Fumoto oil valve for 2nd gen Tacoma good or bad idea?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FletchCentMa, Mar 14, 2025.
  1. Mar 17, 2025 at 10:07 AM
    #61
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    How about a Fumoelectronic valve that works from a switch on the dashboard?
    bagleboy likes this.
  2. Mar 17, 2025 at 10:14 AM
    #62
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    The old Parnelli Jones trick, eh. Works as long as the oil lasts I guess. Need an auto fill feature to match though.
  3. Mar 17, 2025 at 10:21 AM
    #63
    bagleboy
    Scott
    Norcal, Santa Rosa
    Tucked above the frame behind the suspension. If I was in a hurry to change the oil it would overflow the loosened filter and get everywhere. Waiting for the slower drain rate of the valve allows the oil above the filter to also flow back to the pan instead. No mess because that oil isn’t there any more, just what’s still in the filter.
    Monkeybutt2000 likes this.
  4. Mar 17, 2025 at 10:27 AM
    #64
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    I actually had one installed on the Tacoma and at the time for an oil change it didn't work. They opened the valve and nothing came out. The valve failed. So I went with the no spill system. Never had a problem since.
  5. Mar 17, 2025 at 12:06 PM
    #65
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    I had a Fumoto on my '07 and it got accidently opened while out hunting and I didn't notice the oil light in time and ruined my engine.
    I drove through sage brush and somehow the brush got the valve open and drained out the oil and I didn't notice the low oil light on the dash.
    I won't be using another Fumoto because that's an expensive mistake.
    Sae68, hinmo24t and bagleboy like this.
  6. Mar 17, 2025 at 12:32 PM
    #66
    Mallrat60
    A full length skid plate would of solved that issue.
    reallifedog likes this.
  7. Mar 17, 2025 at 12:32 PM
    #67
    Waasheem
    Waasheem
    2007 xrunner
    One thing I absolutely hate is having oil run down my arm into my armpit.
  8. Mar 17, 2025 at 12:42 PM
    #68
    Mallrat60
    That's the beauty of the no spill system. The oil doesn't flow unless you have the drain tube screwd in. And it has a tube that's attached. It drains into the pan. So I no longer get it all over the skid plate. I have a 3" Dia hole for the oil drain. It just makes it so easy. Plus it sits above the bottom of the plate. And has a brass cap that screws on it as well to keep any dirt or stuff out.
    reallifedog and bagleboy like this.
  9. Mar 17, 2025 at 2:47 PM
    #69
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    When I pull my drain plug, the last couple turns I do with my hand to the side of the plug and just using my forefinger on the side of the plug. I use an enclosed drain pan. Plug drops into the top of the pan, oil drains, I haven’t gotten a drop on me. I walk away and go do something else for an hour, come back, stuff a towel in the drain hole for any last drops, pull the pan out, pick up the plug, wipe it clean, pull towel from the hole and reinstall the plug.
    Oil can easily be changed with no mess without a fumoto.
    I have one installed on my riding mower engine, and it hasn’t necessarily gotten me excited about installing one on the taco. I mean, I see the advantages, but I feel better knowing I have a drain plug securely installed.
    Rougarou680 likes this.
  10. Mar 17, 2025 at 3:01 PM
    #70
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yeah, I don’t think I’d be bushwhacking without
    i can see that. Ez drain has a short 12 mm bolt you can install in place of the hose nipple that acts as back up if you need it for whatever, sticks down less, and keeps the lever action for controlling the flow so still no mess(the hose nipple lives on the hose that’s next to the filter wrench). I also added more informative guages since it’s been decades since a dash last had what I want. A red light that only comes on after I’m fucked doesn’t cut it. If I had a garage with a lift I probably wouldn’t have one of these. It’s a convenience rather than a necessity but so are most of the things my base truck has my first ride didn’t.
  11. Mar 17, 2025 at 5:11 PM
    #71
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Less than 1 cup of old oil will remain behind. Not even enough to change the color of the new oil at all.
  12. Mar 17, 2025 at 5:14 PM
    #72
    Sharpish
    Brian
    Or you drop the plug into the pan by accident and have to fish around in 4” of oil to find it. I’ve done that a few times.
    bucktales, bagleboy and Mallrat60 like this.
  13. Mar 18, 2025 at 6:01 AM
    #73
    winkeldc
    winkeldc Well-Known Member
    2014 Reg Cab 4x4
    Guessing or have you tried that? Only thing I can go with is what I have read online on different forums of those that have removed the valve and seen (scope) or felt gunk or sludge like material in the sump in the area from where the oil sat and wasn't dropped fully. It's one thing to not fully get the oil galleys refreshed, but oil that sits in a sump tends to accumulate the gunk whereas the galleys have the oil pressure to flush the oil through preventing that buildup. Just curious if any real world users have ever checked for that.
    If only they would make a magnet, but one on the end of a collapsible rod to fish metal objects out of hard to reach areas. Man that would be useful.
  14. Mar 18, 2025 at 6:26 AM
    #74
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
  15. Mar 18, 2025 at 7:01 AM
    #75
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    The drain plug gaskets I got from my Toyota dealer the other day are no longer blue, just black. If that isn't a reason to install a Fumoto valve, I don't know what is.
  16. Mar 18, 2025 at 7:48 AM
    #76
    Sharpish
    Brian
    Then don’t buy one dude. Nobody cares.
    tacokarl likes this.
  17. Mar 18, 2025 at 8:03 AM
    #77
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The only way there would be "sludge" anywhere in a your motor is if you're not changing oil often enough. If there was concerning stuff in the bottom of your oil pan, that same stuff would be in your oil filter. If it's not in your oil filter then it's not making it's way up into your engine and damaging anything
    deanosaurus likes this.
  18. Mar 18, 2025 at 4:43 PM
    #78
    Waasheem
    Waasheem
    2007 xrunner
    This works exceptionally well for that. Also I have a half sheet baking pan, slide the drain pan out while sliding the half sheet pan in, then you can fish it out with the magnet without making a mess.
    https://www.amazon.com/dp/B000TQ4YLQ
  19. Mar 19, 2025 at 7:52 AM
    #79
    Sharpish
    Brian
  20. Mar 27, 2025 at 2:23 PM
    #80
    rockothetaco08
    rockothetaco08 Well-Known Member
    Those flexible magnetic drain plug tools work great.
