Fuel Tank..Pump...etc
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cland75, Aug 7, 2022.
  1. Aug 7, 2022 at 12:36 PM
    Cland75
    Cland75 [OP] Well-Known Member
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Does anyone know the years that the fuel tank assembly (inside an outside) on the 1st Gen 4cyl 2.7L would be compatible with a 1999?
  2. Aug 9, 2022 at 6:47 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just what are you looking for the complete fuel tank with fuel pump bracket?
    Just the fuel pump bracket and pump??
    It depends just what size fuel tank you have if my over heated brain remembers the difference is in the length from the top to the bottom of the bracket.
  3. Aug 9, 2022 at 7:22 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    You have the larger 18 gallon tank. The smaller 15 gallon tank came on 5lug 2wd trucks. All tanks from 1995.5 to 2000 will fit. The tank design was changed in 2001 when the evap can was moved out from under the hood.
    Bivouac likes this.
