Fumoto valve installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REVHARD25, Feb 6, 2011.
  1. Feb 15, 2011 at 11:37 AM
    #41
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    So I've been to Lowes and home depot...
    Both don't have them.
    Anybody have any extra?
    Or know where else to look?
    Dang...
  2. Feb 15, 2011 at 12:13 PM
    #42
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Found one online:
    http://tweetys.com/self-tighteningspringclamp58.aspx
    Hey Owen, where did you look at Lowes? I found mine in the blue metal drawers where all the bolts/nuts are located. Once drawer had a bunch of the clips in various sizes. I'm just curious if you looked there or if you asked someone and they just said they didn't have them.
  3. Feb 16, 2011 at 6:14 AM
    #43
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    I looked by the screwdriver tightening hose clamps (the ones people use for tailgate safety mod)
    And I also looked over by the nuts and bolts area, in the drawers with the special nuts/bolts. I just looked at the pictures on the outside, didn't look through them. Maybe Ill go back today and look again more thoroughly.
    Someone said Walmart also... nothing there either...
    One more reason that Southern California sucks....
  4. Feb 16, 2011 at 7:08 AM
    #44
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I would check an auto parts store personally.
  5. Feb 16, 2011 at 7:13 AM
    #45
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    will do
    thanks
  6. Feb 16, 2011 at 7:29 AM
    #46
    05Moose
    Jim
    Just FYI, I didn't find any at Walmart nor at any of the auto parts stores in my area (plumbing stores though said they could special order it). The ones at the auto parts stores are now the wide band clips.
    Owen, it was in one of the drawers and did happen to have a picture of one clip on the outside among all the other pictures. So check them carefully. Hard to believe they'd carry every size available up here yet not one at your store.
    At least I gave you a link above to order one online as a last resort.
  7. Feb 16, 2011 at 7:45 AM
    #47
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Yeh, the link is great, the clamps are cheap $1.50... but shipping for one of them is $10.30...
    seems odd.
    Im gonna go check Lowes one more time, then order from the site maybe...
    Thanks Jim
  8. Feb 16, 2011 at 7:48 AM
    #48
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    I LOVE MY FUMOTO VALVE
  9. Feb 16, 2011 at 8:12 AM
    #49
    05Moose
    Jim
    $10 for shipping! Sheesh! If Lowes doesn't have it after looking a second time, send me a PM with your mailing info and I'll mail you the second one that came in the package. I'll just tape it to a piece of paper and stick it in an envelope. It might even be light enough to only use a standard stamp.
  10. Feb 16, 2011 at 8:59 AM
    #50
    Sigo
    Sigo Active Member
    Bruce
  11. Feb 16, 2011 at 9:11 AM
    #51
    05Moose
    Jim
    F103N has the nipple for attaching a hose when draining. Unless you've got a skid plate that's blocking it and need to use a hose or just want to run a hose from the valve into a container, I can't see any reason to get the one with the nipple.
  12. Apr 27, 2011 at 11:20 AM
    #52
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Also keep in mind these guys also sell the 5/8" clip if you're having trouble finding one local. You just tack it on to your order for $3 more. http://www.quickoildrainvalve.com/SearchResults.asp?Cat=351
  13. May 23, 2013 at 10:39 PM
    #53
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    Wish I had discovered this thread sooner.
  14. May 24, 2013 at 5:37 AM
    #54
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    WTF happened in that pic?????
  15. May 24, 2013 at 5:52 AM
    #55
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    that appears to be a picture of a sequence of exothermic chemical reactions
    between a fuel and an oxidant accompanied by the production of heat and
    conversion of chemical species. The release of heat is producing light in the
    form of a flame.
  16. May 24, 2013 at 6:39 AM
    #56
    jshsltr
    Josh
    St Louis
    What he said.
    I had just completed a single person engine swap. The old engine had spun the main bearing due to a clogged uptake in the oil pan.
    Well it sprung a leak in the fuel rail about 15 minutes after the first run. I tried to find a fire extinguisher but it was too late. And from the flames... (and a generous insurance check) a great Tacoma was born.. (or purchased used for a great price.)
  17. May 24, 2013 at 7:33 AM
    #57
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    These valves look pretty cool, although I'm not going to be changing my own oil for a couple years when the freebies are done.
  18. May 24, 2013 at 8:00 AM
    #58
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Exactly! I was tired of trying to get all of the oil off my skid every time I changed it - and I sure as heck wasn't gonna pull the skid to do the oil change.
  19. May 24, 2013 at 10:27 AM
    #59
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    I need to buy a skid. I have that fear of possibly shearing off my valve one day.
  20. Sep 22, 2017 at 11:42 AM
    #60
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    What's the benefits of having a long or short nipple on it? I mean doesn't it drain from just that one hole
