Funky noise @ Front of Engine
Discussion in 'Technical Chat' started by Denver, Jul 2, 2010.
  1. Jul 2, 2010 at 4:40 PM
    Denver
    Denver [OP] Member
    Denver
    S/E Georgia
    '04 Prerunner SR5
    I have an "04 Tacoma Pre-Runner Dble-Cab. w/ V-6. I just bought it in May,I've put 3500 miles on it or so & Wednesday it started making an awful racket at the front of the engine. It first appeared after stopping to get fuel after 2.5 hour of driving or so & then restarting. Thought it was coming from passenger side front, but now seems to be coming from front cover. Ideas???? Please?? It has apprx 96,000 miles.
  2. Jul 2, 2010 at 7:22 PM
    Denver
    Denver [OP] Member
    Denver
    S/E Georgia
    '04 Prerunner SR5
    Come On Guys..........:confused:
  3. Jul 2, 2010 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! Im trying to think of what it could be. Hopfully, more minds will jump in...
  4. Jul 2, 2010 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What does the sound, sound like? Clanking? Rattling? Clicking?
  5. Jul 2, 2010 at 8:48 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Wih the exception of sound how does it run?
    Can not be timing chain since this year V6 has belt. So another question would be when was the timing belt done. 96 k is about the time in needs to be done. Any issues with oil pressure, voltage, or maybe any leaks on the front.
  6. Jul 2, 2010 at 8:54 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    What type of noise would help. Timing belt maybe if it is coming from the front.
  7. Jul 3, 2010 at 3:57 PM
    Denver
    Denver [OP] Member
    Denver
    S/E Georgia
    '04 Prerunner SR5
    Sorry for the delay in responding. It is past time to change the timing-belt & I'm making arrangments to get that done. I listened again & settled on the Power Steering Pump. Drained out old fluid, replaced w/ Lucas & noise has reduced significantly. The truck is running very well. As I said I will get the T-Belt changed right after the Holiday.
    Do these trucks have a history of P/S pump failure??
  8. Jul 3, 2010 at 4:00 PM
    Denver
    Denver [OP] Member
    Denver
    S/E Georgia
    '04 Prerunner SR5
    By The Way: Thanks for the welcome & the replies & again sorry for the delay. Time gets away from you when your truck ain't doing right!!:eek:
  9. Jul 6, 2010 at 7:53 PM
    Denver
    Denver [OP] Member
    Denver
    S/E Georgia
    '04 Prerunner SR5
    It was the A/C pulley?clutch bearing. Gone Has to be replaced. History of early failure????
