Fueling issues
Discussion in 'South East' started by Shander, Feb 23, 2011.
  1. Feb 23, 2011 at 6:17 PM
    Shander
    Shander [OP] Member
    Shannon
    South Carolina
    2010 TRD 4WD
    Hi everyone. Hopefully someone can help with this issue. I have a 2010 crew cab 4wd tacoma. Ever since I bought this truck I have had a problem fueling it up. I try to lock the handle so I don't have to hold the nozzle and it runs for less than 2 seconds and shuts off. So then I have to hold the nozzle and even then it keeps shutting off. I end up pumping fuel so slow that it takes forever.
    Does anyone have any suggestions as to what this might be. I know I will end up taking it back to the dealership... but being female I just didn't want to look completely ignorant.
    Thanks for all of your help.:p
  2. Feb 23, 2011 at 8:48 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Change gas stations... or report the problem fueling to the station or EPA board (state or federal?)... At least here in coastal California we have vapor recovery devices on the nozzles, and if you have to keep removing the nozzle and re-inserting it to fill up, there is a problem... and it is not with the Tacoma... I fill up hands free every time.
  3. Feb 24, 2011 at 4:07 AM
    Big Frank
    Big Frank Member
    Columbia, SC
    09 Taco TRD
    Icon 2.5" Coil overs, Icon Upper Control Arms, AFE stage 2 intake, Flow master exhaust, 285/75 Pro comp X-Terrains, Bilstien Shocks, SS Brake Lines, JVC Kameleon Head Unit, Wet Okole Camo Seat Covers
    dont stick the nozzle in all the way. push it in and start filling when it shuts off pull the nozzle out a little and try again.my truck does the same thing
  4. Feb 24, 2011 at 4:41 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1
  5. Feb 24, 2011 at 6:32 AM
    tquang
    tquang mytacoma
    mytacoma
    San Dimas, S.Ca
    PreRunner SR5
    Try to Used different pump or go to another station, If you still have the same problem then ORVR system in your tank not working
  6. Feb 24, 2011 at 3:23 PM
    Shander
    Shander [OP] Member
    Shannon
    South Carolina
    2010 TRD 4WD
    Thanks for the info.... this happens at every gas station I go to. And I have tried everything from pulling the nozzle out a little bit to turning it upside down. I can at least go to the dealership now and tell them it could be the ORVR system.... what ever that is...
    thanks everyone, I appreciate your help.
