Fumoto oil valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tpr676, Dec 26, 2011.
  1. Nov 9, 2014 at 8:07 PM
    #61
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    thanks, that makes my decision not to buy it, harder :(
    yea, i was thinking the same thing, the biggest benefit to me, would be skipping the drain pan, and going straight into a gallon of milk + lil bit extra
  2. Nov 9, 2014 at 8:28 PM
    #62
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    my freebie changes from the dealer are expired so i'm installing one of these when i do my first change. i got f103 n27 so it has the nipple.
  3. Nov 9, 2014 at 8:40 PM
    #63
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    I have it on my taco and my car. Darn thing hangs like a nut under the oil pan. My low clearance car makes me real uncomfortable having this darn thing hanging down so low.
  4. Nov 9, 2014 at 8:47 PM
    #64
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Why are you removing the engine cover for an oil change?
    Dopplerplus likes this.
  5. Nov 10, 2014 at 5:34 AM
    #65
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Sometimes I take mine off for a better grip with my shitty oil filter pliers. I really need a better oil filter tool. :eek:
  6. Nov 10, 2014 at 6:05 AM
    #66
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    You're right. I just need to break down and by the best tool for the job. Instead of going the cheaper route.
  7. Nov 10, 2014 at 9:07 AM
    #67
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    no, just jam a screwdriver through the filter and twist her off. redneck steeze.
    Alexely999 likes this.
  8. Nov 10, 2014 at 9:56 AM
    #68
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Minus the fact the valve slows down the flow of oil. It's nice that I don't get touched with oil and I can open the valve with my finger. :)
  9. Nov 10, 2014 at 9:59 AM
    #69
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    LOL I've done that.
  10. Nov 22, 2014 at 1:50 PM
    #70
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Fumoto now has a plastic locking device for those that are worried about the lever being accidentally opened. Yes, it may not be the optimal solution, but it gives me a little more piece of mind. They also have the short nipple valve and you can get the connection hose for it.
    http://www.qwikvalve.com/Fumoto-Lever-Clip-Small-HC10.html
    Jon
  11. Feb 21, 2015 at 10:54 AM
    #71
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Awesome! Just what I needed to know!
    Damn, I love TW !!
  12. Feb 21, 2015 at 12:00 PM
    #72
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Had one on wifes camry since 2002 and one on my tacoma since 2011 no problems with either vehicle. Love it. Makes changing the oil a snap.
  13. Feb 21, 2015 at 12:01 PM
    #73
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    There's a TRD filter available for our trucks with a nut on the top. I just ordered a couple. They're 12$/ea
  14. Feb 21, 2015 at 1:25 PM
    #74
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
  15. Feb 21, 2015 at 9:27 PM
    #75
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  16. Feb 21, 2015 at 9:53 PM
    #76
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I've never needed a wrench or pliers on my filters, just my hands.
    I use regular Toyota filters, rub oil on the seal, install hand tight.
    Install a new plug gasket and torque plug to 30 ft lbs.
  17. Feb 22, 2015 at 5:38 AM
    #77
    Jimmyh
    SC
    2012 Prerunner SR5
    I agree with this post!
    Plus if it is installed correctly and you aren't a girl you can usually get the filter off by hand.
    Lubricate the threads and seal.
    Spin the filter on until the gasket contacts the base.
    Tighten By Hand 1/2 to 3/4 of a turn.
    Done.
  18. Feb 22, 2015 at 5:43 AM
    #78
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Even to take off? I always only hand tighten, but can't get it off without a filter wrench.
  19. Feb 22, 2015 at 5:44 AM
    #79
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    How loose are you putting the filter on? Because I'm hardly a girl, and there's no way I'm getting it off by hand.
  20. Feb 22, 2015 at 6:37 AM
    #80
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    ^^^^that
