Fumoto oil valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tpr676, Dec 26, 2011.
  1. Apr 16, 2018 at 9:45 AM
    #161
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
  2. Apr 20, 2018 at 4:40 PM
    #162
    acerunner
    acerunner Active Member
    Haven't used it, but I don't see any real advantage to it. It turns the spout to exit the side instead of straight down, and allows you to swivel it 360. I can see that being useful in cars with hard to reach drain plugs, but not on the Tacoma.
  3. Apr 20, 2018 at 7:32 PM
    #163
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yes you would,no Fumoto for me as you still have too get under the truck anyway.
  4. May 9, 2018 at 8:59 AM
    #164
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Has anyone had a dealer install their Fumoto valve? I'm having my 50K service this weekend and was going to ask if they would install it while they have it. I don't see this being a problem, but just curious what others experience has been. Thanks
    JimboAnz likes this.
  5. May 9, 2018 at 9:25 AM
    #165
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    If you don't want to install it, you have no need for it. :confused::notsure:
  6. May 9, 2018 at 9:30 AM
    #166
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    While I can appreciate your sentiments.(I think) It's not that I can't or don't want to install it myself, but the fact that I am under a maintenance plan that will be expiring soon. Since they are draining the oil, it seems to be a good time to have this done. Thanks for your opinion.
    JimboAnz and teamhypoxia[QUOTED] like this.
  7. May 9, 2018 at 10:07 AM
    #167
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    In general the hung over barely sentient techs that change oil at dealerships have trouble remembering to unzip before peeing. I would never, ever ask them to do anything that I can do myself later. Remember the guys changing the oil are the ones they don't trust to do anything else. Anyone that manages to not screw up changing oil for a few weeks/months will be moved to other work. You almost always have the lowest of the low doing the oil changes.
    With that in mind save putting the Fumoto on for yourself at your first DIY oil change. It seems like it would be impossible to screw up but there is little in this world that is Toyota Dealership Tech Proof.
  8. May 9, 2018 at 10:10 AM
    #168
    scocar
    scocar Patron of the Farts
    I would wait until after you plan expires for various reason already touched on. I just put one on last weekend during my 30k change. F-103s.
    TOP TACO[QUOTED] and ChadsPride like this.
  9. May 9, 2018 at 10:13 AM
    #169
    scocar
    I got the F-103s (short, more clearance and for skids). The SX models do not allow the locking clip, which I preferred to have, because I'm paranoid.
    https://www.fumotooildrainvalve.com/f103s.html
    TOP TACO, blu92in99 and ChadsPride like this.
  10. May 9, 2018 at 10:45 AM
    #170
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
  11. May 9, 2018 at 10:57 AM
    #171
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    I love my fumoto valve. I just put an old oil container in there and crack it open. I do it with the engine hot.
    DrFunker, TOP TACO and Blockhead like this.
  12. May 10, 2018 at 4:51 AM
    #172
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    Ive seen pics of that valve cracking and dumping oil, stick with a plug
  13. May 10, 2018 at 5:34 AM
    #173
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Let’s see some...
  14. May 10, 2018 at 6:56 AM
    #174
    Twitch81
    Twitch81 Well-Known Member
    2019 Double cab Taco 4x4
    I have ran fumotos since 2007 on various diesels and never any trouble. Glad I found this thread for the number on the one for my new to me taco...
  15. May 10, 2018 at 7:03 AM
    #175
    scocar
    Under what circumstances?
    DrFunker likes this.
  16. May 10, 2018 at 8:21 AM
    #176
    DVexile
    Ken
    The only failures I've ever seen fit into four categories:
    1. Leak on initial installation due to not tightening enough or gasket problem
    2. Leak on initial installation due to an actual defective valve
    3. Debris hitting the lever and opening the valve
    4. Physical impact to the valve shearing it off
    The first two are down to paying attention to the thing when you first install it, much like you would pay attention to any new thing you install. So once it is on there and seems to function you don't need to worry about those.
    The last two are down to physical exposure of the valve and absolutely in many configurations the Fumoto is way more subject to damage and leaking than the standard plug if it gets hit by something. In my case the Fumoto is protected by my skid plate so I'm not worried.
    I was able to find one case of a BMW with a Fumoto that stuck down too far and clipped something shearing it. I found another case in which tire debris hit a Fumoto and caused it to open. I found one case in which the valve itself was defective and leaked significantly overnight on the first install. I found multiple cases in which the valve itself was defective and had minor weeping on the first install. I found multiple cases in which the valve gasket leaked/weeped on the first install. I found no cases of the valve magically dumping oil on its own after first installation with the valve protected from strikes or debris.
  17. May 10, 2018 at 9:55 AM
    #177
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yeah but only #1 can happen to a regular drain plug. Well, I guess #4 is technically possible with a regular drain plug, but very extremely unlikely.
    #2, 3 and 4 are all Fumoto-specific problems. No thanks.
  18. May 10, 2018 at 10:03 AM
    #178
    Blockhead
    Pittsburgh, Pa.
    Sky is falling....over 160,000 miles with my Fumoto valve, roughly 30 trouble-free oil changes...love mine.
  19. May 10, 2018 at 10:07 AM
    #179
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I had my dealer put mine on at the last "free" oil change. no issue, no charge
    DrFunker and TOP TACO[QUOTED] like this.
  20. May 10, 2018 at 10:25 AM
    #180
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Thanks Jimbo! That was more of the answer I was looking for.
    JimboAnz[QUOTED] likes this.
