Full size matched spare (Jeep style)
Discussion in 'Wheels & Tires' started by fvtalon, May 31, 2012.
  1. May 31, 2012 at 8:45 PM
    fvtalon
    fvtalon [OP] Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    Anyone run a full size matched spare? As in 5 nice alloy rims with matching AT or MT tires and a 5 tire rotation like you'd have in a Jeep? I need tires and managed to locate a matching rim so I'm thinking about doing this.
    The cons basically boil down to cost and where do you put it. The pros would be once you do buy tires they should last 20% longer because each gets a rotation into the spare position. Also if you have a flat you replace it with a matching tire with matched wear and a matching rim so you're back on the road with no traction imbalance, diameter difference, load capacity or ugliness.
    Another thing is insurance in the event of a catastrophic tire failure on a maybe a half worn set of tires. What do you do? A new MT or AT will have a fairly signifigant tread depth difference or you can hope to find a used tire with similar wear. Or put two on and throw out a tire that's still half good...
    Beyond weighing the cost/benefit issue my other concern is putting a nice alloy rim under the truck. Anyone done this? How beat up does it get?
    I use my box too much to have a spare sitting in it so a bed mount or a tailgate mount isn't an option. I like the look/utility of a roof basket with roof mounted spare but I'm not willing to give up the mileage.
  2. May 31, 2012 at 9:53 PM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    you can mount a 33 under your truck
  3. May 31, 2012 at 10:20 PM
    fvtalon
    Southern BC
    07 DC TRD/Yamaha
    Yeah, thanks, I think you have to cut those front tabs and it'll fit. I'm more curious how a nice wheel will stand up to road debris and stuff while mounted under there.
    I suppose you could plasti-derp it. It does peel off after all... hmmm...
  4. May 31, 2012 at 11:51 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I have a full size spare with OEM TRD 16" wheel in my bed.. Why not just throw it back there that way if you have a flat you can get it out and on your truck in minutes. If you ever need to put anything in the bed you can place it upright for room.
  5. Jun 1, 2012 at 5:52 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
  6. Jun 1, 2012 at 5:58 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2. I wouldn't put an alloy wheel under the truck to get beat on by road debris and rocks. In the event you need to run a spare, who cares what it looks like as long as it's the right size? Just throw a taller tire on the OEM spare wheel and be done with it.
    Unless you're rock crawling and slice a sidewall, you're more likely to use a tire plug kit than use the spare anyways.
