Full fluid change questions (oil, transfer case, manual trans etc.)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blurple Taco, Nov 10, 2017.
  1. Nov 10, 2017 at 12:57 PM
    Blurple Taco
    Blurple Taco [OP] Active Member
    2000 Tacoma 3.4L V6, 4WD
    I am about to embark on the journey that is a full fluid and oil changeover. Doing usual oil change but going to follow up with transfer case, rear and front differential, manual transmission, coolant, and power steering. I am going by the FSM for the gear fluid work and specs. I found a decent YouTube video of somebody doing this here: https://youtu.be/eDNYzMONxEk
    It has been years since I have done any of this so looking for answers to a few questions from the regulars here:
    1. I am unsure if the listing in the FSM for short or long wheel base is in reference to the standard or xtra cab? The oil quantity varies between them, though barely. I see 2.2qts for front differential, and for rear either 2.6 or 2.7qts (long base). Not enough difference to really get manually so doubt that will matter, however, safe is better. I saw a thread that stated the qts for the long wheel base was a typo. A lot of threads say to just fill each until it starts to just barely flow out of the fill point. That seems to be the standard practice but checking anyway.
    2. Oil spec 75W-90 front diff, 80W-90 rear diff. I see many threads here where people just run 75W-90 in both, any difference just using same viscosity?
    3. Transmission shows 2.3 qts at 75W-90, transfer case shows 1.1 qts at 75W-90. Again I see most threads just fill until it barely flows out. Has this ever caused any issues long term?
    4. Power Steering. I see many threads where people do the turkey baster to empty it out then refill with fresh fluid, as in this thread:
    https://www.tacomaworld.com/threads/power-steering-flush.90216/
    Anyone else do it this way or similar?
    I plan on following all this soon with accessory belts, timing belt, and chassis work listed in the FSM for 100-120k miles. This is not like my 1970 Dart that could chew up ball bearings you throw in it, spit them out and ask you what your problem is anyway. I do not want to create any issues in a newer vehicle that is my daily driver and I love this truck. I passed my 100k mile work due to work schedule with no downtime and need to start knocking it out.
    TL;DR Anybody have any do/don't advice when doing a full fluid change out? Input would be appreciated. I plan on doing it over this three day weekend. Thanks :)
  2. Nov 10, 2017 at 2:29 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Both diffs and the transfer case can use 75-90, I use Mobil1 or Lucas. Loosen the full plugs first to make sure they aren't seized. Fill until it dribbles out the fill hole, that is the exact amount that's supposed to be in there.
    Most people prefer Redline mt-90 for the trans, same deal fill it till it comes out the fill hole.
    PS fluid is supposed to be ATF, the seals are not designed for thinner PS fluid. You can crack the hard lines on the steering rack to flush all the fluid out, jack up the front end and steer lock to lock a few times to push the old stuff out. Use a flare nut wrench on the hard lines so they don't round off - 12mm.
    In total you'll need about 6 quarts of gear oil, 3 quarts of Redline, and a quart of ATF. Sounds like you've got a good handle on the rest of it.
    Blurple Taco[OP] likes this.
  3. Nov 10, 2017 at 3:14 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
  4. Nov 10, 2017 at 3:19 PM
    Blurple Taco
    Thanks for the reply. The FSM called for Dexron 3 ATF for the power steering pump, so that was what I got. Came up to quite a bundle at Napa. Thanks for the heads up on filling the fluids, that was what I figured seeing other threads but wanted to make sure I wouldn't be overfilling anything. They didn't have any Mobil 1, which was what I was going to get, so I got Valvoline.
  5. Nov 10, 2017 at 3:23 PM
    Blurple Taco
    Wow, thanks for the videos man, those are pretty thorough. I will check those out fully before I start in.
  6. Nov 10, 2017 at 4:16 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
  7. Nov 10, 2017 at 4:46 PM
    Blurple Taco
  8. Nov 10, 2017 at 6:10 PM
    tony2018
    tony2018 Well-Known Member
    If you're draining the transmission fluid, remove and replace the gasket and filter
    Same for the engine oil pan gasket
  9. Nov 10, 2017 at 6:12 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    OP has 5spd. No filter :rolleyes:
  10. Nov 10, 2017 at 6:13 PM
    tony2018
  11. Nov 10, 2017 at 8:35 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    The advice to check out Amsoil is sound. It's "very" good stuff. I have it in everything. Engine, trans, diffs and transfer case. One of the reasons I use it is because it opens up the drain intervals quite a bit so I don't have to be changing fluids near as often. I went almost 8500 miles on my last oil and filter change and after having an analysis done Blackstone told me I had a "beautiful" sample with everything in spec even though no one runs a 3RZ as long as I am in their experience. I might be able to go 10,000 eventually with a filter change at 5000. Gear boxes? Amsoil can go over 100,000 miles as long as you don't ford rivers or get other contamination into the gear boxes. I changed my gear boxes a couple of years ago. I'll change them again next summer and see how the analysis turns out and then decide how long I can really go. I'll probably have around 60,000 on them by then. I'm using Amsoil 75-110 in my diffs, 75-90 in the transfer case and Amsoil's GL4 in the tranny.
  12. Nov 11, 2017 at 4:07 AM
    tony2018
    Reminds me, there's an advance auto parts store that now sticks amsoil products. The only one
  13. Nov 11, 2017 at 4:52 AM
    ceviche
    ceviche New Member
    TED
    BOSTON, MA
    2001 TACOMA 4X4 2.7 REG CAB - MANUAL
    DUAL OPTIMA 34/78 RED&YELLOW T0P w/INTELLIGENT SOLENOID
  14. Nov 11, 2017 at 5:28 AM
    Blurple Taco
    Yeah I bought that guy along with the gear oil. The last time I did any of this sort of work was helping somebody without one and I remember how much of a mess it was.
  15. Nov 11, 2017 at 7:01 AM
    Blurple Taco
    Anybody
    I spotted that the torque specs for the rear differential were different than the FSM I have. Mine shows 39 ft.lbs but his shows 36 ft.lbs. I am leaning towards following his seeing as he has the physical book and mine is electronic, though our pages match up with that spec being the only difference. I may see if Toyota will confirm the spec for me since I have to get some parts from them.
  16. Nov 11, 2017 at 7:18 AM
    Timmah!
    TIM
    There are mistakes in the FSM. I have found several. When following the FSM, you need to sometimes question the values printed especially when they don't make any sense what so ever. One of the worst ones I've seen was a mistake for the torque value for the nuts holding the 3rd member onto the rear axle. The FSM gave two different torque specs, one for the locker 3rd member (18 ft-lbf) and one for the non-locker 3rd member (54 ft-lbf). There was a huge difference between the two. If you blindly followed the higher torque value given and tried tightening the nuts to 54 ft-lbf, you would be stripping the nuts and breaking the studs on the axle housing. So, common sense is definitely required when using the FSM. If the torque value doesn't seem to jive, it's probably a mistake.
  17. Nov 11, 2017 at 7:21 AM
    Blurple Taco
    Yeah my thoughts exactly. If I cannot confirm with Toyota (though I should be able to) I will go by the lesser of the two specs and do 36 ft/lbs.
  18. Nov 11, 2017 at 7:59 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    For all your drain and fill plugs- buy new crush washers from Toyota. You can get away with reusing them a couple times, but it’s so much easier to use new for a few bucks. I didn’t have one for my rear diff last year, and the dang thing started leaking immediately after I changed fluid. So I got to do it again after I got the washer
  19. Nov 11, 2017 at 8:09 AM
    Blurple Taco
    Yup. Waiting for Toyota to open to see if their parts department is open to buy them today.
  20. Nov 11, 2017 at 8:48 AM
    Blurple Taco
    Thanks to all for the help and input. Much appreciated guys. :thumbsup:
