Fuel Type (Premium 91 - regular 87) of the tacoma, please help from experts???
Discussion in '1st Gen. Tacomas (1995-2004)' started by aoooz, Apr 8, 2012.
  1. Apr 8, 2012 at 1:25 AM
    aoooz
    aoooz [OP] Member
    texas-denton
    97 doubal cab 4 cylender
    Hello my friends
    I am a new member and hope to be active here in this wonderful forum
    I want to ask about the type of fuel?? My car is
    Toyota tacoma 4 cyl (2.7) (Carburetor)
    I have a question important to me?
    What type of fuel that is supposed to be used (unfortunately I lost the owner's manual) I use these days, 91 Premium (previously I was using regular 87 but my friend advised me to switch to 91 Premium I do not know why he says it's prolongs engine life is longer with 91???
    And performance be better????
    Frankly did not
    Notice an improvement in performance
    The engine compression ratio is (9.5)
    So please what am I supposed to use (91 Premium
    Or 87 regular)
    my brother took my car and he put the 87 fuel !!??( in side the trunk was a 91 !!!!! ) it's be come mixed !!!!
    Is the fuel mix (87 and 91) harms the car??
    pleeeeeeas ! Please I am in the most puzzling ????
    thanks in advance for help me
  2. Apr 8, 2012 at 2:51 AM
    aoooz
    aoooz [OP] Member
    texas-denton
    thank you very much !! you relaxed me ??
    OK I'll do what you told me I think i well come back to 87 ??
    But what should I do (I mean convert between 91 to 87) Is there a right way to do that??? Without damage??
    thank you Again Sir !
  3. Apr 8, 2012 at 3:27 AM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I would run 87 octane in that truck from now on. You are not going to gain anything by running higher octane.
    As for mixing octane levels of 87 octane and 91 octane, the fuel manufactures do this all the time and they call it 89 octane. So don't worry about mixing the octane levels.
  4. Apr 8, 2012 at 4:50 AM
    aoooz
    aoooz [OP] Member
    texas-denton
    thank you killer ) nice nakename(
    you relaxed me too ! I was worried that the engine harmed
    thank you guys all of you
    Have nice day
  5. Apr 8, 2012 at 8:12 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Running 91 will do absolutely nothing for your truck in terms of performance or longevity/durability.
    If anything, it might hurt your mpg.
    Run 87 and you're golden
  6. Apr 8, 2012 at 8:29 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Mixing the two (91 and 87) just makes it 89! (if 50-50)
    I had have 3 tacomas 2001-2010 models, and they were all V-6's... and used 87 both here and in Mexico... with no problem (All 3 were recommended 87 in their owner's manuals, too).
    Higher octane gasoline is just one with a lower detonation, for higher compression engines that would 'ping' with excelleration, on Regular grade gas (87). This was back 'in the day' before electronic ignition and ecu controlled motors.
    I believe the newer engines have automatic anti-ping (knock) systems... so you can use the lowerst octane recommended (87)... and putting higher priced gas has no affect accept on lowering the money in you wallet, faster.
  7. Apr 8, 2012 at 9:35 AM
    aoooz
    aoooz [OP] Member
    texas-denton
    Madjik_Man
    David K
    Thanks for the advice
    So no problem With performance when using the regular 87
    OK I will start using 87 regular
    But what is supposed to do (I mean there is in the fuel tank 91 Premium) What should I do? Do emptied the tank and then put 87 or Mix together??
  8. Apr 8, 2012 at 9:40 AM
    David K
    As I said, if you mix a higher octane with a lower... you will just average the two... No worries... Your truck (or at least the new ones) will automatically adjust timing if it is about to ping (knock), so it won't... But that is only extreme high compression, extreme high temperatures and poor/ low octane quality gas.
    You are fine... The truck will let you know if it isn't happy.
  9. Apr 8, 2012 at 9:42 AM
    Madjik_Man
    Boulder, CO
    Don't worry about it. Go through the tank as you normally would (driving it).
  10. Apr 8, 2012 at 11:22 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    :confused:
  11. Apr 8, 2012 at 11:23 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    English second language?
  12. Apr 8, 2012 at 11:29 AM
    TacoMX
    Jonathan
    Deltona, Florida
    no...he said its carbureted....Yotas haven't been carbureted since 1984-1987 with the 22R
  13. Apr 8, 2012 at 11:54 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Could be an export model.
    All kinds of oddball shit outside of the US.
    Encountered a guy with a '97 Suburban that still had the pre-'96 5.7 TBI engine. The engine and interior parts were a mix of '97 and earlier parts... and it was not a Frankenbuild, he was the original owner and brought the truck with him when he moved here from, IIRC, Panama.
  14. Apr 8, 2012 at 2:27 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Truck was designed for 87. use 87
  15. Apr 8, 2012 at 4:53 PM
    Midnight Drifter
    Midnight Drifter Well-Known Member
    Anthony
    Monroe Twp, NJ
    2TR W/T
    Flowmaster dual exhaust
    Why the hell did you convert to carb'd?
  16. Apr 8, 2012 at 5:27 PM
    worthywads
    You think someone afraid to mix 87 with 91 converted to a carburetor? Probably has no idea.
  17. Apr 8, 2012 at 7:14 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I am SOOOO confused! Toyota stopped making carbies back in the 80s. I also checked on wikipedia and the only 2.7L Toyota petrol motor made to that date was the 3RZ-FE, which as we all know, is injected. So I'm not sure how to go about this.
    Maybe if OP clarified?
  18. Apr 8, 2012 at 8:19 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I is confused too :confused:
