Full label
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ralph38, Aug 31, 2016.
  1. Aug 31, 2016 at 8:37 PM
    Ralph38
    Ralph38 [OP] Member
    Rafael
    Toyota Tacoma TRD sport 2013
    I bought a 2013 Toyota Tacoma. How can I tell if this truck is full label?? I want to know how many labels it should have and where are they placed. I will appreciate any help. Thanks!
  2. Aug 31, 2016 at 8:47 PM
    Pigpen
    Dan
    Northwest Montana
    Do you mean if it has all the decals? Not really sure what you mean by full label. Decals can be purchased online or Cboy808 can make custom decals.
    Most members pell off the decals and throw them away. The Toyota and Tacoma badges often get the same treatment.
    Ralph38[OP] likes this.
  3. Aug 31, 2016 at 8:56 PM
    Ralph38
    Ralph38 [OP] Member
    Rafael
    I meant the once that tells you if the body parts are the originals in order to know if any body part has been replace for any reason.
  4. Aug 31, 2016 at 8:57 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Is it because the color looks slightly different sometimes? Like front door to back door? Or grill surround to hood?
    Ralph38[QUOTED][OP] likes this.
  5. Aug 31, 2016 at 8:58 PM
    Ralph38
    Ralph38 [OP] Member
    Rafael
    I meant the once that tells you if the body partsare the originals in order to know if anybody part has been replace for any reason.
  6. Aug 31, 2016 at 9:02 PM
    Pigpen
    Dan
    Northwest Montana
    You're over thinking this.
    Ralph38[OP] and Skyway like this.
  7. Aug 31, 2016 at 9:02 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Serial number matched parts.
    Used to be little 1/4 inch wide stickers about 3 inches long.
    Back in 1990..
    I know my truck has replacement panels so I didn't bother to look for any.
    Just ask the seller?
  8. Aug 31, 2016 at 9:05 PM
    Pigpen
    Dan
    Northwest Montana
    Just drive it down a really narrow trail and scratch it all to hell.
  9. Aug 31, 2016 at 9:06 PM
    Ralph38
    Ralph38 [OP] Member
    Rafael
    alright!! Thanks!!
    Skyway and Pigpen like this.
  10. Aug 31, 2016 at 9:06 PM
    Skyway
    Ande'
    St.Pete
    Look inside of the drivers side door.
    On the door jamb or pillar.
    All the labels you need will be there.
    If there are no labels then someone peeled them off.
  11. Aug 31, 2016 at 9:26 PM
    Ralph38
    Ralph38 [OP] Member
    Rafael
    Those are there!! The one with all the truck info an the vin number and two other..
  12. Aug 31, 2016 at 9:32 PM
    Ralph38
    Ralph38 [OP] Member
    Rafael
    Thanks!! Appreciate your help guys!!
    Skyway likes this.
  13. Aug 31, 2016 at 9:33 PM
    Skyway
    Ande'
    St.Pete
    Right... If it were rebuilt it would have a rebuilt certification sticker.
    Required by law.
    The rebuilt classification means an insurance company totaled it and someone picked it up.
    And restored, or rebuilt it.
    If your truck does not have this sticker "rebuilt" then there's no issue.
    Mine is rebuilt, but I knew what I was buying before I put cash on the table.
    If you think there is a panel ...
    That was replaced.... then look at attach points, there will generally be a screw or clip missing. Or 2 or 3
