Funky smell from A/C?
Discussion in '1st Gen. Tacomas (1995-2004)' started by KiteGuam, Dec 30, 2016.
  1. Dec 30, 2016 at 8:06 PM
    KiteGuam
    KiteGuam [OP] The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
    Just noticed about a day ago that I have a strange smell coming from my A/C. It's almost like vinegar, at first I thought it was this new air freshener but then I got rid of it and the smell is still there. It's only when I turn the A/C on that I smell it too so I know it's coming from there. Any idea on how to get rid of it or do I just go on an adventure and tear apart my dash and locate the source?
  2. Dec 30, 2016 at 8:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    KiteGuam[OP] and DustStorm4x4 like this.
  3. Dec 31, 2016 at 2:21 AM
    KiteGuam
    Guam
    Do 1st Gens even have a filter?
  4. Dec 31, 2016 at 3:12 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No filter on 1st gens.
  5. Dec 31, 2016 at 3:15 AM
    koditten
    Kirk
    Central Michigan
    Just noticed you are in Guam. Its pretty humid there, correct?
    Make sure the drain is clear like Bill said. Its located on the passenger side fire wall. When the truck is running and the air is on, you should see water dripping out of that drain. Poke coat hanger in it or similar to clear the drain. If it starts flowing good, then you know you had a build up and that was what was causing the stink.
  6. Dec 31, 2016 at 3:33 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Rodents in the duct work is always a possibility
    I can`t think a blocked drain is going to smell like vinegar but in high humidity a new life form could be growing
  7. Dec 31, 2016 at 4:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's why I said 'if'. I have (had) no clue. Now that @koditten has edumacated me, the answer is 'no'.
    I'm a little surprised that maybe the latter years didn't have one, as my '04 Highlander does. But I guess they didn't worry about the dirty trucker types. o_O
  8. Dec 31, 2016 at 7:36 AM
    KiteGuam
    Guam
    Thanks guys I will check on those. Happy New Years! :cheers:
  9. Dec 31, 2016 at 7:47 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    spray Lysol into the intake grill on the cowl where the wipers are while the AC is running full blast and the cab air recirculator switch is on
    KiteGuam[OP] and SnowFarmer like this.
  10. Dec 31, 2016 at 7:53 AM
    SnowFarmer
    SnowFarmer I intend to live forever, or die trying.
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    This. This is a common thing in the HVAC industry we call Dirty Sock Syndrome. The short of it, you are smelling bacteria growing in the coil. Like when you work in your socks all day and then enjoy that aroma when you take your shoes off when you get home. Spray some lysol into the intake and the smell should go away as Mush Mouse pointed out.
  11. Dec 31, 2016 at 7:56 AM
    Mush Mouse
    mush
    2013 SR5
  12. Dec 31, 2016 at 8:48 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Air recirculate OFF you want to draw it into the inside. Once the inside is loaded with Lysol then switched to recirculate ON
  13. Dec 31, 2016 at 11:17 AM
    Mush Mouse
    mush
    2013 SR5
    your right:D
  14. Dec 31, 2016 at 9:18 PM
    KiteGuam
    Guam
    Wow thanks that sounds exactly like what I need. Air recirculation has been on for a while now too so I'll grab some Lysol
    Mush Mouse[QUOTED] likes this.
