Fumoto engine oil drain valve
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MDAB87, Sep 28, 2019.
  1. Sep 29, 2019 at 5:58 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    If it's mechanical, it can fail.
    Skydvrr, Junkhead and MDAB87[OP] like this.
  2. Sep 30, 2019 at 12:28 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I had a Fumoto drain plug on my 2001 Dodge Cummins. Absolutely loved it. Just to be extra secure, I drilled a small hole in the drain release and would use safety wire to ensure it didn't accidentally get pushed.
    That engine held 11 quarts of oil... while it was draining, I would get my tools ready to remove the oil filter, get the new oil ready to go, etc.. I never felt it took too long to drain out, I would expect it would not take quite as long on our Tacoma's, with only 6.1 quarts ;)
    Taco_mike73 and MDAB87[OP] like this.
  3. Sep 30, 2019 at 12:40 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I'll never own another vehicle (that I do my own maintenance on) that doesn't have a Fumoto. I've had one on my 2009 Tacoma since it was new. With the Fumoto (and the catch basin around the oil filter), I can do an oil change without spilling a single drop of oil or even getting it on my hands.
    Without Fumoto, how do you remove the OEM plug? Do you unscrew and let if all into your pan - then go searching for it? Do you remove and hold onto it and get oil all over your fingers?
    I can drain my Fumoto right into an old oil container with a small opening. It's very precise.
    Monte24, Taco_mike73 and MDAB87[OP] like this.
  4. Aug 24, 2020 at 5:42 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I just got mine, it’s the new version which allows for more oil flow thru the unit . I’m scared to death to use it thou . Quality unit just scared to use it for fear it will open up while I’m driving !
  5. Aug 24, 2020 at 5:47 PM
    igno1tus
    Good idea ! I love the safety wire idea ! Do you think you could take a picture so I can see hole placement and how you wrap the wire ? Possibly ? Please ? Lol
  6. Aug 24, 2020 at 6:38 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
  7. Aug 24, 2020 at 7:17 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  8. Aug 24, 2020 at 7:45 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have had the fumoto valve installed in my old Jeep liberty CRD since I first got it in 2009. It was one of the recommended mods for that engine due to a drain bolt with an alen key head very few threads and an aluminum oil pan. It's very easy to cross thread, to loose the washer and damage the threads in the pan on that engine.
    It does make the oil changes simple you only need a filter wrench a drain pan and a funnel. It does drain slower but not like super slow. There is a plastic clip they sell on Amazon if you are worried about it getting turned open by accident. That really is unlikely as you have to pull and rotate the value to open it..
    If you get the one with out the hose nipple which I recommend it won't hang down far, it was above the skid plate on my Jeep. I even went of road with it. Wasn't an issue.
    I liked having it and will probably get one again for the Tacoma
    Here is a link to the clip for the value, it looks like they are giving it with new valves now. They weren't when I bought it last time.
    https://www.amazon.com/dp/B011SDCZAK?ref=ppx_pop_mob_ap_share
  9. Aug 24, 2020 at 7:48 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    can i get a checklist of all the stuff you guys changed out? im seeing posts and theres a lot of different stuff. ie: fumoto valve, aluminum housing, motivx wrench, drain tool, baxter spin on adapter. are some of these redundant? with a checklist i can just go item by item right into ebay and buy those puppies up. thanks!
  10. Aug 24, 2020 at 7:57 PM
    Taco_mike73
    York, PA
    Not close to my first oil change but if I'm doing it myself it will have a fumoto valve. I'm likely to put in the metal filter canister if I don't like dealing with the plastic one. I have the MotiveX filter wrench already.
    Having the valve on a previous vehicle I have little worries it would be an issue. I'm not sure what a dealership would say about it. Independent mechanics have seen it on my Jeep. They have either never said anything or commented that they liked it.
    Xer0 SiN likes this.
  11. Aug 24, 2020 at 8:00 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I used Fumoto valves for 18 years and I have never had an issue with them even when being offroad.
    Taco_mike73 likes this.
  12. Aug 24, 2020 at 8:03 PM
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    I have one on every vehicle. I will never go back to a standard drain plug, no more worrying about the copper crush washer sealing every time you tighten or replacing it all the time. No more hot oil on the hand.
  13. Aug 24, 2020 at 8:04 PM
    jerkwithkeyboard
    Ive had them on my car and motorcycle from the early 90's
  14. Aug 24, 2020 at 8:07 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Do your research. People are changing things out for different reasons. I still have my plastic oil filter housing. Absolutely zero issues.
