Fuel to air short?
Discussion in 'Technical Chat' started by RJALLDAY702, Feb 22, 2012.
  1. Feb 22, 2012 at 3:28 PM
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    So after my ocotillo trip. My check engine light came on, and I went to Toyota to get it scanned, and they said its a short in the fuel to air component? Like $400 to replace.. Anyone know what this is?
  2. Feb 22, 2012 at 3:31 PM
    Aw9d
    Aw9d That one guy
    Az
    Did they give you a bottle of lube with that diagnostic?
  3. Feb 22, 2012 at 3:34 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Code #p0031
    Yeah I thought they meant the MAF.. He said it wasn't.. Air fuel sensor? I am confused
  4. Feb 22, 2012 at 3:34 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    I'm gunna go home and clean the shit out of everything..
  5. Feb 22, 2012 at 3:35 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Just got back in it and the check engine light is off? Maybe they reset it or something
  6. Feb 22, 2012 at 3:54 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
  7. Feb 22, 2012 at 3:55 PM
    Aw9d
    Aw9d That one guy
    Az
    They might have reset it. Take it to autozone/checkers/ and they can scan it for free, then google that code and see..
  8. Feb 22, 2012 at 3:56 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    Maybe a google search will come up with something... If you need a part replaced ... dont buy it from your local stealership... I bet you can get it off of eBay wayy cheaper than $400.
    gl
  9. Feb 22, 2012 at 3:56 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    Damn lol
  10. Feb 22, 2012 at 6:23 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Bump for any more info?
  11. Feb 22, 2012 at 11:30 PM
    Rmesa1
    Rmesa1 Well-Known Member
    Possibly talking about the air/fuel ratio sensor did they give you a code#
  12. Feb 23, 2012 at 12:16 AM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
  13. Feb 23, 2012 at 3:58 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    I would start by cleaning your Mass Air Flow sensor and looking at the AFR sensor
    If you have to buy the AFR sensor you can get it for half of what the stealership wants and you can change it out yourself
    I am not familiar with your vehicle but the sensor should be located near your front catalytic converter
  14. Feb 23, 2012 at 6:50 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
  15. Feb 23, 2012 at 7:05 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Maybe you just got some dirt in the connector and it shorted, Had something very similiar happen to a component on our airplane the other but it was fuel instead of dirt lol. once it was clean it worked fine. if it pops again maybe replace the O2 sensor?
  16. Feb 23, 2012 at 7:14 AM
    Rmesa1
    P0031 is heater circut low the ecu is not seeing and amperage to the af sensor heater circut. if you have an ohm meter unplug the sensor and check resistance across the two black wires should be around 13-18ohms if it is out of limits or a really high reading you need a new a/f sensor.
  17. Feb 23, 2012 at 8:49 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    The AF sensor is in the exhaust. Its the same as an 02 sensor, just runs of different voltages.
    The heater side of the circuit is not the side that reads Air fuel ratios. It is the side that heats up the sensor so it can read more accurately.
    This guy has the right idea, I don't know if those are the correct values though.
  18. Feb 23, 2012 at 9:10 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Hmmm.. I wish I knew how to fix this myself
  19. Feb 23, 2012 at 11:16 PM
    Rmesa1
    Just double checked the repair manual online Fractured is right just looked up the spec in the manual 1.8 to 3.4 ohms 13 to 18 is for an O2 sensor thats what I get for qouting values off the top of my
    head. If you need help shoot me a pm if you can come down to lake forest maybe we can work it out.
  20. Feb 29, 2012 at 5:06 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Alright, it ended up being 2 cooked fuel to air sensors.. Toyota wanted 350 for one.. but i got two done at a local shop for $500. Just drove it home.. and.. OMFG. you can literarily feel the power and the clean-ness of it.. I was loosing a lot of power because of this. can almost hit the rev line just progressively pushing on the pedal.
    Cant wait to see how much of a difference it makes in gas milage
