Fuel the Fire, or Stay the Filter?
Discussion in 'Performance and Tuning' started by Torspd, Sep 3, 2017.
  1. Oct 3, 2017 at 11:40 AM
    #41
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am getting my fuel pump & pulley installed tomorrow! Will it be possible to disassemble the stock pump from the filter to see how bad it is in there?
  2. Oct 3, 2017 at 12:31 PM
    #42
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Stock pump will slide out from the filter which shrouds it. Then cut the filter open.
    Murphinator and inwood customs like this.
  3. Oct 4, 2017 at 11:07 AM
    #43
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Did anyone buy a new snapring for the fuel tank? Dealer is saying it should be replaced rather than reused..I told them if they can get it today to get a new one but if not reuse the old one. Anyone ever have any issues reusing it? I know I should make a new thread but I figured more people here have probably done the pump swap and will see it.
  4. Oct 4, 2017 at 1:17 PM
    #44
    Torspd
    Tor
    The Great America!
    Upgraded my pump three different times. Haven't used but the original ring and o-ring.
    Murphinator likes this.
  5. Oct 8, 2017 at 9:17 AM
    #45
    reedbrynn14
    reedbrynn14 Well-Known Member
    2014 TRD Tacoma
    supercharged, icon stage 2, rock sliders, 255/85-16
    Correct me if I'm wrong but the Walbro GSS342 is the unit that'll work in 2nd generation correct?
  6. Oct 8, 2017 at 10:03 AM
    #46
    Torspd
    Tor
    The Great America!
    Yes. It is not a direct drop in though. You will need about 6" of submersible fuel hose, and a stainless zip tie.
    If you want to additionally install the external fuel filter, look to the part numbers earlier in this thread.
  7. Oct 8, 2017 at 11:01 AM
    #47
    reedbrynn14
    2014 TRD Tacoma
    Cool, thanks. I have an Aeromotive 10 micron filter with a ball valve that'll go on as well. Not a big fan of hose clamps so AN stuff will be utilized.
  8. Nov 3, 2017 at 8:15 AM
    #48
    Torspd
    Tor
    The Great America!
  9. Nov 3, 2017 at 8:36 AM
    #49
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Sorry to be a bother on this but as an owner of a non supercharged 2nd gen is this is still a worthy upgrade? thanks
  10. Nov 3, 2017 at 9:56 AM
    #50
    Torspd
    Tor
    The Great America!
    Does the fuel filter get clogged?
  11. Nov 3, 2017 at 10:07 AM
    #51
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    What if you were to pull the screen off the OEM pump, and put an external filter on. Would there be any repercussion from have the pump unprotected?
  12. Nov 3, 2017 at 10:12 AM
    #52
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
  13. Nov 3, 2017 at 10:15 AM
    #53
    Torspd
    Tor
    The Great America!
    That is otherwise known as the "sock." Its only purpose is to protect the pump. Not the injectors. You still need to remove the OEM filter and replace it with an external one.
  14. Nov 3, 2017 at 10:15 AM
    #54
    Torspd
    Tor
    The Great America!
  15. Nov 3, 2017 at 10:19 AM
    #55
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Have any idea what flow and pressure OEM pump is rated at?
  16. Nov 3, 2017 at 11:19 AM
    #56
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    About what part?
    I havent gotten a reply from denso corp.
    Denso usa was unable to give info due to contract.
    If thats what u was ferrin to?
  17. Nov 3, 2017 at 11:31 AM
    #57
    Torspd
    Tor
    The Great America!
    ~100-103 LPH. The factory system uses 43.5 psi. *Note*(As referenced from Delphi's OEM replacement.)
  18. Nov 3, 2017 at 11:38 AM
    #58
    Torspd
    Tor
    The Great America!
    For N/A use .5 to .6 BSFC (Brake Specific Fuel Consumption).
    For F/I use .6 to .75 BSFC
    Optimal LPH = (Max HP x BSFC)/ 1.585
    This formula, will calculate the flow requirements for Engine HP.
    Pretty quickly you'll see that the OEM pump is out of its flow capacity, at 300 brake HP.
    Biscuits likes this.
  19. Nov 3, 2017 at 11:40 AM
    #59
    inwood customs
    Dave
    Oh shit, you went there
    GilbertOz and Sterdog like this.
  20. Nov 3, 2017 at 11:47 AM
    #60
    Torspd
    Tor
    The Great America!
