Fuel Trophy D551
Discussion in 'Wheels & Tires' started by snorinlorin, Mar 17, 2014.
  1. Mar 17, 2014 at 1:50 PM
    snorinlorin
    snorinlorin [OP] Snorinlorin
    Maine
    2011 TRD Sport Dbl cab
    Laradoe tonneu cover,Weather tech window vents/ floor mats, OME 3 inch lift / AAL., Light Racing UCA's, Painted engine cover, Avid off-road step tubes,Cross Fab light bar,Hella black magic lights,Satoshi grille, Trophy D-551 wheels,285/70/17 Duratracs
  2. May 24, 2014 at 9:08 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    What did you wrap them in?
  3. May 24, 2014 at 3:20 PM
    huli467
    huli467 Turning Octopus
    Honolulu
    2015 TRD Sport 4x4
    The world is big...and I want to have a good look at it...before it gets dark - John Muir
    What size did you go with? I have a set and the powder coating of paint is peeling just after a year. I hope you have better results.
  4. May 24, 2014 at 3:36 PM
    ThomasMore66
    Ugh! I was ready to buy them today but the store was closed. Pealing.
  5. May 24, 2014 at 8:23 PM
    huli467
    Honolulu
    2015 TRD Sport 4x4
    Here you go:
  6. May 24, 2014 at 8:46 PM
    ThomasMore66
    Warrantee?
  7. May 25, 2014 at 3:44 AM
    snorinlorin
    Maine
    I mounted 285/70/17 BFG Rugged Terrains on the wheels.
  8. May 25, 2014 at 3:49 AM
    snorinlorin
    Maine
    Oh wow that pealing sucks! I hope I have better luck. But if I don't, there is an implied warrantee law in this state I'll try that route. If that doesn't work, I have a paint guy
