Fumoto Differential Valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Taco4x4, Jul 12, 2011.
  1. Jul 12, 2011 at 7:35 AM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Does anyone know if there is anything like the Fumoto valve for the differential?
  2. Jul 12, 2011 at 11:27 AM
    Eurosport
    Eurosport Well-Known Member
    around the world
    hmmm that would be the dumbest thing you could possibly do
    think about it
  3. Jul 12, 2011 at 11:51 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I recently made a custom oil pan for my truck, so I had the oil pan off. I also had one of these Fumoto valves. The way the valve is designed and the amount of threads projection into the oil pan, retains a fair amount of oil in the pan.
    So, you think you have drained the old oil out, but you actually may have 1/2 cup still in the sump.
  4. Jul 12, 2011 at 12:13 PM
    Eurosport
    around the world
    easier and cleaner with a Pela extractor from the top,
    then you can open your drain plug if you really wanted and drain the last 2 drops that's left and no mess ;)
    as well as use the extractor on the filter housing as you unscrew it, never have to mess with the filter housing bottom plug, and not one drop overspill on that flange...
  5. Jul 12, 2011 at 12:28 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The Fumoto valve scares me. Why make it to where some scum bag doesn't even need tools to get under your truck and drain some fluid just for the hell of it? These trucks (especially when lifted) are an easy target.
  6. Jul 12, 2011 at 12:29 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    this is exactly why I don't want one
  7. Jul 12, 2011 at 12:57 PM
    Eurosport
    around the world
    residual particles? hmmm they are in your filter already
  8. Jul 12, 2011 at 2:51 PM
    OffroadToy
    I know...you could probably even do it with a jack knife. At least with the oem drain bolt you'd have to use the right size socket/wrench. I'm not saying it could never happen with the bolt...just sayin it wouldn't be as easy. In a qiuck get underneth and dash scenario they'd be looking at a longer time spent underneth removing the drain bolt than opening up the valve.
  9. Jul 12, 2011 at 6:53 PM
    05Taco4x4
    2TR-FE Enthusiast
    I don't do any off-roading and i have a pre-runner so it's fairly high off the ground, so I don't have any ground clearance problems. but the more i think about it, i don't think it's as routine as an oil change, so i don't think i want to any more.
    the oil pan/remaining oil problem raised earlier is easy, CUT A BIT OF THE THREADED PART OFF
