Fumoto valve choice. 103SX or the 103S
Discussion in '4th Gen. Tacomas (2024+)' started by patos tacoma, Jan 14, 2025.
  1. Jan 14, 2025 at 9:27 PM
    patos tacoma
    patos tacoma [OP] Well-Known Member
    For those that have installed a Fumoto valve on your 2024 Tacoma, which one did you install.
  2. Jan 14, 2025 at 11:06 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    103SX....well that is what I will install once I change my oil.
  3. Jan 15, 2025 at 12:51 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    I did the 103SX. Nice to have it point exactly where I want
    Blockhead likes this.
  4. Jan 15, 2025 at 7:01 AM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    103SX installed at first oil change
  5. Jan 15, 2025 at 10:00 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
  6. Jan 15, 2025 at 10:10 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'm kind of surprised they don't have the L version available in that size. (I prefer the swivel to be downstream of the valve, for peace of mind reasons. Fewer gaskets to fail.)
    I'm guessing the 4th gen has one of those horrible sideways oriented drain plugs? Yeah, life is so much easier if you can get the stream pointed straight down.
    Edit, if your plug is facing the ground, then heck no, you don't want an SX.
  7. Jan 15, 2025 at 10:46 AM
    tonymac
    tonymac Well-Known Member
    Waco, TX
    2024 TRD Sport
    I bought the regular valve. Will install when I change oil. Might be awhile!
  8. Jan 15, 2025 at 12:28 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    f133, from what i remember its suppose to be a little larger and drain faster
  9. Jan 15, 2025 at 5:00 PM
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    Pappy Jon likes this.
  10. Jan 15, 2025 at 9:17 PM
    JoeMongo
    JoeMongo perennial noob
    Jonathan
    SF Bay Area
    2024 TRD Offroad Premium, MT
    RCI Rock Sliders, RCI Skidplate, Diamondback tonneau
    103S, it points where I want my drain hose to go.
  11. Jan 15, 2025 at 10:15 PM
    hoodwinked
    hoodwinked Well-Known Member
    If you haven't already bought the fumoto, check out this one. I used to use it on my old WRX. It sits more flush to the drain pan than the fumoto and has a screw on cap to prevent accidental leakage or in case you hit your plug on something while wheeling. Then when you want to change oil, unscrew cap, connect hose to the quick connect nipple and then it just snaps on and oil starts flowing.
    https://hosewarehouse.com/products/...pling-full-flow-male-half-m22-x-1-5-6g-thread
    They have multiple sizes for various vehicles.
    PDKTaco and Light1984 like this.
  12. Jan 17, 2025 at 7:30 AM
    Tdkrum5
    Tdkrum5 New TRD OR P
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR P
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    Does anyone the size of the drain plug and thread type. Also has anyone tried the Femco. I like how they have a removable cap and hose that screw on and oil can be drained through an access hole and not have to remove your skid plate. Seems similar as @hoodwinked shared. Check them out at femco.com
  13. Jan 17, 2025 at 5:21 PM
    Tdkrum5
    Ted
    2024 TRD OR P
    FYI Just contact Femco about their drain plugs, here is their response.
    Hello Ted,
    The Toyota Tacoma would take any of our plugs with an M12x1.25-T9 thread pitch. Residual oil is not an issue when utilizing a Femco drain plug. We recommend draining the oil at engine temperature to fully flush out all waste particulates. This is easier as Femco’s system prevents burns.
    Best regards,
  14. Jan 20, 2025 at 11:14 AM
    emidyl2124
    emidyl2124 Member
