Functional Advantages of a lift and/or bigger tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gudujarlson, Jan 9, 2020.
  1. Jan 9, 2020 at 12:18 PM
    gudujarlson
    gudujarlson [OP] Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    For those of you that lifted your truck and/or stuffed bigger tires under it for the functional benefits, what degree of functional benefits do you perceive you got? Also how did those benefits compare to other modifications you did or considered? I am trying to phrase this question to avoid discussion of the aesthetic reasons for lifting a truck. I previously asked a similar question phrased differently and it didn’t generate a lot (it did some) of the type of discussion I was looking for.
    Edit: an ideal answer to this question would be something like, “I drove trail A while stock, then drove it with a 2” lift, then drove it with a 6” lift, and my experiences were X.” I know it’s unlikely I’ll get an ideal answer, but I’m giving an example to help drive the discussion to where I’d like to see it.
    Edit: I’m trying to avoid spending $20,000 to answer my question by myself, but there may be no other way and that might be more fun anyway. I wish truck parts were as cheap as bicycle parts. ;)
  2. Jan 9, 2020 at 12:21 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Define "functional advantage"
  3. Jan 9, 2020 at 12:22 PM
    lynyrd3
    Bill
    East Central Upstate NY
    A hell of a lot more clearance while driving in the woods or deep snow !
    BMo and tacom08 like this.
  4. Jan 9, 2020 at 12:28 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    Larger/taller tires is the only way to raise the differentials up off the ground. In order to gain that clearence one must spend hundreds or thousands of dollars to do so. That's it. That's the story. End of discussion.
    BRFab, BalutTaco, suprdav59 and 8 others like this.
  5. Jan 9, 2020 at 12:33 PM
    lynyrd3
    Bill
    Lift for bigger tires ,yes ^^^^
  6. Jan 9, 2020 at 12:36 PM
    Wesintex
    Wesintex Well-Known Member
    2017 Blazing Blue Tacoma TRD OR
    255/85R16 Toyo Open Country MT, Customish bed rack, CB radio
    Approach angle and clearance body (lift) and axle (tires).
    Some mods may be better suited. If I did more rocky offroading then sliders would have probably helped as with or without a lift I'd likely scrub the sides. An aftermarket bumper may improve and accomplish your goal if you just want approach angle improvements. I went places when I was stock that I had plenty of clearance, my approach was fine, and I never scrubbed the bottom sides of my truck (where sliders would help) BUT I kept smashing/scrubbing my rear bumper, which could have been remedied by a high clearance rear bumper.
    The lift sort of helped with all of those issues, but maybe not as much as something could have helped each thing individually. I find myself most often in mud, which is why I went MT tires -> bumper + winch -> OME HD lift kit (mostly to help with the weight upfront, I like the lift, but it was ancillary to my main purpose).
    CmdrTrekk, BlackGT99 and GreyBaldTaco like this.
  7. Jan 9, 2020 at 12:37 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    Will I see results in the downstairs department?
  8. Jan 9, 2020 at 12:40 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Ground clearance. I'm dinging the shit out of everything at stock height just driving fire roads.
    mgmdclb likes this.
  9. Jan 9, 2020 at 12:47 PM
    gudujarlson
    Minnesota
    Example: Without it I could not get over obstacle A.
  10. Jan 9, 2020 at 12:49 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Aside from clearance and angles(lift helping body/frame clearance and tires helping diff and body/frame), bigger wider tires have a bigger contact patch which gives you more traction. A bigger tire will also have an easier time climbing near vertical faces(not talking about driving straight up, but getting up 1-2 foot "shelves")
    Certain suspension set ups will give you more articulation, which can keep a tire on the ground that otherwise wouldn't. Suspension can also help letting you go faster through some terrain, soaking up the bumps and cracks better.
    mgmdclb likes this.
  11. Jan 9, 2020 at 12:49 PM
    gudujarlson
    Minnesota
    It’s debatable whether a lift is required to install bigger tires. Also, the ability to install bigger tires is not a functional advantage unless the tires have a functional advantage.
  12. Jan 9, 2020 at 12:51 PM
    gudujarlson
    Minnesota
    This is all generally accepted and well documented theory. Do you have any specific personal experiences?
  13. Jan 9, 2020 at 12:53 PM
    gudujarlson
    Minnesota
    Me too. Did you lift? How far? How much did it help? Was there a trail you couldn’t do without the lift?
  14. Jan 9, 2020 at 12:55 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    A lot easier to clear over the snowflakes.
    lynyrd3 likes this.
  15. Jan 9, 2020 at 12:57 PM
    gudujarlson
    Minnesota
    I don’t notice clearance problems in the snow until it’s so deep that I’m plowing it (15”+). At that snow depth, I’m not sure I could go over any sort of obstacle even if I had enough clearance. In snow I am more worried about traction than clearance. I have not experimented a lot with clearance though. I am curious to hear if you have.
    Edit: what I mean is that I generally have traction problems in snow before I get to the point where I am having clearance problems. But snow varies so much, so it depends. Snow is awesome that way. Conditions can be complete different day to day. Keeps you guessing. I used to do a lot of bicycling in the snow and had to constantly change up my gear and tactics day to day.
    lynyrd3[QUOTED] likes this.
  16. Jan 9, 2020 at 12:58 PM
    lynyrd3
    Bill
    Yes ,clearance :facepalm:
  17. Jan 9, 2020 at 12:59 PM
    supmet
    Paul
    Most/all of that isn't theory unless you mean scientifically like the theory of gravity.
    But yes, I have a 2 inch lift which did indeed lift the truck. My 32" ATs have more traction than the stock tires. I can definitely do bumpy fire roads, washboard, etc faster than with the stock suspension.
    lynyrd3 likes this.
  18. Jan 9, 2020 at 1:02 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Ive been stopped dead by a downed tree across the road at stock height/tire size. With bigger tires we could have climbed over it. This was in a Forest Service pickup. I now carry a saw
    CaptainBart45 and lynyrd3 like this.
  19. Jan 9, 2020 at 1:04 PM
    gudujarlson
    Minnesota
    Yes but you are just quoting generally accepted and well known theories/best practices.
  20. Jan 9, 2020 at 1:08 PM
    gudujarlson
    Minnesota
    That makes sense, but with say a 2” lift and 33” tires how many more trees could you climb over? I know it’s probably not an easy question to answer and that’s why I asked the original question.
    And ya a saw is probably a better solution to your problem. I once was descending a narrow, steep, and long farm “road” when I ran into a downed tree and had to reverse all the way back up it. Hah!
