Fuel Tank Overfilling
Discussion in 'Technical Chat' started by RaidenDSI, Feb 2, 2012.
  1. Feb 2, 2012 at 1:32 PM
    RaidenDSI
    RaidenDSI [OP] Member
    Lincoln, NE
    2009 Toyota Tacoma SR5 4x4
    My fuel tank overflows for some reason. I tried filling it on the slow setting and on the fast setting. I also tried several different gas stations(all different brands) and it's all the same. I can't see anything in or around the fuel neck that would indicate a problem. Can anyone suggest anything? Thanks.
  2. Feb 9, 2012 at 11:58 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Bump! but I believe most fuel tanks have a small return line to "tell" the pump hey I am full, by creating a loop. I would try and see if yours is loose/broken.
    Where is Chris4x4???
  3. Feb 10, 2012 at 5:17 AM
    RaidenDSI
    Lincoln, NE
    I would like to check that out. Is there anywhere I can get a drawing of the fuel tank system?
  4. Feb 10, 2012 at 12:31 PM
    RaidenDSI
    Lincoln, NE
    Thank you for that PDF. It's very helpful and what I was looking for. I will check the valve for anything abnormal.
    I don't understand how the refueling valve works with the fuel tank system. If you could please explain it to me I would greatly appreciate it.
  5. Oct 3, 2014 at 9:12 AM
    malay4785
    malay4785 Well-Known Member
    Malay
    New Jersey
    2012 SW Double Cab
    I am having the same problem. The auto shutoff on the gas pump doesnt turn off until the fuel is right at the top of the tank, and then overflows. did you find out what the problem was?
  6. Oct 3, 2014 at 10:23 AM
    RaidenDSI
    Lincoln, NE
    I did not but the guy I sold the truck to did. He said the problem was the pressure regulator or whatever its called. He said its a plastic piece that is supposed to be installed in the tank neck area where you slide the fuel pump into.
    Anyway, once a new one was installed the problem went away. I would go to the dealer or a mechanic and maybe have them inspect yours or ask for a drawing and see if you could figure out what may be causing your problem. Most likely there is something wrong with a component in that area.
    I don't know what it's called or what it looks like. He just told what it was.
    Sorry I can't be of anymore help.
