Fuelly - not just another mileage thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoSter, Jul 28, 2009.
  1. Sep 11, 2009 at 7:00 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    decided to add mine too.
  2. Sep 11, 2009 at 7:09 AM
    danb86
    danb86 East Ender
    Dan
    Long Island, NY
    2010 I4 Access Cab 4x4
    I'm in...
  3. Sep 11, 2009 at 7:29 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My mileage sucks wtf? I suppose its the luck of the draw, I notice some 4 cylinders getting just slightly better mpg than the 6's.
    Those of you with larger tires, have you adjusted your numbers for your tires?
  4. Sep 12, 2009 at 4:42 PM
    TacoSter
    TacoSter [OP] Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
    Maybe experts could chime in. It's a given that a lift & tires causes lower mileage... I do not think it's as bad as it seems.... with larger tires it throws your speedometer & odometer off so it does not register correct.
    Click on the link below... It lets you compare specs on the stock tire vs 285 or whatever your running.. I think 285's throw the speedo off about 7%
  5. Sep 12, 2009 at 7:03 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    When I add my mileage it is already corrected for my tires and such. Now my indicator in my sig it says 19+mpg average but if you click it and look at the fuelly site it says 16+ is my average I have not gotten 19mpg since I joined Fuelly. Odd.
  6. Sep 12, 2009 at 7:39 PM
    TacoSter
    Chicago Burbs
    Does fuelly have a setting for oversize tires?
  7. Sep 12, 2009 at 8:58 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    No sir, I have always kept a close eye on my mileage. When I got the tires I did the homework. So through. I originally had tires smaller than what the computer was calibrated for, so the increase isn't as large as the tire calculators thought. So I adjusted for that then realized my 33" tires only measure 32.4" so i also adjusted for that. I am 2.7mph above what my stock speedo reads. I multiply my trip miles times 1.033 to adjust for my tires then punch that result into fuelly. What I don't get is why fuelly insist I make an average of 19mpg when I have never gotten in my last 3 fuel ups above 17.6mpg. I mean a 17.6, 16.2, and a 15.1 don't average 19, unless I am all screwed up.
  8. Sep 14, 2009 at 3:28 PM
    TacoSter
    Chicago Burbs
    :confused: I think fuelly screwed up on the average. your 3 fill ups total 48.9 then divide that by 3 = 16.3 should be your average. I checked the math on my fuelly and it's right where it should be.
    The only thing I can see is on my 11 fill up's the first input was "0" cause it has nothing to base itself from until the 2nd fill up. On yours it has an mpg on the 1st time??
  9. Sep 14, 2009 at 4:34 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i signed up, but i dont have any data yet.
  10. Sep 14, 2009 at 4:36 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Entered all my info the other day but forgot to adjust for larger tires. Doing it now...
    Actually, I'm not quite sure how I would do that with Fuelly since it doesn't have a spot for actual mileage.
  11. Sep 14, 2009 at 4:43 PM
    TacoSter
    Chicago Burbs
    Question... Is there any way to calibrate the Speedo/ odometer for the tires? After my stock tires take a crap, I wanna upsize
    Strange.. when I go to add fuel ups, it lets me input the odometer. I gave up on the trip meter for mileage tracking because they do not need it
  12. Sep 14, 2009 at 4:46 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I have 20's & did not adjust for the tires. But I also drive 80-85mph(with the flow of traffic) on the highway to & from work.
  13. Sep 14, 2009 at 4:50 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I believe the dealer service dept can do that. However, I'm sure they charge an arm and a leg. What I normally do is calculate the difference. For example, in going from 245/75/16 to 265/75/16 the difference is 1.033 larger so I muliply that by the amount of miles traveled. Fuelly doesn't seem to allow that, though. I also use MPGTune.com which does allow you to put in "miles driven" instead of the odometer reading.
  14. Sep 14, 2009 at 5:04 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Alright, I'll do this. I'm interested to see just how my true average mpgs since I do a lot of varied driving. Lots of towing and offroad driving too.
  15. Sep 14, 2009 at 5:14 PM
    #35
    04coma
    04coma Well-Known Member
    Justin
    Temple Texas
    04 trd offroad sr5 prerunner debadged
    air aid intake and throttle body spacer billet grill clear corner lights and 3rdbrake decal "coma" :)
    ill give it a shot!
  16. Sep 14, 2009 at 5:31 PM
    #36
    RelentlessFab
    Eric
    Sparks, NV
    I believe that Hypertech has a calibrator for our truck, dont know what they cost though.
  17. Sep 15, 2009 at 6:00 AM
    #37
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Not sure if I have read wrong but you can change fuelly from odometer reading to miles driven, or vise verse.
    When I make my tire corrections I do it myself before hand, as in however many miles my odom shows I then multiply by that and add that number to fuelly.
    Oh and my little thing in my sig is way wrong but on my home page on fuelly it is correct. 16.3, I'll see if it adjust after my next fuel up.
  18. Sep 15, 2009 at 6:49 AM
    #38
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    For those that are interested here is how you get your correction value.
    * Take the stock tires Circ. and divide it into the Aftermarket larger tire's Circ. that will be your the number you multiply into the miles on your odometer.
    Example: 245/75/16 30.6" Tall.Circ= 95.7 Factory tires size our trucks are calibrated for. This is important because they are known for sometimes coming with smaller tires. Although still calibrated for this tire size.
    After market Tire 285/70/17 33" tire which actually measures 32.7" Tall. Circ=102.8
    102.8/95.7=1.074 Now take your mileage of 321x1.074= actual miles driven 344.8
  19. Sep 15, 2009 at 6:54 AM
    #39
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    0.0? no fill-ups yet!
  20. Sep 15, 2009 at 8:00 AM
    #40
    ponq
    ponq Active Member
    Just signed up.
    Neat
