Fuel vapor smell
Discussion in '1st Gen. Tacomas (1995-2004)' started by jimbobaja, Mar 26, 2017.
  1. Mar 26, 2017 at 4:10 PM
    jimbobaja
    jimbobaja [OP] Member
    jim
    Walnut Creek, Ca.
    98 SR5 Xtracab 133k ret. land survey work tru
    OME frt. & rr springs & shocks
    '98 Taco w/ 3.4 just developed fuel smell w/i engine bay, sucked into cab w/ outside air vent open. No visible leaks. Injector O-rings 4 yrs. old. Gas cap 2 yrs. old. Need general guideline of things to check. I have FSM, but not familiar w/ fuel issues.
    Also, do I need to get adapters and gauge to check fuel pressure? Never checked it before for bad Regulator. My '05 Lexus GX 470 never checked before too.
    As always, greatly appreciate guidance as do all my own work.
    Thanks! Jim
  2. Mar 27, 2017 at 7:40 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Are you getting a check engine light?
  3. Mar 27, 2017 at 8:10 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    could be a bad fuel pressure regulator seeping fuel into the air box
  4. Mar 27, 2017 at 8:14 PM
    CodeSeven
    Serge.
    Coachella Valley
    never heard of the flexplate falling off...... I was going to chalk it up as a bad alternator that couldn't power the motor after the battery was so dead it wouldn't power/start the engine.
  5. Mar 27, 2017 at 8:24 PM
    jimbobaja
    jim
    Walnut Creek, Ca.
    No check engine light. I will pull any codes tomorrow. I know, should have done that first, will let you know.
    I was going to get a fuel pressure testing adapter and gauge online, but won't ship to Calif. Assume CARB doesn't want us messing w/ raw fuel spillage. Have to do more research.
    Was also going to check charcoal Canister and EVAP valves.
    Any other suggestions? Any guidance appreciated, smell very strong and worrisome. Won't drive 'til diagnosed and fixed.
  6. Mar 28, 2017 at 2:42 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sorry to hear about that. I guess it's time consuming, but I'd go through the whole fuel system looking for cracks / breaks in the lines and sniff the whole way along it.
    Aside, I see you're from Walnut Creek - I had a friend from Alamo when I was living in San Luis Obispo - you're in a nice place. :)
  7. Mar 28, 2017 at 7:21 AM
    jimbobaja
    jim
    Walnut Creek, Ca.
    Thanks Logger, CodeSeven and Dalandser for assistance, much appreciated! Will go over everything and "sniff" it out, as it were. Found an old CPAP headset and hose to use for locating source of leak.
    Always being approached to buy the Taco, but can't/won't part w/ it. Also have an '02 Ford F-350 Crewcab Lariat 4x4 Diesel w/ Banks that everyone wants to buy too.
    Will keep you posted on diagnosis and solution.
    Thanks again. Yikes, today's my 73rd B-Day. Never thought I'd make it this far. Go figure.
    PS Grew up here in "Nut" town, but it's REALLY changed, not my kinda place anymore. Tiffany's, Neiman Marcus etc. just not us. Called Rodeo Drive of the north and that's sure not me. Love us the Four Corners area. Thought when kid's raised and gone would move but then grandkids happened and now greatgrandkids, well, it's all over for the move. Tough living in Calif., changed radically if you get my drift.
    Dalandser likes this.
  8. Mar 28, 2017 at 8:47 AM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Interesting, Mine was doing this awhile back as well. I never wound up figuring out the issue and the smell just kind of, went away. It was producing a bit of drip from the exhaust at that time as well.
    Sorry i can't be of any help but i hope you get it squared away. Interested to see what the cause is.
  9. Mar 28, 2017 at 12:36 PM
    jimbobaja
    jim
    Walnut Creek, Ca.
    CPAP sniffer unit worked great. Banjo bolts at front fuel cross-over pipe were not snugged to req'd. torque of 25 ft-lbf, so tightened them ( 2 ) and all's good. I'd had these off 4 yrs. ago during major service, but pretty sure torqued them up and, of course, used new washers. No visible fuel and passes the CPAP sniffer test. 25 ft-lbf pretty good torque so hard to imagine heat
    cycles and/or vibration loosening them up, but there you are. They were about 5 to 10ft-lbf torque. It had been 6K miles and 4 yrs since last work done.
    Thanks again for all helpful input!
    Dalandser and erice like this.
  10. Apr 16, 2017 at 8:34 PM
    jimbobaja
    jim
    Walnut Creek, Ca.
    Up-date on fuel vapor smell issue. Took air chambers off and found leak at top of fuel injector at the fuel rail. Had changed all o-rings 4 yrs. ago so don't know what happened. Awaiting new seals and will do it again and see if I can determine cause. Will further up-date then.
  11. Apr 16, 2017 at 8:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Glad you found what was going on. Who installed the o-rings? Was he worth his hourly rate? ;) (Joking, if it was you, know that job's high above my paygrade at the moment :))
