functional hood scoop/ram air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 75thrangertaco, Jun 12, 2010.
  1. Sep 23, 2014 at 9:05 PM
    #61
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Yes blower relates to a ROOTS supercharger.
    Gains are 70hp to the crank.
    Cool air is dense...... Dense air creates more hp.
    Mpg is unaffected
  2. Sep 23, 2014 at 9:07 PM
    #62
    Yota64
    Yota64 Professional Threadjacker
    Hmm. I wish the gains of a TCAI or Ram air were enough to justify buying one. Not dissing them, just am on a budget and need some real functionality to spend my stagnant $$$s
  3. Sep 23, 2014 at 9:09 PM
    #63
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Urd tcai is good for 10+ HP
    The only issue with the stock setup is the box itself.... Get rid of the piece of crap. Thrown on the urd, afe stage 2 si, or the volant and u will see gains due to the removal of the stock airbox/resonator.
  4. Sep 23, 2014 at 9:16 PM
    #64
    Yota64
    I'm not in disbelief of that-it's just that I don't use my truck in WOT at any time. I accelerate slowly and cruise at 60 MPH on the highway between school and home once a week. When with friends I drive the speed limit but I am never flooring it, so the only benefit that fits my needs is MPG. I do think a ram air system (Not necessarily a ram air from a company, but a self designed one) could improve MPG because I have heard often that snorkels increase MPG, and by that logic there must be ways to improve it with some rigging.
  5. Sep 23, 2014 at 9:16 PM
    #65
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
  6. Sep 23, 2014 at 9:19 PM
    #66
    Yota64
    I was actually looking at that recently. It is so strange to me that that actually works. For a few reasons.
    1)Something that simple-couldn't Toyota have just designed an intake that was already that spaced if it increases power? Why not if it really works?
    2)The very first thing I (thought I) learned on TW was the throttle body spacers were no more than gimmicks. And now I'm hearing they make gains? :Goingcrazy:
  7. Sep 23, 2014 at 9:30 PM
    #67
    Lord Helmet
    Nick
    Well it does make sense pertaining to the intake spacer. In the intake manifold with short runners you lose the low end and mid range but gain a lot in the high end. With the longer runners you gain low end and mid range but suffer in the high end.
    A perfect example is the Honda dual intake manifold on the 94-01' Acura Integra GSR. On low rpm the long runners are open and short runners are closed. During a preset rpm 5500 rpm and up, the short runner opens up helping the engine get the air flow quicker. I hope that make sense.
    So with the spacer you just lengthing the intake manifold runner and moving the power band down a tad in the rpm.
  8. Sep 23, 2014 at 9:34 PM
    #68
    Yota64
    Okay, so I guess I would see gains from one at my end-2000 RPM?
  9. Sep 23, 2014 at 9:44 PM
    #69
    Lord Helmet
    Nick
    You'll be making gains around 1500-3500 rpm. The sweet spot on the 1GR which I believe it lives it's life around the most.
  10. Sep 23, 2014 at 10:14 PM
    #70
    Yota64
    Then I might have to try it some time.
  11. Nov 13, 2014 at 6:12 PM
    #71
    OEM2011
    OEM2011 New Member
    How can it be anything other than a low air pressure area, of course it will be, its a dead leg for any air flow (plugged hood scoop). Now, if you unplug the scoop, measure the air flow and you'll find it is quite high, next move, add a vacuum to the equation and this should be sufficient to providing combustion air to the motor. Just to add some perspective, what would make anyone believe that the OEM filter arrangement is in a higher air pressure area, lol.
