Fumoto drain
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baboltin, Jun 26, 2025.
  1. Jul 8, 2025 at 5:38 PM
    #41
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    You could cut a slot in the end of the threads to make a channel for any remaining oil to drain.
    Personally I would like the oil to flow slower. The last couple oil changes I did with 0W20, it made a huge mess because it flows too well when it's hot. It went into the oil catch pan and then jumped straight back out, making a mess of the skid plate and the floor. It was worse in my other car where I had to pull the plastic underbody panel with 16 plastic push pins and then cut out the oil soaked sound deadening material.
    po35042 likes this.
  2. Jul 8, 2025 at 5:46 PM
    #42
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    you missed the part where you carefully lay out cardboard to catch any overflow or splashes to avoid staining the garage floor.
    instead, it will splash and bounce off the cardboard, go even further than expected, and then wick across the bottom of the protective cardboard everywhere.
    Taco_mike73 and Barsoom like this.
  3. Jul 9, 2025 at 6:36 PM
    #43
    otoro
    otoro Member
    2017 White Tacoma TRD Pro
    i seen some shit recently where people were taking a torch to the garage floor in the summer and burning away oil.
    anybody do that here?
  4. Jul 9, 2025 at 7:43 PM
    #44
    johnnyd2723
    johnnyd2723 Well-Known Member
    N.E.Ohio
    '23 LR Trail, '05 F-150, '22 Mustang M1 HP FJG
    Ive read that too but maybe that's been corrected and here's why I say that.
    When I installed my Fumoto (last month), I had the factory drain plug out for, I don't know, 20 minutes or so, and the pan had slowed to a drip. I screwed in the Fumoto and opened it up. Well, it started dripping slowly just like it was prior to the install. So my conclusion was this was a non issue.
    My .02
  5. Jul 9, 2025 at 7:59 PM
    #45
    999
    999 Well-Known Member
    Texas
    I would google torch and concrete before trying it yourself.
    Can have some bad results.
  6. Jul 9, 2025 at 11:38 PM
    #46
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Professional auto shops get dirtier than anything and you won't see them doing this excrement. Just some internet BS. Cancel it.
    soundman98 and otoro[QUOTED] like this.
  7. Jul 10, 2025 at 6:31 AM
    #47
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Cheap kitty litter, then power wash it. Or scrub it with Dawn/Sam's Club dish soap, broom and hot water.
  8. Jul 10, 2025 at 7:29 AM
    #48
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    If you enjoy having flaming hot concrete chunks exploding in your face then go ahead and try it.
    Barsoom likes this.
  9. Jul 10, 2025 at 8:18 AM
    #49
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Post the "cleaning session" on the web for all to see ...
    Barsoom likes this.
  10. Jul 10, 2025 at 10:46 AM
    #50
    otoro
    otoro Member
  11. Jul 10, 2025 at 11:09 AM
    #51
    johnnyd2723
    N.E.Ohio
  12. Jul 10, 2025 at 11:12 AM
    #52
    InThePlains
    InThePlains Well-Known Member
    changing oil is so icky, you should have your husband do it.
