Funky electronics, brakes and lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96BlueTacos, Oct 7, 2019.
  1. Oct 7, 2019 at 11:57 AM
    96BlueTacos
    96BlueTacos [OP] トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Hey Tacoma world, hopefully someone has had something similar to this happen.
    If my headlights are off and I hit my brakes, my driving lights come on with each push of the brake pedal (the lights that come on with the first click of the headlight switch, I think they are called driving lights). If I turn my headlights on it doesn’t seem to flash the lights, only when my headlight switch is off my driving lights come on every time I hit the brakes.... any ideas?
  2. Oct 7, 2019 at 12:08 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Do you have towing elect connection?
  3. Oct 7, 2019 at 12:33 PM
    96BlueTacos
    Mikey
    Yes I do it’s been there’s since I got it
  4. Oct 7, 2019 at 2:29 PM
    Black DOG Lila
    Virginia
    The control box for tow package lights don't last forever and cause strange light issues eventually
  5. Oct 7, 2019 at 2:47 PM
    96BlueTacos
    Mikey
    Hmmmm I will check that out thanks.
    Should I just disconnect it and see if it fixes the problem you think?
  6. Oct 7, 2019 at 2:58 PM
    Black DOG Lila
    Virginia
    Worth a try. Won't hurt anything.
  7. Oct 7, 2019 at 3:12 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Remove that harness. It’s easy to do and your problem will disappear.
  8. Oct 7, 2019 at 4:26 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Of it is not that box, then the second common reason for this behavior is broken ground contact between the tail lamp and the battery. It could be as simple thing as rusted lamp socket or corroded grounding wire or grounding point.
  9. Oct 7, 2019 at 5:38 PM
    96BlueTacos
    Mikey
    Awesome, I did get rear ended a couple of months ago, so that could have jacked up the ground, or the trailer light box ill check all that out
