Fumoto valve or magnetic drain bolt?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drogen, Nov 28, 2016.
  1. Nov 28, 2016 at 6:58 PM
    Drogen
    Drogen [OP] Floppy bass
    Demitri
    Dallas, TX
    2014 Sport 4x4
    Lift & 33s
    Which do you prefer?
  2. Nov 28, 2016 at 7:12 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I have a Fumoto valve. I love it, but wouldn't run it without a skid. Unless you keep to the pavement, then it doesn't matter I guess.
    KRAMERICA, 1Shifter and Drogen[OP] like this.
  3. Nov 28, 2016 at 7:15 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Fumoto valve, only complaint is that it seems to take forever for the oil to drain compared to the drain plug.
    kenneth.morris07 and Drogen[OP] like this.
  4. Nov 28, 2016 at 7:16 PM
    Drogen
    Demitri
    Dallas, TX
    2014 Sport 4x4
    Lift & 33s
    Good to know, thanks.
  5. Nov 28, 2016 at 7:18 PM
    1Shifter
    Jeff
    09 PreRunner
    It's not too bad, gives me time to crawl around the frame while it's draining.
    Drogen[QUOTED][OP] likes this.
  6. Nov 28, 2016 at 7:20 PM
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    The drain valve is great- with tubing attached, I drain the oil right into a gallon jar- I no longer need to use a catch pan.
  7. Nov 28, 2016 at 7:48 PM
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    THIS FTW! ^
    I've done this on all my vehicles including motorcycles!
  8. Nov 28, 2016 at 7:51 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Forever... as in the time it takes to drink a nice cold beer?
    You need excuses, you know.
  9. Nov 28, 2016 at 7:52 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    "Beers"
    Dalandser likes this.
  10. Nov 28, 2016 at 7:54 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    The valve doesn't extend below the cross member. No need for a skid plate.
  11. Nov 28, 2016 at 7:54 PM
    Drogen
    Demitri
    Dallas, TX
    2014 Sport 4x4
    Lift & 33s
    Six packs*
  12. Nov 28, 2016 at 7:56 PM
    DistortedAxis
    Toronto
    STOCK
    if it takes that long, your oil is still good... your just changing it too soon!
    Let it thin out a bit more next time. lol.
  13. Nov 28, 2016 at 7:57 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Every vehicle I'll ever own will get a fumoto.
  14. Nov 28, 2016 at 8:01 PM
    Pigpen
    Dan
    Northwest Montana
    Fumoto for sure. I agree that you should have a skid. I drive through a lot of brushy areas and a bush could grab the lever and drain your oil.
    Midnighttaco08 likes this.
  15. Nov 28, 2016 at 8:03 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I've got one on my Tacoma. I'm definitely nervous about it and planned on putting my drain plug back on when it came time to change my oil. I liked how easy it was to change my oil so much that I couldn't see removing it.
  16. Nov 28, 2016 at 8:05 PM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    A bush would literally have to grow fingers, grab a pair of pliers, remove the "o" clip, and then press the spring compressed lever over and then down. Sounds extremely plausible. That's why there's all these threads about fumoto drain valves failing. :rolleyes:
    RickG, vicali, Yaozer and 4 others like this.
  17. Nov 28, 2016 at 8:05 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Fumoto in all of my vehicles. The flexibility if allows (even if used rarely) is well worth the price of admission.
    Drogen[OP] likes this.
  18. Nov 28, 2016 at 8:10 PM
    Drogen
    Demitri
    Dallas, TX
    2014 Sport 4x4
    Lift & 33s
    Do you guys know which Fumoto I'd need for a 2014 Tacoma?
  19. Nov 28, 2016 at 8:17 PM
    Justinlhc
    Crazy shit happens off-road and a rock could easily bounce up and knock that thing off IMO.
    One time I was pulling out of a shopping center and had to run over a palm tree branch laying in the road. It jammed up in my shift linkage and stuck my car into neutral. Freak accidents happen and having a 1.5" object hanging from the bottom of your oil pan is definitely more of a risk than NOT having it.
    Skids are definitely a good idea, regardless of using the Fumoto valve.
    Dalandser and Pigpen like this.
  20. Nov 28, 2016 at 8:19 PM
    Pigpen
    Dan
    Northwest Montana
    I have the plastic Fumoto clip. Thanks for playing.
