Fumoto Oil Drain Valve (discount)
Discussion in 'Technical Chat' started by agapedisciple, Sep 18, 2007.
  1. Mar 27, 2008 at 5:42 PM
    jdubh
    jdubh Active Member
    08 Double Cab V6 4x4
    I would be very afraid of that thing getting ripped off when I drove over a curb, or a piece of hyway debris taking it out.
    I changed my oil for the first time last night and realized that craftsman gave me two 13mm sockets instead of a 13 and 14mm with my set. I was able to get it off with a 9/16 I think, it was a close fit.
  2. Oct 14, 2008 at 3:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I installed my Fumoto valve back in March and had to wait 4500 miles to actually use it. Today, I finally got to use it!
    And all I can say is..... :thumbsup::thumbsup:
    No tools needed. No mess. Very convenient and easy to use. Sooo worth the money!
  3. Oct 14, 2008 at 3:59 PM
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    It is funny, I will be doing mine today and also it will be the first time for the Fumoto valve to be opened.
    I pour AMSOIL and did close to 10,000 oil still clean, but cold temperatures are coming.
  4. Oct 14, 2008 at 5:09 PM
    agapedisciple
    agapedisciple [OP] Active Member
    02 PreRunner SR5
    Skid plate, Tonneau bed cover, Toyota bed liner, Bed Extension bar, Nerf bars
    Same as you mvega1969. I just got a hose from Advanced auto and routed it to a milk jug. Worked great... took a long time, but worked great! Very clean! :)
  5. Oct 15, 2008 at 4:08 AM
    Janster
    Jandy
    Lancaster, PA
    It's weird how a synthetic oil can stay 'clean' for that long. I've been running Mobile 1 in all my vehicles for years and it's always dark as night when I change it. I'm glad its dark.
  6. Oct 15, 2008 at 6:48 AM
    mvega1969
    Laredo
    Well I have seen chocolate tone in some other vehicles with not synthetic oil, our Sienna's oil is same age (7 months -march until today-) but a lot less miles (around 5,000+) and that one is half tone of mine and still see it good until december, AMSOIL is great but I had not enough $$$ now to get it :( and I went to get the Mobil 1 synthetic extended performace deal at Advance Auto Parts (hard to beat!), this time I will try to keep oil in the Tacoma at least 5,000.
  7. Oct 15, 2008 at 11:53 AM
    Janster
    Jandy
    Lancaster, PA
    The question is.... is it better to be clean or dirty when you change it?
    I'd think it's better to have chocolate colored oil when you change your oil because it's removing dirt/debris/sludge instead of leaving it in your engine.
  8. Oct 17, 2008 at 11:29 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Which part # please?
  9. Oct 17, 2008 at 11:41 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Quoted{ Just a recommendation, if you have an air bed inflator handy you can use it as a flush device by placing it at the top where you pour the oil and have everything "closed", oil dip stick in place, oil filter in place and the Fumoto valve open, then pump air into the motor and cover the gap of the inflator with a clean cloth, that will help in the reduction of any oil left after normal gravity or you can expedite your oil change.
    Why not just "blow your air" down the dipstick tube and eliminate all that fancy footwork? You'll never get it all out of the valve train and cylinders.....Air straight to the oil pan will.......not do much either i guess.....
  10. Oct 18, 2008 at 3:29 AM
    Janster
    Jandy
    Lancaster, PA
  11. Oct 18, 2008 at 6:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It IS better to have your oil look like "chocolate". If it comes out looking like new after 5000 miles, the oil isnt keeping suspended the contaminates.
  12. Oct 18, 2008 at 7:31 AM
    MyTaco
    Az
  13. Jul 19, 2011 at 1:54 AM
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    10% off with code "YM4" no more mess : ) https://www.quickoildrainvalve.com
    they also sell a security clip to make sure the valve can't get hit when you go off-road.
  14. Jul 19, 2011 at 4:49 AM
    GSB
    GSB Well-Known Member
    Odenton, MD 21113
    09 TRD Sport DC Long Bed
    Has anyone used this model of Fumoto valve yet?
    http://www.qwikvalve.com/F103S.html
    It has a shorter nipple but you can still attach a hose.
    I only have seen F103 and F103N mentioned before.
