Full 3" with 884s and 5100s?
Discussion in 'Suspension' started by 208_Tacoma, Mar 9, 2019.
  1. Mar 9, 2019 at 4:27 PM
    208_Tacoma
    208_Tacoma [OP] Well-Known Member
    Jake
    Idaho
    2011 Trd OR black 4wd
    BFG KO
    I want a true 3" lift and I am thinking I am going to go with Bilstein 5100's. (On a budget) My question is there are some brandnew OME 884 coils for a very good price that I am going to buy. If I paired the 884's with 5100's would I get the FULL 3 inches? Thanks!
  2. Mar 9, 2019 at 8:13 PM
    208_Tacoma
    Jake
    Idaho
    BFG KO
  3. Mar 9, 2019 at 8:30 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Probably closer to 2.5" of lift with the 884.
    tcjacado likes this.
  4. Mar 9, 2019 at 8:34 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    2" if DC. If you want 3, go with 885 and a top plate spacer or 887 coils no spacer.
    Again, if DC.
    maxtherat and tcjacado like this.
  5. Mar 9, 2019 at 8:36 PM
    tcjacado
    tcjacado Well-Known Member
    ^^^^ this
    maxtherat likes this.
  6. Mar 9, 2019 at 8:37 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    If you get close to 3” you’ll likely need uca’s as well. Anything above 2.5-2.75” you are going to be asking for problems plus poor ride quality. My$.02
  7. Mar 9, 2019 at 8:39 PM
    geekhouse23
    Realistically, anything approaching close to 2.5" or more, it's HIGHLY recommended, but yes. OP is looking for 3 and should definitely add UCAs to his purchase list
    maxtherat[QUOTED] likes this.
  8. Mar 9, 2019 at 9:37 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    This!! Then, prepare for the ECGS bushing, new alignment hardware and control arm bushings because your stock units are seized, worn tires and a couple of alignments.
    Oh, and if you lift the back, shock extenders or longer shocks. Then, you'll need to relocate your parking brake cables and flexible brake lines on your rear diff.
    Would I lift again, yes. Just know that your $ input will be more than the lift!
  9. Mar 9, 2019 at 9:39 PM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    ^ hit the nail on the head there. Lifted 3 all required the ecgs bushing
  10. Mar 10, 2019 at 7:57 AM
    208_Tacoma
    Jake
    Idaho
    BFG KO
    My truck is an Access Cab. Would I get more lift then?
  11. Mar 10, 2019 at 9:01 AM
    yotatotaco77
    yotatotaco77 Well-Known Member
    Southern Oregon Coast
    2011 Tacoma TRD off-road extended cab
    Bilstien 6112s with 700# springs ARB Deluxe Bull Bar 9k winch Bilstien 5160s Icon progressive 3 leaf AAL
    Hey OP, I don't know much about the 5100s and OME coils, but for my truck, same as yours only blue :rolleyes:, you would get a little more lift being an access cab, but not much. And as far as new UCAs go, I've been running my stock UCAs on my lift for a little while now and have had no issues, but that being said, I still bought new ones:spending:
    You can get away with it for a while, just put it high on your to-do list :thumbsup:
  12. Mar 10, 2019 at 10:50 AM
    208_Tacoma
    Jake
    Idaho
    BFG KO
    Thanks for the help! What is the difference of running new UCA's?
  13. Mar 10, 2019 at 10:56 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    The aftermaket ucas allow for better allignment and less binding on the front suspension. If you plan on going 2.5"+ then it is recommended to install uca to correct these issues.
  14. Mar 10, 2019 at 11:00 AM
    yotatotaco77
    For my shocks they help with clearance from the coils, with my stock UCAs, when my suspension droops they contact the coils. So over time they'll ding the crap out of your coils. But as long as you don't do too much off roading until you get new UCAs you should be alright. Depending on which UCAs you get, they'll help with caster too.
