Fun Fact or Flub?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The, Jul 1, 2021.
  1. Jul 1, 2021 at 5:51 AM
    The
    The [OP] Well-Known Member
    '17 TRD 4x4
    Shit I found on CL or EBAY that I could screw on.
    I was re-installing my seat covers and I pulled the bolts for the front seats. I was re-installing and I happened to look down the hole of the passenger rear left bolt hole and I saw pavement. The pic is terrible.
    Daylight was fading and I didn't feel like climbing under, but is this a drain or am I missing a plug down there? None of the other bolt holes were like this.
    Junkhead likes this.
  2. Jul 1, 2021 at 5:55 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Same here. The hole is filled with the bolt only
    Junkhead and SR-71A like this.
  3. Jul 1, 2021 at 5:59 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  4. Jul 1, 2021 at 6:07 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    SHUT THE FRONT DOOR?!?!?!!
    Junkhead, 44-16 Taco and Skydvrr like this.
  5. Jul 1, 2021 at 6:16 AM
    slowlane
    AZ
    16 double cab MGM
    To be fair, im pretty sure its normal. I wouldn't worry too much about it.
    TXTP and gsubioguy like this.
  6. Jul 1, 2021 at 6:16 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    That’s how 99% of the floor bolts are. Not just the seats.
    gsubioguy and 3JOH22A like this.
  7. Jul 1, 2021 at 6:29 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yes that is normal. You can see some of the bolts from under the truck. I think one of the fronts is direct through (you can see it from below). I think the other front bolt goes into like a sandwiched layer (for lack of a better term). Aka you may not be able to see the other one from below.
    Edit: toss a bit of never seize on them before you reinstall
    Key-Rei and Grossomotto like this.
  8. Jul 1, 2021 at 6:35 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  9. Jul 1, 2021 at 6:40 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The floor has a reinforcement rib below the front seat rear mount bolts. The rib has drain holes. One of the drain holes happens to line up with that particular bolt so you have direct line-of-sight with the ground. But none of the other seat bolt holes are sealed or capped. Shoot the threads with some Fluid Film or Cosmoline before installing.
    I guess it makes an improvised floor drain if you ever flood the passenger footwell in a water crossing!
    SR-71A, Junkhead and Skydvrr like this.
  10. Jul 1, 2021 at 6:56 AM
    The
    '17 TRD 4x4
    Thanks for confirmation y'all!
    I am not worried about it. It was just weird that 1 out of 8 I could see right through.
    I am sure if I had the time or the drive to look underneath, it would have made more sense.:pccoffee:
    At least I had the drive to vacuum under the seat for what I believe will the very last time.:rofl:
  11. Jul 1, 2021 at 7:14 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    This is BS. Toyota owes us an explanation.
  12. Jul 1, 2021 at 7:18 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Key-Rei likes this.
  13. Jul 1, 2021 at 7:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    To be fair, you can install seat covers without unbolting the seats. That's how I did mine. :notsure:
  14. Jul 1, 2021 at 8:15 AM
    The
    '17 TRD 4x4
    I had put them in once like that, and it wasn't the greatest fit. So I went back under and was able to really get them nice and tight.
    Plus I got to try out a new electric impact to zip them out.
    SR-71A and Skydvrr like this.
  15. Jul 1, 2021 at 8:17 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Was the same way in 1st gens as well.
  16. Jul 1, 2021 at 8:21 AM
    Stocklocker
    17TRDORDCSBAT
    You could leave that bolt out and it makes a great spot to wire in accessories or run an antenna! Too easy!
    Junkhead, RushT and Skydvrr like this.
  17. Jul 1, 2021 at 8:22 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    This is by design on pretty much all vehicles. The seat bolts through multiple layers of the body construction so the sheet metal doesn’t shear in an accident. It makes the mounting point more rigid. Usually the rears in most vehicles are enclosed, but the fronts usually thread all the way through.
    Junkhead and gsubioguy like this.
  18. Jul 1, 2021 at 8:55 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I saw this too, as I had my passenger seat out for an air compressor installation. Worst part, in my case was I started to cross thread that bolt upon reinstallation. But it’s all cleared up now and I can’t see the ground. But there is a plug, closer to the outside, right there for wires.
  19. Jul 1, 2021 at 9:26 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    Literally undrivable. File a complaint with your state AG.
  20. Jul 1, 2021 at 9:35 AM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    The hole is a portal to the underworld disguised as a regular hole.
