Full 3 inches from eibachs/5100
Discussion in 'Suspension' started by wolfdog2314, Jan 10, 2012.
  1. Jan 10, 2012 at 4:33 PM
    wolfdog2314
    wolfdog2314 [OP] Well-Known Member
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I've got eibachs and 5100's at .85 with the driver side lean spacer.
    Stock ucAs currently.
    I'd like to get a full 3 inches out of this lift. From what I have read, and I just want to confirm, I can:
    Put the driver side lean spacer on the passenger side and get ??inch spacer for the driver side?
    I plan on getting new uCAs with this.
    Also would this setup allow for a plate style bumper such as Relentless aluminum (55lbs) is what I'm interested in...
    Thanks!
  2. Jan 10, 2012 at 4:39 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I wouldn't stack more spacers on top- you already have the taco lean spacer.
    are you not already getting 3"?
    the eibach coils should let you run the aluminum bumper without a problem
  3. Jan 10, 2012 at 4:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Toytec makes a thicker top plate specifically for the application you described but if you use a 1/2" spacer on the driver's side and 1/4" on the passenger side, you'll be pretty damn close to 3" (just under by about 1/4 - 3/8"). Check out Toytec's website for the top plate they made specifically for this application.
    A plate bumper will sag the set up some unless it's aluminum but the Eibachs will support weight, they're a strong coil. If you want to run 3" of lift with a heavy plate bumper, this might not be the best set-up for you.
  4. Jan 10, 2012 at 5:09 PM
    wolfdog2314
    Perfect. That's what I needed to hear.
    .5inch spacer on driver side and .25inch spacer on passenger side. (no stacking)
    And the aluminum bumpers are what I am looking into. I understand id have to do something different with the 100+ lbs bumpers.
    Thanks again
