Fumoto for transmission pan?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RichochetRabbit, Aug 17, 2023.
  1. Aug 17, 2023 at 9:33 PM
    RichochetRabbit
    RichochetRabbit [OP] Bing Bing Bing
    My RCI transmission skid has a hole for the transmission drain plug (pretty sure it is the drain plug). But opening it could splash all over the skid. Is there an equivalent adjustable-rate drain for the transmission pan?
    My truck has 15k, so there is time. And the transmission plate would have to be removed again, but ...
  2. Aug 17, 2023 at 9:36 PM
    Bishop84
    Bishop84 Well-Known Member
    There's a drain and a check, plus filling with the plate in the way would be a pain too. 3 plugs.
    I remove skids when I do services. Even with holes. The mess isnt worth the time possibly saved.
  3. Aug 17, 2023 at 9:44 PM
    RichochetRabbit
    Figured that much, else I would have read about it. Well ... I have time before transmission skid must be removed.
    Some good news ... the "soft armor" I selected for my forearms prevented bruising while futzing installing engine and transmission skid after the first oil change.
    TRDRed likes this.
  4. Aug 19, 2023 at 11:59 AM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    This... The fill plug which you should always remove first is near the top of the trans, so you will need to remove the skid plate.
    TRDRed likes this.
  5. Aug 19, 2023 at 12:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't know about 3rd Gen's but transmissions normally have a magnet on said drain plug.
    I'd want to retain that feature for whenever I drain/fill my transmission.
    Chew, RichochetRabbit[OP] and TRDRed like this.
  6. Aug 19, 2023 at 12:07 PM
    WinterFalco
    Donald
    No magnets on the trans drain plug. They are in the bottom of the trans pan. The Diffs have them.
    TRDRed likes this.
  7. Aug 19, 2023 at 12:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I remember the Tacoma (1G) and 4Runner (3G) had it in the pan.
    Wasn't sure about a 3rd Gen; thanks for clarifying :hattip:
    TRDRed likes this.
  8. Aug 19, 2023 at 12:12 PM
    WinterFalco
    Donald
    No problem. :)
