Fumoto Valve and the pimply faced kid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtdog, Aug 11, 2017.
  1. Aug 11, 2017 at 8:31 AM
    vtdog
    vtdog [OP] Well-Known Member
    NH
    I have been considering a Fumoto valve as I "almost" always change my own oil. However, living here in NH there are times when it is either too cold, or snowy to get under the truck to do the work. When that happens, I check around for a deal on a synthetic change and have it done by the pimply faced kid at a local shop.
    What about the valve and the pimply faced kid? Does anyone have any experience with an oil change at a shop when you have the valve installed. Do you have to explain how to use it, is there a problem, etc.
  2. Aug 11, 2017 at 8:37 AM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    I've heard that some dealers won't even touch it...
    But why don't you just schedule your changes around Spring and Fall?
  3. Aug 11, 2017 at 8:43 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I am of the opinion the pimply faced kid is equally likely to screw up the oil change with a normal drain plug. :devil: He can cross-thread the drain plug with an 1/2" impact set to max torque, forget the oil filter catcher bottle to grind against the fan belt, mistakenly drain the transmission...
    Most lube shops in my area don't employ pimply faced kids. They hire older-looking mechanics who will appear more authoritative when upselling you on the EFI system flush or transmission flush.
    Durdy, phillstill, adanfon and 2 others like this.
  4. Aug 11, 2017 at 8:49 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    as having some of those pimply faced kids in my shop. Our policy is we don't touch them. Too much liability in a draining device we can't put tamper seal on. I've been in a few shops where this is the policy. Same goes for over sized plugs, butterfly valves, quick drain (fumoto) and anything that isn't oem or oem equivalent. When I was with firestone we use to do them and some bozo decided he wanted a new engine so he opened his valve and drained his oil and locked up the motor. Firestone bought him a new motor. Couldn't prove it was the shop or the customer. Now only drain plugs that can have blue tamper seal installed will be worked on.
    Sandman614, tomwil and Key-Rei like this.
  5. Aug 11, 2017 at 8:52 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    guess what ? do it yourself from now on
    because you will always have to crawl under there and double check it if you
    have someone else touch it.
  6. Aug 11, 2017 at 8:57 AM
    Bebop
    Nick
    I thought the point of the valve was so you can change it yourself with no tools?
    Alexely999 and Braves95 like this.
  7. Aug 11, 2017 at 9:00 AM
    Avsfreak18
    Robert
    2015 AC
    Potential upside for me is not getting my hands covered in oil...
  8. Aug 11, 2017 at 9:10 AM
    Muddinfun
    Muddinfun Well-Known Member
    My local spray it yourself car wash actually has a sign somethng about please do not change oil in the bays. Like a sign is really going to stop people that would actually think of it, from draining their oil into the car wash drain.
  9. Aug 11, 2017 at 9:19 AM
    Avsfreak18
    Robert
    2015 AC
    My first thought was "What idiot would do that"
    My second thought is, "Oh so many..."
  10. Aug 11, 2017 at 10:03 AM
    KenLyns
    Belly of the Beast
    I do that. But we don't know how many miles @vtdog puts on every year.
  11. Aug 11, 2017 at 10:09 AM
    Avsfreak18
    Robert
    2015 AC
    True, but if he knows he's putting on a ton of miles, and really wants to avoid doing winter changes, just schedule 3 changes. early March, mid July, late October/early November.
  12. Aug 11, 2017 at 10:10 AM
    el_smurfo
    el_smurfo Well-Known Member
    I have a shop that I sometimes use and they figure out the valve easily. Not a pimply faced kid though...I wouldn't trust my worst enemy's car at a chain oil change shop.
  13. Aug 11, 2017 at 11:20 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Or he can put on a fucking jacket. Oil change takes like 30 minutes. I changed mine in freezing rain in January.
    I don't like the valve because I'm afriad it will leak. And honestly, how hard is it to undo a bolt? To me the valve fixes a non-existant problem.
  14. Aug 11, 2017 at 11:36 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Some people like ease of use. No tools needed and no messy hands.
    Blockhead, Key-Rei and Bebop like this.
  15. Aug 11, 2017 at 11:43 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Exactly.... even if you drive a lot of miles, you can always stretch it a bit with synthetic. I always change my oil nov 1 and may 1.
  16. Aug 11, 2017 at 12:29 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    a $10,000 fine, min, from the EPA is what that will get you.
  17. Aug 11, 2017 at 1:01 PM
    Bebop
    Nick
    Dude you are a real man!!!!! Got forbid a man should own a 14mm wrench.
    Maticuno, txtaco87 and kgarrett11 like this.
  18. Aug 11, 2017 at 1:12 PM
    TexasWhiteIce
    Texas
    Yeah buddy!!!! Tell it like it is..... *fist bump*
    kgarrett11 and Bebop like this.
  19. Aug 11, 2017 at 1:15 PM
    Avsfreak18
    Robert
    2015 AC
    xxTacocaTxx, Key-Rei and Chase8059 like this.
  20. Aug 11, 2017 at 1:27 PM
    el_smurfo
    With this valve, it takes about 5 minutes of active time in the cold. You can drain your oil directly into a gallon jug for recycling (rather than a messy pan). If you're worried about it opening, which mine hasn't in 10 years, just put a small clamp or ring on it and it's safe.
    xxTacocaTxx likes this.
