Fumoto Fact(s) You Might Not Know
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Oct 12, 2021.
  1. Oct 12, 2021 at 8:52 PM
    #141
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Crikey! Just checked the price on this kit and >$500 for the adapter and inverted spin on.
  2. Oct 12, 2021 at 9:25 PM
    #142
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A couple of those rare earth magnets stuck on the pan would be good, too
    GrizzledBastard likes this.
  3. Oct 12, 2021 at 9:46 PM
    #143
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    I have literally never changed a crush washer on any vehicle that I've changed the oil on(car, truck, dirt bike, bobber, crotch rocket, 4wheelers, mud truck, lawnmower, pressure washer). With the exception of when I put a magnetic drain plug in my CR250r dirt bike. It got a new washer because it got a new bolt. I've literally never had a leaking drain bolt. This includes the '78 CB750K that I have, which is the oldest vehicle I have. I have so many vehicles that the amount I spend on oil/filters is pretty nuts.
  4. Oct 12, 2021 at 9:52 PM
    #144
    Coffeetime
    Coffeetime Well-Known Member
    My question is, if as you say "bad idea, seems failures can happen easier" Then why are quick drain's used universally on piston engine aircraft? I do not know more of a more mission critical application than aviation and it tendency to be unforgiving :)
    usmc2msu and Big tall dave like this.
  5. Oct 12, 2021 at 10:38 PM
    #145
    DonKeyote
    DonKeyote Well-Known Member
    it’s a freaking chore but it’s worth it. I used a planning tool from one of the landscape websites. Bluebird or something. It helped me quite a bit on the design layout.
    I’m in the desert southwest. I’ve got about $800 into valves and PVC. I opted for commercial valves. Cost a lot more but when they fail (and they will) you can rebuild the commercial units. I had homeowner grade but those change all the time and parts are not as easily sourced.
    I run Tiffway419 in the summer and perennial rye in the winter. Just dropped $100 on a 50lb bad of bird food.
    I’m still eyeballing reel mowers….right now if got a Honda and it’s pretty nice but a reel mower has no equal.
    mquibble[QUOTED][OP] likes this.
  6. Oct 12, 2021 at 11:45 PM
    #146
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    No , we are talking about you being an engineer.
    My company spent $$$$$$ to adapt Toyota methods to remove "points of failure" in the workflow, exactly like those you had with your valve.
  7. Oct 13, 2021 at 2:05 AM
    #147
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    True, but with a magnetic bolt you clean it off easily and get that crud removed out of the pan.
    Big tall dave and $yoda$ like this.
  8. Oct 13, 2021 at 2:31 AM
    #148
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Wow!
    I started on page 1...will read more later. Defending a valve...lol...that's from page one.
    Ed
    Steves104x4 likes this.
  9. Oct 13, 2021 at 4:00 AM
    #149
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    G.. G.. G.. Gorn!
    CrufflerJJ and 44-16 Taco like this.
  10. Oct 13, 2021 at 6:52 AM
    #150
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    "I’m still eyeballing reel mowers...."
    I had plenty of time to eyeball reel mowers in my youth, I spent many hours sweating behind this 60's "Silent" Scotts.
    I mowed every lawn in a neighborhood filled with people who were either old, retired or dead -- all of them cheap!
    One lady would give me $2 and a stick of gum -- yes a stick, not a pack.
    CrufflerJJ, jackn7 and mquibble[OP] like this.
  11. Oct 13, 2021 at 7:04 AM
    #151
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Looks like you can get it off no problem... getting it back on is a another story. LOL
    1. I don’t need any tools to change my oil.
    2. I don’t make a mess.
    3. I don’t get oil running down my arm.
    4. I don’t have to worry about how hot the oil might be.
    5. I don’t get any oil on the topside of my skid plate.
    6. I drain the oil directly into a jug. No oil pan to wipe clean.
    7. I don’t have to fish-out the drain plug from the oil pan.
    8. I don’t have to reuse a crush washer.
    9. I don’t forget to install a new crush washer.
    10. I don’t forget to install a crush washer.
    11. I don’t mistakingly install two washers.
    12. I don’t incorrectly install the washer. There is an orientation to these washers if you weren’t aware.
    13. I don’t cross-thread the plug.
    14. I don’t over-tighten the plug.
    15. I don’t under-tighten the plug.
    16. I don’t forget to not install the plug.
    17. I don’t have to torque a plug.
  12. Oct 13, 2021 at 7:07 AM
    #152
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That's not the right kind of washer. This is the one most people use, it goes on either way. The kind you posted is used on the diffs and t-case, though.
  13. Oct 13, 2021 at 7:13 AM
    #153
    OffroadToy
    better shine that thing up... might need it the way things are going... https://www.cnet.com/home/yard-and-...re-sales-of-gas-leaf-blowers-and-lawn-mowers/
    whatstcp and RustyGreen[QUOTED] like this.
  14. Oct 13, 2021 at 7:23 AM
    #154
    RustyGreen
    sleeping in a chair
    Pavement Princess
    OffroadToy[QUOTED] likes this.
  15. Oct 13, 2021 at 7:29 AM
    #155
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Thanks for the pictures. That’s a pretty cool idea. To be honest I’ve never even considered filtering oil between changes. I do like the idea of being able to drain out water from the oil too.
  16. Oct 13, 2021 at 7:35 AM
    #156
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    You can the drain plug out and install the Fumoto without spilling a drop of oil now, instead of waiting for the next oil change.
    https://www.youtube.com/watch?v=cMs6__8cDm0
    jackn7 likes this.
  17. Oct 13, 2021 at 7:56 AM
    #157
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    And you guys are giving me sh** about a Fumoto?!?!
    Looks EXACTLY like a video I would create to trick my friends. Also Looks like a lot of work. You know- you could just drain your oil into a very clean container and pour it back in OR you could filter the oil through my bypass filter setup, lol.
    Let me know when any of you are going to do this. I will drive wherever you are to watch, root you on, and of course VIDEO you too!
    yea, I get it. This questionable method could be employed for those times you want or need to remove the plug without any oil coming out. I’d have to see this one to believe it. Make sure your dipstick has a good seal on it!
  18. Oct 13, 2021 at 8:17 AM
    #158
    $yoda$
    Tom
    2007 Tacoma 4.0
    I am not making a case against the product or anything like I said I’ll probably get one but realistically none of these things are really a problem. Draining into the empty jug is definitely a plus also not having to worry about oil temperature but nothing else I ever experience when changing oil.
  19. Oct 13, 2021 at 8:20 AM
    #159
    $yoda$
    Tom
    2007 Tacoma 4.0
    This one I have to guess because the oil pan and valve are not sitting 8 inches off the road and potential hazards. Again I’m not opposing this valve for the right application but come on guys little common sense.
    JGO likes this.
  20. Oct 13, 2021 at 8:24 AM
    #160
    mquibble
    Michael
    2021 TacomaTRD Pro
    Have you EVER overfilled your engine and needed to remove 1/4 of a quart or so? If so, this valve allows you to dial-in your fluid oil level easily.
    Have you seen the number of threads about too much oil? They wouldn’t be asking the question if they had this valve.
    pop.tremuloides and grogorat like this.
