Fumoto Valve F103N DEAD DEAL
Discussion in 'Group Buys' started by Unchained 5150, May 20, 2016.
Fumoto Valve
  1. F103S
    41 vote(s)
    61.2%
  2. F103N
    26 vote(s)
    38.8%
  1. May 25, 2016 at 3:20 PM
    #141
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Rick, not sure if you're only checking eBay sellers, but I got mine off Amazon for a good price.. might be worth contacting an Amazon seller or two and testing the waters there as well.
    digitaLbraVo likes this.
  2. May 25, 2016 at 3:20 PM
    #142
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Not a bad idea
  3. May 25, 2016 at 3:21 PM
    #143
    DrFunker
    DrFunker Well-Known Member
    Thanks for giving it a go Rick.
  4. May 25, 2016 at 4:15 PM
    #144
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Amazon has it for that price and you get the removable adapter as well...it also uses a metal clip instead of a plastic clip, so why even go with fumoto if you can go with the EZ drain?
    [​IMG]http://smile.amazon.com/EZ-Oil-Drai...psc=1&redirect=true&ref_=od_aui_detailpages01
    Fumoto is not removable snout, so you just stick a hose on it... the EZ-103, you can have your hose attached to the adapter and screw on when you want to drain the oil...remove and no long snout. You can also but the screw in cover and also the metal clip? If you aren't saving much...don't see why this isn't better than fumoto.
  5. May 28, 2016 at 3:01 PM
    #145
    jsucraig
    jsucraig Well-Known Member
    Craig
    Lynchburg, Virginia
    2013 Tacoma TRD Off-Road Double Cab
    Mudflaps removed, MESO LED Interior lights, 886 Fog Lamps for Reverse Halogens, Redline Tuning Hood Struts, Garmin Dashcam 20, 17X8 Chrome Helo HE791 MAXX Wheels, Cooper Discoverer AT3 265/70R17, JBL Speakers, JL Sub, and Alpine & Memphis Amps, mattgecko LED Bed Light & Under Hood Kit, Truxedo Low Pro QT Tonneau Cover, OEM Bed Mat
  6. May 28, 2016 at 3:09 PM
    #146
    Unchained 5150
    Rick
    Auburn Ma
    Norton won't let me open it it states it's a virus
  7. May 28, 2016 at 3:13 PM
    #147
    jsucraig
    Craig
    Lynchburg, Virginia
    Hmmmm me too. I'll post the base webpage and see how that works. http://www.fumotooildrainvalve.com/
    still shows malware. Just manually copy and paste fumotooildrainvalve.com. If you manually key it in there is no malware detected. Actually the threat is from tacomaworld.com according to my mac.
  8. May 28, 2016 at 3:15 PM
    #148
    Unchained 5150
    Rick
    Auburn Ma
    That Link does the same
  9. May 28, 2016 at 3:18 PM
    #149
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    It's not, TacomaWorld is acting odd right now I just got an alert on a redirect from TW to another website that TacomaWorld is a "reported attack page."
    @tcBob
  10. May 28, 2016 at 3:20 PM
    #150
    jsucraig
    Craig
    Lynchburg, Virginia
    It appears to be a tocamoworld issue. When you hotlink it automatically gives a tacomaworld url before the hotlink.
  11. May 28, 2016 at 3:21 PM
    #151
    digitaLbraVo
    He may be implementing one of those "YOU ARE BEING REDIRECTED FROM TACOMAWORLD.COM" warnings?
    Just a theory.
    Unchained 5150[OP] likes this.
  12. May 28, 2016 at 3:22 PM
    #152
    jsucraig
    Craig
    Lynchburg, Virginia
    May be. I know that it is a big pain because I can't even cold link; as long as you add www. it auto hots the link.
  13. May 28, 2016 at 3:25 PM
    #153
    jsucraig
    Craig
    Lynchburg, Virginia
    just copy and paste this: fumotooildrainvalve.com into your url and it will take you to the home page select your vehicle, and whichever valve. At checkout use code BLK16 and the clip should automatically add to your cart. If it doesn't automatically add the clip manually add it and it will show a $2.00 credit.
  14. May 28, 2016 at 3:27 PM
    #154
    Unchained 5150
    Rick
    Auburn Ma
    Thanks I already have one but hope the guys hop on this
  15. May 28, 2016 at 3:33 PM
    #155
    jsucraig
    Craig
    Lynchburg, Virginia
    BLK16 literally just expired. Use code ACC50 for 50% off all accessories.
  16. May 28, 2016 at 5:32 PM
    #156
    jsucraig
    Craig
    Lynchburg, Virginia
    THESE ARE NOT THE CORRECT VALVES FOR TACOMAS. THESE ARE FOR A CORVETTE. THE CORRECT VALVES FOR THE TACOMA V6 & L4 ARE THE F103 SERIES, BUT THE PRICES ARE THE SAME.
    I just used ACC50 and got 50% off of accessories. In my order 2 clips, a 90* Elbow, and a 3ft tube saved me $4.75.
    May 28, 2016, 19:48Grand total: $58.65
    Item Price Qty Total
    F107S: Fumoto Engine Oil Drain Valve with Short Nipple for Drain Plug Size 12mm-1.75
    • SKU F107S $26.95 2 $53.90
    LC-10: Small Lever Clip For All F-series Fumoto Valves
    • SKU LC-10 $2.00 2 $4.00
    SL-10 | Small 3/8" ID Elbow-Shaped Plastic Socket for S-type Valves
    • SKU SL-10 $2.50 1 $2.50
    F-Hose: 3/8" ID x 3FT Clear Vinyl Tubing
    • SKU F-Hose $3.00 1 $3.00
    • Subtotal: $63.40
    • Coupon discount:
      • ACC50 (-50%) $4.75
    • Shipping cost: $0.00
    • Grand total: $58.65
  17. May 28, 2016 at 6:40 PM
    #157
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Thanks for the heads up. Looking into it right now...
    digitaLbraVo[QUOTED] likes this.
  18. Jun 3, 2016 at 4:52 PM
    #158
    imom
    CAL
    2014 Regular Cab
  19. Jun 7, 2016 at 1:22 PM
    #159
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    this garage!
  20. Jun 9, 2016 at 8:16 AM
    #160
    jsucraig
    Craig
    Lynchburg, Virginia
