Fumoto oil valve for 2nd gen Tacoma good or bad idea?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FletchCentMa, Mar 14, 2025.
  1. Mar 15, 2025 at 12:55 PM
    #41
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That won't keep it from leaking later if it fails and opens on its own ;)
    I hear ya, I have one on my truck and it's fine. I trust it completely.
    It's just that shops get blamed for shit all the time and engines are expensive. Over time I've had to become stubborn because I'm the one that has to pay the bill if something goes wrong
    AllTacosFloat[QUOTED] likes this.
  2. Mar 15, 2025 at 6:31 PM
    #42
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I’m not a Fumoto fan, but having one installed would save a fair amount more than the time to remove the drain plug. It’s pretty hard to deny that it’d be a major upgrade in terms of convenience, not that an oil change is all that difficult.
    I haven’t gone to one for 3 reasons:
    -concern the valve might fail
    -potential for valve to somehow be damaged and leak oil long before I realize it
    -oil drains more slowly and less thoroughly
    I doubt any of these are legitimate reasons, but it takes a lot for me to change.
    Sprig likes this.
  3. Mar 16, 2025 at 12:12 AM
    #43
    Jarod888
    Jarod888 Well-Known Member
    Colorado
    2024 GMC 2500 AT4 Duramax Longbed
    It was one of the first things I did when I got my 2014. I really miss the simplicity of oil changes on that truck. You really can't go wrong, unless you do lots of rock crawling. I would go for the short nipple version.
    I never had a bit of trouble with it. The initial cost is easily made up rather quickly by not having to replace crush washers every time.
    I was pretty religious about changing my oil every 5k. So from the time I got the truck in 2016, until I got rid of it in 2024, I went from 16k to 130isk. So I probably changed the oil 40 or more times. The crush washer pack on Amazon was 9$ or so, so I figure I saved over 300$ by not having to buy washers. I think I paid 30 bucks for the fumoto valve. Seems like a deal to me.
  4. Mar 16, 2025 at 6:42 AM
    #44
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    It takes less than 30 seconds to remove the drain plug. Maybe 3 to 5 seconds to get the Fumoto valve opened. Assuming oil changes every 5k miles and a lifespan of 200k miles, that's 40 oil changes and a total of around 16 minutes saved. Assuming 12k miles per year, that works out to a whole minute in a year. But, the oil drains slower.
    You can get a pack of 12 washers for $6 or 100 for under $22 (current prices on Amazon). That's 50 cents or less each, and every dealer I've bought parts from would just give me a handful at no charge. That's a cost of about $20, so significantly less than the valve.
    I don't knock anyone that wants to do the Fumoto valve. I just don't buy the argument that is saves time or is cheaper in the long run. if you like it, fine.
    Sprig likes this.
  5. Mar 16, 2025 at 9:05 AM
    #45
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    The fact that it makes the oil change toolless,and no mess on your hands/garage floor is a no brainer to me.
    bagleboy, TegoTaco and szidls like this.
  6. Mar 16, 2025 at 9:08 AM
    #46
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
  7. Mar 16, 2025 at 9:40 AM
    #47
    Sarra
    Sarra Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    Having worked as a lube tech, I can say that a stripped out oil pan is way, way more of a pain in the ass than just replacing a damaged or jammed Fumoto valve. Also takes waaaay less time and effort to replace one, vs fix the other.
  8. Mar 16, 2025 at 10:10 AM
    #48
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    This is a thread composed of DIYers, is there a rash of people doing their own oil changes and stripping the pan? I suspect that there isn’t, and that most of those occurrences happen, no offense, at a quick change joint or dealership. People are much more careful working on their own vehicles, with no time crunch.
  9. Mar 17, 2025 at 7:09 AM
    #49
    jeff7176
    jeff7176 Member
  10. Mar 17, 2025 at 7:31 AM
    #50
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I have one for the simple reason that oil doesn’t run down my arm and/or splatter on my garage floor.
  11. Mar 17, 2025 at 7:45 AM
    #51
    winkeldc
    winkeldc Well-Known Member
    2014 Reg Cab 4x4
    And looks like the only folks that like them, are the ones that paid $35 to replace a $3 part? :)
    To the save the mess crowd, where's your oil filter located?
  12. Mar 17, 2025 at 7:54 AM
    #52
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    I have a 1GR, so the oil filter is up top with a catch pan and a hose barb. Really easy to connect a hose, run it down to the drivers side wheel well, pop the filter and let it drain into a jug for a bit. Pull the filter, wipe out the pan and pull the hose. Can pull it off without spilling more than a drop or two of oil.
  13. Mar 17, 2025 at 8:32 AM
    #53
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My oil filter has a cup that catches overflow and is routed to a hose that runs under the truck by the front left wheel. Uses a shank of a 3/8 bolt and a hose clamp as a plug to stop any dripping. My oil changes no longer require gloves that rip or having oil run all over my hand. I’m not worried about the $35.00. Lord knows I’ve spent more on other frivolous things for the truck.
    scocar likes this.
  14. Mar 17, 2025 at 9:13 AM
    #54
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Completely disagree! I've had one on since almost day one (2013) and it's been one of the best thing I've ever done. Having to never clean up oil covered hands/plugs every time you do an oil change, you start to appreciate the little things! For about $60, it's a no brainer...
    scocar likes this.
  15. Mar 17, 2025 at 9:19 AM
    #55
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    1,000%. I'm not sure why everyone who has never actually used one before, feels the need to post their opinion! I'd be more interested to hear from people who have put one on, and then taken it off and gone back to the regular plug....
  16. Mar 17, 2025 at 9:24 AM
    #56
    winkeldc
    2014 Reg Cab 4x4
    Welcome to the internet?
    jaymac10[QUOTED] likes this.
  17. Mar 17, 2025 at 9:36 AM
    #57
    winkeldc
    2014 Reg Cab 4x4
    I am guessing most of "its cleaner" crowd doesn't have an oil filter to drop, so I can see why that is a benefit, but has anyone drained using the valve and then pulled the valve itself to see if all the oil was evacuated? That seems to be the only knock I have read about the drain valve, that it extends into the pan by a bit and over time, residual gunk sits in the sump.
  18. Mar 17, 2025 at 9:40 AM
    #58
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Another thing that’s funny is how these naysayers compare a bag of washers with the cost of the fumoto valve.
    It’s like they must collect cans for the recycling cash value.
  19. Mar 17, 2025 at 9:51 AM
    #59
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Since it takes longer the block drains more completely and the filter as well so that’s no longer an issue. When I spin it off with a cup there’s no spillage at all. Mine’s a stock 5-lug so I use ramps which tilt the pan towards the plug and the way they work they don’t stick into the sump farther than a plug anyway.
  20. Mar 17, 2025 at 9:54 AM
    #60
    winkeldc
    2014 Reg Cab 4x4
    well yes, they don't stick farther in than the plug, but the plug gets removed for draining.
