Fumoto Fact(s) You Might Not Know
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Oct 12, 2021.
  1. Apr 26, 2024 at 1:06 PM
    #421
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Well, I use the filter for about 20 minutes per month. I’ve had it two years now and don’t think it will ever need changing. My oil is pretty darn clean so there’s not much contaminating that filter too much.
    GilbertOz likes this.
  2. Apr 26, 2024 at 1:11 PM
    #422
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Does your oil look visibly cleaner after passing through your 2-micron filter setup?
  3. Apr 26, 2024 at 2:04 PM
    #423
    mquibble
    Michael
    2021 TacomaTRD Pro
    No it doesn’t. I’ve seen videos where it turns magically clean but that’s a hoax. The oil, when it’s doing one of its job of “cleaning” will get darker in color. Don’t let that mind you in the least. The #1 thing that that will ruin an engine is contamination. Use a great oil filter, and air filter too, and you will be on your way of doing good for your engine.
    I take the same approach with my oil as I do most other things. I rather change things at 90% life than try and squeak out the last 10% and save a few pennies. I think we’ve all chased Pennie’s to wind up losing dollars.
  4. Apr 27, 2024 at 3:33 AM
    #424
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I can say this, I’ve heard of way more drain plugs falling out than I ever have of a Fumoto valve leaking
  5. Apr 27, 2024 at 9:45 AM
    #425
    mquibble
    Michael
    2021 TacomaTRD Pro
    Added a new item to the list, #22 in post #1. It states.....You don’t forget and leave the drain plug that drops into the pan and then discard it out with the oil.
  6. Apr 27, 2024 at 10:00 AM
    #426
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    this is a huge plus for me-- the fumoto is sacrificial. absolute worst case, if it develops a leak, i've saved the wear on my oil bung threads, saving me an entire oil pan replacement, and can easily order a replacement valve that failed from standard use...
  7. Apr 27, 2024 at 10:06 AM
    #427
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    If I forgot to reinstall a plug I could probably forget to close the Fumoto valve also. I don't how that would happen when you have to put new oil in and check the dipstick before starting. If I couldn't do that correctly maybe I shouldn't be trying self maintenance. Don't know how a plug can "fail" if it's removed and installed correctly.
  8. Apr 27, 2024 at 11:46 AM
    #428
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Maybe I’ve been lucky. I installed a Fumoto drain valve in our FJ when new, it’s a 2008. I have changed the oil every 4-5k.
    Currently has 142,000 it is never leaked is never been removed.
    BabyBilly and mquibble[OP] like this.
  9. Apr 27, 2024 at 11:49 AM
    #429
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I don’t think a plug can fail. The only failure I’ve ever heard about with an oil drain plug is the idiots that reinstall it. They forget to tighten, the overtighten, they cross thread.
  10. Apr 27, 2024 at 3:37 PM
    #430
    mquibble
    Michael
    2021 TacomaTRD Pro
    I can't refute your comments but I know I have read here, and seen a bunch on YouTube, of oil change failures. They do happen, even to the best of you guys/gals.
  11. Apr 27, 2024 at 3:41 PM
    #431
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
  12. Apr 27, 2024 at 4:21 PM
    #432
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    TacoTime55 likes this.
  13. Apr 27, 2024 at 5:04 PM
    #433
    soundman98
    NW Indiana
  14. Apr 27, 2024 at 5:14 PM
    #434
    mquibble
    Michael
    2021 TacomaTRD Pro
  15. Apr 27, 2024 at 5:40 PM
    #435
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I’ll take that as a yes. Cool product but I prefer my shavings and potential gunk to woooosh out when I open the drain hole, not dribble. Used one on my 03 Tundra 4x4 OR and hated it. That motor oil was changed every 10k and came out a dark caramel color. Castrol edge 10w-30. Use it on the Taco 10w-20 and it comes out black at 10k. Blackstone says plenty of life left in it so I trudge on with 1 change per year. YMMV
  16. Apr 27, 2024 at 5:51 PM
    #436
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Why would you have shavings in the oil pan?
    doublethebass and Kwikvette like this.
  17. Apr 27, 2024 at 5:52 PM
    #437
    Kwikvette
    Fresno County
    4 run, 2 don't
    Because #shitbox
    (He's a 3rd Genner afterall)
    stbear and b_r_o[QUOTED] like this.
  18. Apr 27, 2024 at 5:53 PM
    #438
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Oh fuck, I just remembered my oil filter is upside down too! :goingcrazy:
  19. Apr 27, 2024 at 6:08 PM
    #439
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    What pliers do you use for that clip? I have an F133 that I haven’t installed just because of being hesitant. That clip would make me feel better about it, but only if it’s not going to be a PITA.
  20. Apr 27, 2024 at 6:09 PM
    #440
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    First time with this housing filter system…and I’ve adjusted to it.
    Fumoto works great as long as “due diligence” is taken to lock the valve once drained.
    I’ve got the aluminum housing and it doesn’t expand like the plastic one does so hand tighten plus 1/8 turn is fine.
