Fuel tank hole repair - solved
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sand_In_My_Taco, May 29, 2024.
  1. May 29, 2024 at 8:53 PM
    Sand_In_My_Taco
    Sand_In_My_Taco [OP] Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
  2. May 29, 2024 at 8:57 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    If you have access to welding gas, maybe purge it with a CO2/AR mix or similar before trying to plastic weld it. Through the fuel filler cap, rig up a rubber or foam plug & use very mild positive pressure e.g. less than 1 PSI so it doesn't push on your patch.
  3. May 29, 2024 at 9:00 PM
    Sand_In_My_Taco
    NOR*CAL
    I think im going to fill it with water, then dry it out after. Tank is out, and I can do it in a well ventilated outdoor area.
  4. May 29, 2024 at 9:05 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    A motorcycle gas tank shop next door use to put a pipe up a running vehicle's tail pipe with the other end in the empty motorcycle gas tank to get rid of all the remaining fumes.
    soundman98 likes this.
  5. May 30, 2024 at 9:39 PM
    Sand_In_My_Taco
    NOR*CAL
    Solved
    I cut a piece of HDPE from a sheet, and trimmed it to fit snugly in the hole.
    melted the edges together.
    I then cut a long "welding rod" out of the donor sheet, and used that to slowly fill in the hole.
    Once done, I cut some wire mesh to be 3x the size of the hole, and melted it into the tank material.
    I then added a bit more filler material on top, cooled it off, then smoothed it out / compressed it down.
    Looks pretty damn good tbh, and its rock solid. Topped the tank off with fuel, and added a bottle of HEET since I filled the tank with water as a explosion deterrent (I did wipe out as much as I could).
    Not bad for less than 50$
    willie2, NewWheeler, vivid02 and 15 others like this.
  6. May 30, 2024 at 9:46 PM
    GilbertOz
    GilbertOz Driver
    CA
    Any pics?!
    RIX TUX likes this.
  7. May 30, 2024 at 9:47 PM
    Sand_In_My_Taco
    NOR*CAL
    Ill take some tomorrow when theres light out :)
    eurowner and Robnik like this.
  8. May 30, 2024 at 9:48 PM
    GilbertOz
    GilbertOz Driver
    CA
    :thumbsup:
    What did you use as a heat source for the plastic fusing/welding?
  9. May 30, 2024 at 9:50 PM
    Sand_In_My_Taco
    NOR*CAL
    cheap harbor freight plastic welder.
    Its basically a soldering iron with a different tip on it. A soldering iron would work just fine.
    shotgunbilly420 likes this.
  10. May 30, 2024 at 9:52 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Congrats! Hope it holds up. Friggin' tweakers.
  11. May 30, 2024 at 9:54 PM
    Sand_In_My_Taco
    NOR*CAL
    I fully expect any other part of the tank to fail. This is quite solid.
    MarX likes this.
  12. May 30, 2024 at 9:55 PM
    Robnik
    Rob
    Greenacres, Florida
  13. May 31, 2024 at 10:13 AM
    Toycoma2021
    Would definitely like to see pictures of this repair. There have been in the past a few items in plastic I would have liked to repair/resurrect.
  14. May 31, 2024 at 10:28 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Thank you for the update and glad you were successful with the repair, looking forward to the pictures!
  15. May 31, 2024 at 11:21 PM
    #35
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Jbweld tank weld?
  16. May 31, 2024 at 11:27 PM
    #36
    Sand_In_My_Taco
    NOR*CAL
    Only works temporarily as the plastic expands/contracts at different rates and will eventually leak.
    vivid02 likes this.
  17. May 31, 2024 at 11:32 PM
    #37
    GilbertOz
    GilbertOz Driver
    CA
  18. May 31, 2024 at 11:35 PM
    #38
    Sand_In_My_Taco
    NOR*CAL
    I'm bad and I feel bad.
    Oh... This is a whole ass story btw.
    I went to return the tank, because it was incorrect. No ones fault, it just wasn't the correct tank. The salesman started yelling at me, calling me a liar and that it's the right tank. Dude went off the deep end completely. Told me I was making up the Toyota part numbers, they didn't exist, and all 3rd gens have the same tank.
    Absolutely wild. I would advise everyone stay away from Toyotamart in Sacramento. Dude there has serious issues lol.
    For the first time in my life, I left a negative review. Nothing outlandish, just a "hey this happened it's not cool" and the dude starts calling me from his personal phone.
    I'll get pics tomorrow, promise! Today was just too busy to do it.
  19. May 31, 2024 at 11:51 PM
    #39
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Yikes, go to return the thing like a human being and get barked at..WTF. Seems to me you would have rather the new one fit, used that, and called it a day.
    Jeez, IIRC my 1979 Mustang could have used more than one kind of tank. Pretty sure my 1984 Olds Delta 88 did..only 2 vehicles I've had to deal with this part on. Not out of the question for anything else IMO
  20. May 31, 2024 at 11:53 PM
    #40
    Sand_In_My_Taco
    NOR*CAL
    Yeah no idea, dude just paused for a few seconds then exploded like it was some hit to his pride. Looking at the reviews of the place there are others that have had this issue as well.
    oldtimertoyota and Steves104x4 like this.
