] and PapaBear like this.
  7. Jul 7, 2017 at 2:29 PM
    PapaBear
    Austin
    SIN CITY
    Hard idle maybe mechanically. I've used it as a maintenance but I don't do it very often. It isn't even a once a year thing, more like every 2 or 3 to keep heads clean, valves, etc. It's been tested many of times and shown real results of actually cleaning away carbon build up on runners, valves, etc.
    replica9000[QUOTED] likes this.
  8. Jul 7, 2017 at 2:49 PM
    replica9000
    2019 T4R ORP
    I'm only at 90k, engine still seems to run good.
  9. Jul 7, 2017 at 3:10 PM
    PapaBear
    Austin
    SIN CITY
    I'm at 103k, put half a can in the tank at 100k. Did a full can through everything at 50k, I'm looking to do another can through the system soon because I feel a weird idle sometimes, lots of carbon built up on the exhaust pipe.
  10. Jul 7, 2017 at 3:13 PM
    PapaBear
    Austin
    SIN CITY
    Also Seafoam Trans Tune works well for transmission and powersteering, though my power steering seems very tight, hard to move the steering wheel sometimes.
  11. Jul 7, 2017 at 3:20 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I like the lucas stuff seems like every time i put small bottle in truck runs smoother. I also have 165k miles
    Rambo54 and PapaBear like this.
  12. Jul 7, 2017 at 5:30 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I use Techron maybe once or twice per year for 10+ years. I've watched enough YouTube maintenance videos and fuel injector maintenance videos. It's a pain in the ass to clean injectors when they clog up especially if you don't have the special cleaning tool...and fuel injectors are annoyingly expensive to replace.
    Techron isn't snake oil...I've never had a problem with my injectors on any car.
    Rambo54 likes this.
  13. Jul 7, 2017 at 5:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    Redline injector cleaner, Techron and Seafoam are all safe to use items.
    But its very unlikely that most folks need to use it, or that you'll notice any difference in performance/MPG when you do.
    No harm, other than your wallet, will be done, even if the vehicle doesn't need it.
  14. Jul 7, 2017 at 5:34 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If your truck is running fine, I see no point.
    I use it for gummed up small engine fuel systems.
    If you are in the habit of leaving your truck sit for 2 years, it would be a good thing.
    Otherwise, in not going to waste the money.
    Clearwater Bill likes this.
  15. Jul 7, 2017 at 5:39 PM
    taco2010trd
    Tampa, Florida
    So I have tried the Seafoam and then I tried Techron. Techron seemed to work better. Reduced engine ping in my Taco. In doing some research I see that Techron and some of the others like Redline are detergent types of treatments while Seafoam has some oil in it and solvents. So I am now doubting Seafoam vs the Techron, Redline type of treatments.
    Just some of my thoughts.
  16. Jul 7, 2017 at 5:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do you mean ping / pre-detonation?
  17. Jul 7, 2017 at 5:41 PM
    taco2010trd
    Tampa, Florida
    Yes sorry ping. I will change
  18. Jul 7, 2017 at 5:41 PM
    PapaBear
    Austin
    SIN CITY
    It's never going to increase power/mpg, it's there to help clean it out. Rough Idle is the main reason I do it.
  19. Jul 7, 2017 at 5:44 PM
    eon_blue
    Azusa, CA
    If you're pinging when accelerating you might be looking at bad/old spark plugs
    Rambo54 likes this.
  20. Jul 7, 2017 at 5:45 PM
    taco2010trd
    Tampa, Florida
    No just recently changed.
