Funky Noise In Dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ngneer, Oct 7, 2015.
  1. Oct 7, 2015 at 5:52 PM
    Ngneer
    Ngneer [OP] Well-Known Member
    Hope I can splain in correctly. On any other setting other than defrost, I get a sound like the vent doors n dash are constantly opening and closing. Anyone run into this before. Sorry forgot, 02 Xcab 4x4 auto 3.4. Thanks folks
  2. Oct 7, 2015 at 7:32 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    It could acually be that the vent doors are constantly opening and closing. Look on the bright side, winter's coming.
    Sorry, I got nuthin'. :/
  3. Oct 7, 2015 at 8:42 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Ive got no helpfull info, but i do know that its a fairly common problem in the later models. Try searching on here or hopefully someone can post a link to one of the usefull threads...
  4. Oct 7, 2015 at 9:16 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Mine does that too if the weather is mild (70s) AND the temperature knob is all the way counterclockwise (cold). If you set the temperature up one click clockwise from full cold (or anywhere above full counterclockwise cold) it will stop.
    I think it has something to do with the climate control thermostat having the off/on temperature set too close together so the duty cycle is basically zero. I can't prove that and don't ask me how to fix it.
  5. Oct 9, 2015 at 6:32 PM
    Ngneer
    Thanks bravo for useful posting and info, I'll try that tomorrow.
  6. Oct 9, 2015 at 6:40 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Mine does it also, it's the blend door actuator servo. From what I can find is that it when it stats going crazy it on its way out. Been doing it for over a year now so I just deal with it.
  7. Oct 9, 2015 at 6:45 PM
    Ngneer
    DAMN, I miss the cable slide temp adjuster. Life use to b so simple. Thanks Taco, btw where the hell is that thing for when it goes out. Thanks man.
  8. Oct 9, 2015 at 7:01 PM
    TACO TX
    Kelly
    Denison ,Texas
  9. Oct 9, 2015 at 8:20 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Mine does the same damn thing....has for about 5 years.
    bowyer2002 likes this.
  10. Oct 11, 2015 at 7:44 PM
    Ngneer
  11. Oct 11, 2015 at 8:26 PM
    AmericanInfidel
    AmericanInfidel Well-Known Member
    Mine as well, turn up the stereo... lol... we all have the same gremlin
  12. Oct 13, 2015 at 2:45 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Same here, dashboard gremlins!
  13. Oct 13, 2015 at 4:25 PM
    Ckali7
    Ckali7 Active Member
    Mines done it since it was brand new!
