Fuel tank filler tube
Discussion in '1st Gen. Tacomas (1995-2004)' started by Combatman, Dec 14, 2014.
  1. Dec 14, 2014 at 7:27 AM
    Combatman
    Combatman [OP] Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    So I searched quite a bit but couldn't find anything.
    I started smelling gas after I filled up the other day, and I found it was leaking where the filler tube enters the gas tank.
    Now what I'm wondering is do I have to drop the tank to get at this (I'd really rather not as I just filled up)? Also do I need the whole filler tube or can I purchase just the "bendy" looking part of it (the parts seem hard to find)?
  2. Dec 14, 2014 at 8:02 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    My 2002 has a rubber joint joining the filler neck to the tank, held on with 2 clamps. I think you should be able to replace that part without removing the tank. The rubber is preformed, if yours is the same shape as mine, you will need to buy the part, not just buy a piece of fuel hose.
    Can you see exactly where it is leaking?
    Don
  3. Dec 14, 2014 at 11:28 AM
    Combatman
    Sioux Falls sd
    31" Wrangler tires
    Yeah it appears to be the bottom portion of the rubber that is connecting the filler tube to the tank. I'll have to look and see if it is clamped on there. I found the part for a 2000+ tacoma, but not for the older ones, so I might just buy the newer part as it's only $20
  4. Dec 14, 2014 at 1:45 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    the best way to access this is pulling the bed off, at first it seams odd to say that big it is easier then taking the tank off to do this repair.
    the bed comes off with only 4 bolts and a couple guys to lift it off. its not heavy, its just bulky to hold so get 3 guys to help you, pull the mounting bolts, wiring harness for tail lights, and unscrew the filler neck to bedside screws and it lifts right off.
    all it is is a rubber hose so you can get any radiator hose with a similar diameter and shape and cut it to size instead of a high dollar Toyota replacement part
  5. Dec 14, 2014 at 2:40 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I wouldn't trust a hose made for water in an environment of gasoline, so I would get the high-$$ replacement from Toyota.
  6. Dec 14, 2014 at 5:26 PM
    NSDON
    Don
    NS
    Gasoline and ethanol will eat water hose in no time. Plus in my 2002, the bend is such that a straight piece of hose would collapse.
    As far as removing the bed to do this, you may be right, if you have the space and the buddies to help. You will only know when you peek in there and see if you can easily access it. The 2002 has the filler pipe and 2 more rubber hoses attached to and overfill and an evap hose (i think that is what the other hose is for). Since you may only need to remove the filler hose to do this without the box removed, that may be the easiest way to do what is needed.
    Don
