Fumigate travel trailer to get rid of smoke smell?
Discussion in 'Towing' started by MJonaGS32, Apr 20, 2009.
  1. Apr 20, 2009 at 10:07 AM
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I'm in the process of getting a used travel trailer, but the previous owner smoked in there and so it smells like a vegas casino. Any tips on fumigating the whole thing? What to replace (cusions, wall paper etc), anything on getting rid of that smell?
    Also, if I'm looking at getting new cusions, mattresses, etc, how would I go about getting replacements for those custom sizes? Would I be better of doing most of it myself?
    Any tips would be great
  2. Apr 20, 2009 at 1:25 PM
    JWWPHOTO
    JWWPHOTO Well-Known Member
    Westlake, Louisiana
    2008 Tacoma Pre-Runner w/ TRD packag
    I would literally wipe down all the surfaces, including floor, walls & ceiling with warm soapy water. That will be a good start.
    Jeff
  3. Apr 20, 2009 at 5:20 PM
    saltbranch
    saltbranch Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    Cant garrantee this to work, but it should. Go to Walmart and buy a big can of cheap coffee. Buy some cheap panty hose or use the wifes at your own risk :eek:. Cut panty hose in 10-12" sections, tie knot on 1 end, fill with coffee grounds, tie knot in top. Set several of these inside trailer, the coffe will absorb smells.
    I used coffee to absorb bad odors in trailer when I drove a truck. Example picked up some bull hides hauled them from Fl. to Laredo Tx. Open the back door and the stench was fierce, after unload, had trailer washed out..stench was still bad. Spread out coffee grounds in trailer that PM, next AM, trailer was good to go.
    My father in law had squirrels in the attic of his home, so he decides to launch handfuls of moth balls in attic. Squirrels left, but moth balls created a serious smell in the house, they were looking at having a Co. come out suck out insullation, then spray in more insullation. Told him coffee/panty hose trick, he threw in about 20 coffee bombs in attic...smell gone.
    Worth a try. Paparika works too, but Coffee is alot cheaper.
  4. Apr 20, 2009 at 5:40 PM
    canadiankid
    canadiankid Well-Known Member
    Langley BC Canada
    09 DC LB TRD SPORT
    You can get a product called nil odor that might work. After that I would put in a good air purifier and leave it closed up for a few days with it running.
  5. Apr 20, 2009 at 5:43 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    IMO it's not worth it. You'll never get the smoke out of the trailer. I would look at getting a different trailer. In today's market there are tons of deals out there.
  6. Apr 20, 2009 at 5:45 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    I had a Ford truck ozone treated one time - it worked pretty well. Concentrate on soft furnishings above the head - that's where the smoke rises too and affects the most.
  7. Apr 20, 2009 at 6:32 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    thanks for the tips guys. once i get the trailer i'll be using some of these techniques to get rid of the smell.
  8. Apr 20, 2009 at 7:15 PM
    j4x4ar3
    Jay
    Austin, TX
    I just noticed you're not very far from me. Seriously.. I wouldn't fight with smoke or the residual because when it gets hot out you're going to smell it especially in the synthetic fabrics that the trailer cushions are usually made out of. I would take a trip out here to Manteca and surrounding area. Several dealers are going out of business and are blowing their remaining stock out the door. You can get a trailer new for a really good price and not have to mess with the smoke smell.
    Don't forget to do a thorough inspection as well to make sure there are no leaks and that everything is fully functional. Check the black tank as well to make sure it was properly taken care of and cleaned out. Nothing worse than having a tank that's half functional because the crap (literally) wasn't properly cleaned out regularly. Horror stories can be found over at rv.net.
  9. Jun 8, 2009 at 11:16 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I guess I should update this thread for archival purposes...
    I took out ALL of the upholstery and blinds. Then wiped down all of the walls, cabinets, and ceiling. Then I filled 6 paper bowls with baking soda and put them all around the TT: in cabinets, in the bathroom, out in the open, etc. Then I closed all windows and vents and left it in there.
    Seriously, in a matter of ~3 weeks, the cigarette smell is completely gone. And this is from an owner who constantly smoked in it. Now, as I continue to revamp the whole thing, I leave all the vents and windows open, because now it just smells like my grandma's room, plain ol "OLD." Maybe I'll eventually add some febreeze, etc.
    So considering all of your wonderful tips, it has completely fixed my problem.
    Thanks!
  10. Jun 9, 2009 at 12:13 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    sounds good :thumbsup:. We had a trailer that got a little damp and musty over the winter once, and couldn't get the smell out even dried out and aired out, then used ozone and it cleared it completely. Ozone is hazardous to your health though, so you shouldnt be in/around the area being treated.
  11. Jun 9, 2009 at 12:52 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    Might have to try this my self.. i wonder if I could feed the coffee to the dog to counter act the smells it releases
  12. Jun 9, 2009 at 2:20 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    they use coffee to get rid of some scents at the clinics so that you can smell the next "herb" haha sorry but coffee is THE SHITT!! esp during finals!
  13. Jun 9, 2009 at 2:21 AM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    that is the smell i was referring to in my previous post
  14. Jun 9, 2009 at 2:23 AM
    MiikeyD
    Upland, CA
    hahah i dont think that it would be healthy for the dog.
  15. Jun 9, 2009 at 11:20 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    coffee is a "no no" for dogs
  16. Jun 10, 2009 at 5:57 PM
    j4x4ar3
    Jay
    Austin, TX
    To get rid of that "musty" smell try getting some DampRid. Not the kind in the tubs but the DampRid that you can hang in a clothing closet. You can hang one in a couple of the windows in your trailer. They serve two purposes.. they will keep the mositure from forming on the windows and prevent mold in the window trays. Also since they are the ones that are designed for clothing closets they'll keep the moths away and make your trailer smell clean and fresh. I do this when storing and they trailer smells like new when I open it up again for the spring/summer camping season.
