Fuel Type Used...
Discussion in '3rd Gen. Tacomas (2016+)' started by Shikokaon, Oct 11, 2017.
What Grade Fuel do you use???
  1. Premium
    34 vote(s)
    18.1%
  2. Plus/Mid
    20 vote(s)
    10.6%
  3. Regular
    134 vote(s)
    71.3%
  1. Oct 11, 2017 at 10:11 PM
    Shikokaon
    Shikokaon [OP] Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Ever since I got my rig i had been using Chevron Premium... Last 3 tanks decided maybe it was overkill and changed to Regular...
    Engine pings/knocks even while taking off during normal acceleration...
    Figured it was just computer not "used" to it, so tried for 3 tanks, to see if it'd adjust...
    No luck, so filled with Mid/Plus today and it seems to have gone mostly back to normal (no ping/knocking)...
    Anybody else have similar issue???
  2. Oct 11, 2017 at 10:14 PM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    regular 4 lyfe! im too cheap for that other shit! never any issues for me... the sportster likes the 93 thought...
    perhaps pull the battery and ground out the hot leg so it dumps the computer then start over?
    Roland79 and Shikokaon [OP] like this.
  3. Oct 11, 2017 at 10:19 PM
    2005 TRD Sport
    2005 TRD Sport Well-Known Member
    NM
    17 Black LTD
    Chrome step tubes, bed extender
    I stick with 87 if I can get it in the desert SW, 88 if I can’t. No issues. I used 86 on her maiden voyage, but I prefer not to try again.
    Shikokaon [OP] likes this.
  4. Oct 11, 2017 at 10:21 PM
    Roland79
    Roland79 Well-Known Member
    Dave
    Missouri
    2017 TRD Off Road DCLB Black
    93 is all I will feed my truck. I’ve never filled it with anything else, and probably won’t.
    I’ve seen and read to many other threads about knocking and pinging with lower quality gas. I’m probably overdoing it/overpaying , but I’m fine with that.
  5. Oct 11, 2017 at 10:23 PM
    Shikokaon
    Portland, OR
    Hhhmmm, didnt think of that. Figured it'd computer would learn within a tank or two...
    Will def try again next tank to see...
    Another thing i noticed is that MPG went to shit with Regular, but it could be cause of the timing being "off"...
  6. Oct 11, 2017 at 10:50 PM
    Oldman808
    Oldman808 Powered by Mosconi !!
    O'ahu
    2016 TRD Sport DCSB
    Clazzio Black Leather Seat Covers Roll N Lock M-Series Tonneau Cover Customcargrills Unholey vent mount Oem mud flaps AVS in channel ventvisors Oem bed mat Mosconi 1000.1D Mosconi 60.6 AB JL 10TW3-D8 X 2 tuned to 31.33 Kenwood DMX7704S
    I use 89 non ethanol pure gas and it’s the ftw for the taco imho ! Runs great , and I get 24.5 - 25 mpg on every fill up.
    Was using 87 e-10 for the first 10k miles and was getting 22 mpg but my truck didn’t run as well as it does now. The pure 89 cost the same as the corn fed premium but my taco is happy without the corn.
    :mudding:
    inksin, 9th and Roland79 like this.
  7. Oct 11, 2017 at 10:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    2017 MGM DCSB Off Road, 6 Speed MT
    When I fuel up with 87 the Dash says 365 Miles to Empty, when I fuel up with 93 the Dash says 395 Miles to Empty.
    opentang, Roland79 and Oldman808 like this.
  8. Oct 11, 2017 at 11:02 PM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    In AZ we only seem to have lo and hi... When I run lo, I get the spark knock. I run the hi unless I'm filling up with around half tank, then I go lo.
    rjbiii and shakerhood like this.
  9. Oct 11, 2017 at 11:26 PM
    JARStacoma
    JARStacoma Well-Known Member
    Seward Alaska
    17' inferno TRD OR MT
    Can anyone describe to me the "pinging" noise. Dont think I have heard it. Haven't ran 87 yet. Mostly 90. I however have been thinking of switching. Is this a noise that I would notice? What exactly is causing the pinging? Thanks.
  10. Oct 11, 2017 at 11:28 PM
    Mike_Lowrey562
    Mike_Lowrey562 Well-Known Member
    Long Beach, CA
    2016 TRD OR MGM
    I’ve always used regular for the Tacoma and I haven’t had any issues..
    over60 and Jukeboxx13 like this.
  11. Oct 11, 2017 at 11:43 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    i was using 92 during breakin
    then switched to 87 and noticed some ping going up hill
    with low rpm. noticed that stop after about the 2nd or 3rd tank.
    i wonder if the computor adjusted for it?
  12. Oct 11, 2017 at 11:56 PM
    9th
    9th are those biscuits I smell?
    Smitty
    Tropic of Cancer
    2017 4x4 Tacoma
    I use gasoline...Not that GMO corn BULLSHIT.
    bertle, opentang, tonered and 2 others like this.
  13. Oct 12, 2017 at 12:19 AM
    Facts Only
    Facts Only Well-Known Member
    State Of Jefferson
    17 TRDOR DCLB Quicksand
    Are you guys sure its pinging your hearing? I'd be very surprised if its in fact pinging your hearing.
    I've used regular (87) from new and have heard nothing remotely sounding like pinging/knocking.
    over60, Jukeboxx13, Skidog1 and 2 others like this.
  14. Oct 12, 2017 at 1:24 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Personally I doubt it's knocking and pinging you are hearing, if it is then your motor is screwed already cause by the time you can actually hear it, the damage is being done. The knock sensors pick it up WAY before any ear can hear it and retards the timing enough to stop the ping
    Jukeboxx13 likes this.
  15. Oct 12, 2017 at 1:29 AM
    david-oregon2999
    david-oregon2999 Well-Known Member
    I follow the book. Unleaded regular, top-tier. I try to keep mostly non-ethanol gas in it, but will throw in a tank of the usual stuff when I must.
  16. Oct 12, 2017 at 4:43 AM
    froejoe
    froejoe Well-Known Member
    Rochester NY
    2016 TRD Sport 4x4 Access Cab
    I run ethanol-free whenever possible because I don't drive that many miles and have a hard time burning a single tank of gas in a month. I want to avoid moisture build-up in the tank and don't like measuring additives. I run the premium variety because most of the gas stations around here that offer ethanol-free only offer it in premium not regular. Hell, I use premium, ethanol-free in my lawn mower. LOL
  17. Oct 12, 2017 at 5:41 AM
    Skidog1
    Skidog1 Well-Known Member
    2016 Black TRD 4x4 Sport DCLB
    Toyota engineer says- "You can use Top Tier 87". Me- "ok".
  18. Oct 12, 2017 at 5:44 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  19. Oct 12, 2017 at 5:47 AM
    rjbiii
    rjbiii Savvy?
    Robert
    TX
    '09 6T8 ACLB 5spd PreRunner & '13 3R3 DCSB 6spd 4x4
    '09 hard taco & '13 soft taco
    My gen 2 DCSB 6spd did this whenever there were gas runs in tx and all you could find was regular. I also switched back to shell premium and the pinging has gone away for me as well. I avoid Valero gas stations like the plague now :bikewheelie:
  20. Oct 12, 2017 at 6:00 AM
    whitewolf001
    whitewolf001 Well-Known Member
    TN
    2017 8T0 Tacoma TRD Off-Road
    :rofl:
    Bulldogs129 and rjbiii like this.
