Full exhaust replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by PBNCLB, Jan 9, 2022.
  1. Jan 9, 2022 at 10:55 AM
    PBNCLB
    PBNCLB [OP] Well-Known Member
    Landon
    1999 Black Tacoma Xtra Cab
    Aftermarket Radio Bilstein 5100s
    You guys know any good places to source a full bolt on exhaust from the manifold back? Long story short, local muffler shop did a crap job welding a new muffler on resulting in a hanger breaking off, then the muffler broke off as well and also broke the manifold… smh
    Looking to just replace the manifold with mini headers, every single pipe following that considering the cat that’s welded to the front pipe is also bad and I have no welding skills or access to a welder.
    Having a hard time finding the correct pieces and at a reasonable price… oem Toyota front pipe/ cat assembly is $1000+
    what do you guys recommend ?
  2. Jan 9, 2022 at 11:15 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I went with Walker for the inter pipe and tail muffler because it was drop in place with the preinstalled hangers...
    went generic on the stainless headers and JC Whitney cat.....
    Ordered the Walker two pieces thru Advance auto.....ship to home only.....
    Exhaust Parts Lookup | Walker Exhaust Systems
    Still had to have local shop weld all up....took 20 min...charged me a c-note
    PBNCLB[OP] likes this.
  3. Jan 9, 2022 at 11:50 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have been using Walker Exhaust for years.
    It fits Easy to find most places
    PBNCLB[QUOTED][OP] likes this.
  4. Jan 9, 2022 at 12:54 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Just like the others said go with Walker. Proven product over time
  5. Jan 9, 2022 at 1:04 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Have you asked that shop to reimburse you or fix their work? You might be able to find a used setup for next to nothing, if you don't live in a rust area then it should be usable.
  6. Jan 9, 2022 at 1:54 PM
    PBNCLB
    Landon
    I haven’t , I have no proof they did it. I didn’t keep the receipts/ records of them doing the work and its been almost a year since. I’m still going to give them a call and see what they say about it. Doubt they will fix it for me but I’ll try.
  7. Jan 9, 2022 at 2:01 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    Just be nice about it and see what happens. If it goes bad you can take them to the B.A.R. and they will get it taken care of. Either way, the burden is on them to make it right. Good luck!
  8. Jan 9, 2022 at 6:20 PM
    O'Silver_Taco
    MD
    Yeah....I would run from those people.....
    sometimes... just got to shoot the dog....cut your losses.....
  9. Jan 9, 2022 at 6:27 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    Run and they keep doing this to people, if they get a visit from the BAR he will get it repaired or refunded.
    Give the shop a chance to make things right, as of now it sounds like the shop has no idea what happened. Maybe they hired a new guy and fired him the same week.
  10. Jan 9, 2022 at 6:28 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
  11. Jan 9, 2022 at 6:40 PM
    PBNCLB
    Landon
    yeah mines the cast one, I was going to upgrade to the steel mini header from the 01-04 but I’m having a super hard time finding a used one locally. All of the options I see online are $300+ not including the $87 heat shield.
    Then the exhaust on top will be a good bit over what I can spend right now unfortunately. Hopefully I can find a decent one off a junkyard truck sometime this week. I’m without a ride right now because of this lol
  12. Jan 9, 2022 at 6:47 PM
    PBNCLB
    Landon
    Thanks to all for the great recommendations and help. Definitely going with a walker setup :)
    Toyotaguy1 likes this.
  13. Jan 9, 2022 at 6:53 PM
    Bivouac
    If your close to me I should be able to make something for an Exhaust till the budget improves
    Can`t help with the manifold.
    The bad part is waiting a year it seems so many just get in the truck and leave never inspect the work you paid good money to have done..
  14. Jan 10, 2022 at 5:56 AM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Walker is the way
  15. Jan 10, 2022 at 6:38 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    remember there is a difference between the 4cyl and 6cyl versions so make sure to get the correct one.
    as long as you get/find/fix the header Walker has all the other pieces to bolt up (unless the long tube header for 4cyl)
  16. Jan 10, 2022 at 8:10 AM
    snaggs
    snaggs Well-Known Member
    Shaun
    Nova scotia , Canada
    2001 tacoma sr5 2.7 4x4
    None
    Walker for oem likeness. Reasonable priced and quality is alright. Dealer is best but prices are beyond what i will pay.
  17. Jan 10, 2022 at 10:05 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I like Bosal more than Walker but same difference.
  18. Jan 12, 2022 at 10:25 AM
    PBNCLB
    Landon
    I’m located in NC, if I’m reading correctly I think you’re located in PA :( thanks for the offer, it’s very appreciated
    Bivouac[QUOTED] likes this.
  19. Jan 12, 2022 at 2:32 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    +2 For Bosal.
  20. Jan 12, 2022 at 3:34 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    My O.E. exhaust lasted 21 years, my Walker S.S. is in 1 year and sounds good and it’s holding up well. Can’t beat the price.
